Motorola P2k A-Series: A630,A668,A728,A732,A768i,A780,A835,A840,A920,A925,A1000,A1200 C-Series: C250,C26x,C33x,C35x,C370,C380,C450,C550,C650,C390,C975,C980 E-Series: E1,E398,E390,E375,E370,E378i,E380,E680,E770,E1000,E680i,E1070 P-Series: P280 T-Series: T280,T720,T721i,T722i V-Series: V60,V66,V7x,V80,V150,V180,V186,V188,V220,V226,V235, V30x,V360,V400,V500,V525,V535,V547,V555,V557,V635,V600,V620,V872, V3,V3x, V3i,V980,V975,V1050. other-Series: like L6,L7,U6. |
10-13-2003, 07:08 | #1 (permalink) |
Junior Member Join Date: Oct 2003 Location: México, City Age: 45
Member: 41426 Status: Offline Thanks Meter: 0 | Help with my C33x. IT'S DEAD What can I do to repair it? how can I re-flash it if windows doesn't recognize the phone? is there a way to install the drivers manually? if yes How? If I can get my hands on another C33x and install the drivers, do you think I can re-flash my phone then? if yes how? Thanks a lot in advance.. Last edited by Alcon; 10-13-2003 at 08:02. |
10-13-2003, 09:20 | #2 (permalink) |
No Life Poster Join Date: May 2000 Location: Bacau, Romania Age: 50
Member: 1447 Status: Offline Thanks Meter: 97 | don't need to pull uot the battery... Try again.Battery must be full. If don't work try to press * and # simultan when flasher search the phone..... by.. |
10-17-2003, 23:33 | #4 (permalink) |
Freak Poster Join Date: Dec 2002 Location: Zooropa Age: 42
Member: 18832 Status: Offline Thanks Meter: 18 | Well well. many times it's been said. Short pins 13-14 on connector, and most likely victor soft detects phone. Anyway press reset just for safety's sake on the phone. Then press power on. Don't bother yourself if you don't see anything on screen. It's normal. After that with pins 13-14 shorted for me Victor soft always detect phone. You can also check up in your device manager, to see if there is Motorola Flasher Interface installed in your USB peripherials section. Regards |
10-18-2003, 00:14 | #5 (permalink) | |
No Life Poster Join Date: Jul 2002 Location: uk
Member: 13808 Status: Offline Thanks Meter: 163 | Quote:
...what you should do is, remove the plastic coverings on the phone, (the one covering the back and the front), then with the phone screen facing you, to the left side near the screen up, you ll see a small switch....rock the switch to the other position for a couple of minutes...maybe 1 minutes or less and return to its original position. Then try flashing again...... This should help... BR | |
10-18-2003, 00:21 | #6 (permalink) |
No Life Poster Join Date: Mar 2003
Member: 24435 Status: Offline Thanks Meter: 4 | esoojay never lies mate beleive him... solution posted on: http://www.iespana.es/lggroup/html/g...nlock_c33x.htm |
10-18-2003, 07:03 | #7 (permalink) |
Member: 41426 Status: Offline Thanks Meter: 0 | thanks a lot, I finally solved my problem, I installed winXP and used a friend's c33x to install the drivers, the I connected my phone to the cable and it recognized the flash interface, after that, I flashed it and it's working now. But thanks a lot for your help... |
10-18-2003, 10:11 | #8 (permalink) |
No Life Poster Join Date: Aug 2003 Location: at home
Member: 36951 Status: Offline Sonork: 100.63212 Thanks Meter: 6,247 | when you flash mot c3xx u must flash it under win 200 or xp. under win 98 the program freezes while flashing so flash uner xp or 2000 and start passo under win 98 br andres |
11-06-2003, 05:21 | #9 (permalink) |
No Life Poster Join Date: Sep 2002 Location: Cebu, Philippines
Member: 15652 Status: Offline Thanks Meter: 344 | Flash.exe tells me while about to flash working c33x warning The file you selected doesnt match the connected phone! Are you sure you want to try to flash this file. Im sure i have c33x and i dont know why flash.exe tells me this. should i ignore this or what? |
can someone help with my alibaba box? it's asking for an activation string | blackcobralinks | HWK | 1 | 06-21-2008 23:59 |
pls help with my smart clip its dead pls hep sir | andrew14 | Smart-Clip | 3 | 01-05-2006 03:03 |
I need help with my dead c45 ID: C4C2E3C0 | pegppp | Phone Unlocking Codes & Maps | 3 | 10-27-2002 14:20 |
