Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Motorola > Motorola P2k
Motorola P2k A-Series: A630,A668,A728,A732,A768i,A780,A835,A840,A920,A925,A1000,A1200
C-Series: C250,C26x,C33x,C35x,C370,C380,C450,C550,C650,C390,C975,C980
E-Series: E1,E398,E390,E375,E370,E378i,E380,E680,E770,E1000,E680i,E1070
P-Series: P280
T-Series: T280,T720,T721i,T722i
V-Series: V60,V66,V7x,V80,V150,V180,V186,V188,V220,V226,V235, V30x,V360,V400,V500,V525,V535,V547,V555,V557,V635,V600,V620,V872, V3,V3x, V3i,V980,V975,V1050.
other-Series: like L6,L7,U6.
Old 07-17-2006, 14:07   #1 (permalink)
a2b2t's Avatar
Member: 214516
Thanks Meter: 86
how to unlock v360 with test point
hi how can i unlock v360 with test point please tell me step by step thanks
Old 07-17-2006, 17:47   #2 (permalink)
cellectro's Avatar
Member: 73310
Thanks Meter: 3
open shield, i do mine mini grinder, locate tp, connect cable, then tp, then bat, search sc and the rest is easy
Old 07-18-2006, 09:18   #3 (permalink)
Member: 39925
why i use testpoint to unlock,then the phone can not on already?
the v360 is from aus one...
any solution?
Old 07-18-2006, 14:01   #4 (permalink)
Member: 38025
Thanks Meter: 4
CONNECT TP exactly like the schema then power on then use search after finding the phone disconnect tp then unlock then wait about 1 min to begin unlocking phone
Old 07-18-2006, 14:57   #5 (permalink)
Luc+Luc's Avatar
Member: 85694
Thanks Meter: 48
Do we need some special cable for TP?
Old 07-18-2006, 16:52   #6 (permalink)
a2b2t's Avatar
Member: 214516
Thanks Meter: 86
please tell mi ho can i open v 360 i am rying but useless i have opend 4 patch or screws and from lower white part of mobile but fail to open body please help mi
where is secret
thanks
Old 07-18-2006, 17:26   #7 (permalink)
a2b2t's Avatar
Member: 214516
Thanks Meter: 86
hi it is difficult to separate shield from the body which method is easy to cut the shield and also when test point is conected how can i put the bettery very strange how tell mi please
Old 07-18-2006, 17:32   #8 (permalink)
cellectro's Avatar
Member: 73310
Thanks Meter: 3
i use mini grinder where tp is located, then the rest is easy
Old 07-19-2006, 16:27   #9 (permalink)
a2b2t's Avatar
Member: 214516
Thanks Meter: 86
hi i tried to open the shield but failed now my mobile v360 is without service .what is the solution
please help mi
Old 07-20-2006, 06:22   #10 (permalink)
cellectro's Avatar
Member: 73310
Thanks Meter: 3
@a2b2t some unlockings are like playing chess,be patient and think, with difficult tp phones i just make a plan to unlock it,take it slow,it works
Old 07-21-2006, 01:26   #11 (permalink)
ebu mohammed-emin's Avatar
Member: 263993
Sonork: 100.1612432
Thanks Meter: 173
take one kabel to gnd best from the energy(strom) kabel
and aded one nadel to the kabel
tuch the nadel to the testpoint
putt the batery to his plase and search after
remove the nadel and press unlock via testpoint
wait little bit phone unlock ok
Old 07-21-2006, 11:50   #12 (permalink)
J-lock's Avatar
Member: 40451
Sonork: 100.1580450
Thanks Meter: 73
can we use hot air station to open the shild ...?or just the gringer ist best idea, im asking cose i never have unlockin that phones
Old 07-21-2006, 20:39   #13 (permalink)
Member: 305743
Hi everybody You can use charp cutting , hot air station or gringer but the must important here is to be very careful to what are you doing because w/o precaution you can get differente result
good luck
Old 07-22-2006, 09:11   #14 (permalink)
Member: 95476
Thanks Meter: 185
chek pictur of test poin and you have......
Old 07-23-2006, 19:51   #15 (permalink)
zakovb's Avatar
Member: 32589
Thanks Meter: 4
ok my friend can you help me....???
if i solder very small wire to the test point BUT where to i connect the other end of wire to GND?? where is GND...please explain thank you
[IMG] code is Off
how to unlock c81 with test point mobayk S-Gold Based Phones 2 02-26-2009 10:13
how to repair gdfs with test point ruvanw1979 SETool2 3 07-29-2008 13:27
how to unlock v3xx with test point???? abdelhak_gsm Smart-Clip 17 04-07-2008 19:42
How To Unlock C60 Without Test Point ??? wintesla E-Gold Based Phones 2 08-12-2004 22:29
How to Unlock C62 without test point? it's Urgent help plz ... the_frightener NON Siemens Brand (ODM Phones) 4 08-05-2004 07:06
Page generated in 0.22881 seconds with 11 queries
