Go Back   GSM-Forum > GSM Mobile Brands -Software Area- > Motorola > P2k Series
P2k Series A-Series: A630,A668,A728,A732,A768i,A780,A835,A840,A920,A925,A1000,A1200
C-Series: C250,C26x,C33x,C35x,C370,C380,C450,C550,C650,C390,C975,C980
E-Series: E1,E398,E390,E375,E370,E378i,E380,E680,E770,E1000,E680i,E1070
P-Series: P280
T-Series: T280,T720,T721i,T722i
V-Series: V60,V66,V7x,V80,V150,V180,V186,V188,V220,V226,V235, V30x,V360,V400,V500,V525,V535,V547,V555,V557,V635,V600,V620,V872, V3,V3x, V3i,V980,V975,V1050.
other-Series: like L6,L7,U6.
Old 06-30-2005, 02:00   #1 (permalink)
Member: 53124
HELP V3 water damage, now say insert sim card
V3 Razzor water damage, now say insert sim card,
i got 2 unit which is the same, both water damage and i clean it up all working put doesn't read sim card ?????
i need a serivce manaul or if someone have fix this problem before?
Please Please help.
could it be like a nokia sim card ic that need replacing or what ??
please please help
regards
ken
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Share on Facebook
Old 06-30-2005, 07:02   #2 (permalink)
Member: 144358
I think your out of luck . from what I have seen of water damaged motorolas they burn any solder joints that power was running thru at the time the damaged occured.
there are no fuses or breakers to save the phone
Old 07-01-2005, 17:50   #3 (permalink)
Member: 150005
Arrow
I have found water damaged V3 phones are hard to fix and get back to normal. Service Manual won't help. Maybe someone can help you but with water damage in this phone it is hard to fix.
Old 07-02-2005, 05:36   #4 (permalink)
Member: 154129
if you phone is dead am wilign to buy it from you
Old 12-26-2005, 12:46   #5 (permalink)
kades's Avatar
Member: 77651
I have the same problem here... Does anyone have a hint to fix it???
kadES
Old 12-31-2005, 02:19   #6 (permalink)
Member: 142704
hello the solution for your V3 keypad stopped working is you need to heat the board
step 2 toltally change to flex to the LCD i give you 100& surellu is gonna work
[IMG] code is Off
Refbacks are Off
GSMCity - GSM Hosting - 1999-2010
Page generated in 0.05217 seconds with 8 queries
