Motorola P2k A-Series: A630,A668,A728,A732,A768i,A780,A835,A840,A920,A925,A1000,A1200 C-Series: C250,C26x,C33x,C35x,C370,C380,C450,C550,C650,C390,C975,C980 E-Series: E1,E398,E390,E375,E370,E378i,E380,E680,E770,E1000,E680i,E1070 P-Series: P280 T-Series: T280,T720,T721i,T722i V-Series: V60,V66,V7x,V80,V150,V180,V186,V188,V220,V226,V235, V30x,V360,V400,V500,V525,V535,V547,V555,V557,V635,V600,V620,V872, V3,V3x, V3i,V980,V975,V1050. other-Series: like L6,L7,U6. |
04-16-2002, 03:28 | #1 (permalink) |
Freak Poster Join Date: Oct 2001 Location: uk
Member: 6995 Status: Offline Thanks Meter: 0 | help on pst2 v66 unlock |
04-16-2002, 04:29 | #2 (permalink) |
Freak Poster Join Date: Nov 2001 Location: england
Member: 7240 Status: Offline Thanks Meter: 0 | me too i need the same help i installed motorola.exe copied the patch in to dir pst now i m supposed to update the driver but which hardware and how i need somebody to go through he procedure on msn or something please yardim lazim |
04-16-2002, 19:46 | #3 (permalink) |
Freak Poster Join Date: Jan 2002 Location: U.K
Member: 8465 Status: Offline Thanks Meter: 0 | instructions v66 @ t68 Motorola V60/V66 Unlocking System This Software Will Only Work On Windows 98SE Setting up the v66 Drivers You need a v66/v60/ Make sure you have nothing installed to do with the v66 software etc. Then install PST by JIC Electronics. Now extract the driver packs into the PST folder (C:\Program Files\Motorola\PST) Now restart the computer. When the computer has started back up, Connect the phone and point everything to the PST folder, When everything is installed, Restart the computer and disconnect the phone. When the computer has rebooted, Run PST.exe or Phone Flasher.exe and connect the phone, You should now see one of these: USB Device Motorola (v.series 66) phone When these come up, If it is the USB Device shown, and it asks for drivers again point it to the PST folder, You are wanting the USB Device to be shown first! Then you should see Motorola (v.series 66) Phone appear, and it should start flickering on and off, Between P2Kx (where x Is a number) and Motorola v.series phone screens, When that has done, Restart the computer and run PST/Phone flasher.exe, You should now have the device in the corner of the screen to select before flashing. If you did it well done If not, Try again…. ( Connect the phone via the USB cable Make sure its powered on Run PST.exe, which is located START>>PROGRAM FILES>>MOTOROLA PST>>FLASH & TEST COMMANDS Go to the browse button next to the file name dialog box and open the file called V66E to C GB.shx Now in the bottom left of the screen, highlight the device using your mouse (V66 PK port 0) After doing this the FLASH button should be highlighted, click on this and wait for the flashing process to finish…this should take about 2-3 minutes Now shut down PST.exe program and run phone programmer, this is located in START>>PROGRAM FILES>>MOTOROLA PST>>PHONE PROGRAMMER Go to file and open…Select pFlex You will be greeted with the message “Are you sure you want to start Flexing?” Click on “YES” Select the file called V66 E to C GB.hs Another window will appear, just select RUN When all is done program will tell you “Programming Complete” Phone is now unlocked and may be showing Chinese! Don’t worry you can change back to English very easily, by inserting card of your choice and doing this….. MENU = top middle button SELECT = top right button UP,DOWN = arrow keys Press MENU once, then UP once, and then SELECT Then UP once, and then SELECT Then DOWN seven times, and then SELECT Then just select ENGLISH and press SELECT Last edited by GSMWIZARD; 04-16-2002 at 19:50. |
04-18-2002, 16:42 | #5 (permalink) |
No Life Poster Join Date: Oct 2001 Location: n east
Member: 6705 Status: Offline Thanks Meter: 24 | driver pack dont mean to sound stypid but where are the driver pack when unzipped i only hav four files notepad /shx/sh/and instalation prog any help appreciated |
04-22-2002, 22:08 | #6 (permalink) |
Major Poster Join Date: Nov 2001 Location: Leicester, UK
Member: 7300 Status: Offline Thanks Meter: 0 | You can download the driver packs from cellgate who host the pst software. I still haven't been able to get the software to work though, i've followed these instructions perfectly & the psthelp that you can download from the same site but every time after i connect the phone and direct the add new hardware to the pst folder i just get "windows was unable to locate a driver for this device". The file P2K.inf is 100% in the PST folder. Anybody got any other ideas? |
04-23-2002, 03:40 | #8 (permalink) |
No Life Poster Join Date: May 2001 Location: U.K Age: 54
Member: 4611 Status: Offline Thanks Meter: 68 | When you try and install the p2k.inf files, select the second pk driver in the list. (I think there are about 6 to choose from) windows should then detect further devices. just keep telling it program files\motorola\pst. for the location of any drivers, and all should be o.K |
04-24-2002, 02:45 | #11 (permalink) |
Member: 4611 Status: Offline Thanks Meter: 68 | The IMEI software is "ATE" when you work it out for a while, it is very simple to change IMEI on a V66 etc. The serial lead (no diagrams sadly) will also flash and flex the phone, so if the IMEI thing worries you (the networks might ban the number, as they are always the same). Just buy a serial lead and forget the usb cable. P.s you only have to install the main program for PST and everything works straight away. |
need help on how to unlock c651 | rain_89 | Motorola P2k | 0 | 01-09-2007 10:03 |
help on purchasing e700 unlock cable to use wid ust pro 6 | JOKERS | Trident/AGERE Platform | 2 | 10-20-2004 09:51 |
help on how 2 unlock a835 with smartclip | MichieMax | Smart-Clip | 2 | 09-24-2004 16:27 |
Need help on hackgsm E365 unlocking tool | bcnboy | Motorola ODM | 0 | 02-28-2004 15:33 |
i need help on nokia sp unlocker | koloksky | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-17-1999 02:29 |
