Motorola P2k A-Series: A630,A668,A728,A732,A768i,A780,A835,A840,A920,A925,A1000,A1200 C-Series: C250,C26x,C33x,C35x,C370,C380,C450,C550,C650,C390,C975,C980 E-Series: E1,E398,E390,E375,E370,E378i,E380,E680,E770,E1000,E680i,E1070 P-Series: P280 T-Series: T280,T720,T721i,T722i V-Series: V60,V66,V7x,V80,V150,V180,V186,V188,V220,V226,V235, V30x,V360,V400,V500,V525,V535,V547,V555,V557,V635,V600,V620,V872, V3,V3x, V3i,V980,V975,V1050. other-Series: like L6,L7,U6. |
10-21-2006, 18:38 | #1 (permalink) |
Junior Member Join Date: Oct 2006
Member: 375397 Status: Offline Thanks Meter: 0 | Motorola E1000 - not working, after simlock modifications Last days I get E1000 to my hands... with simlock. So I turned p2k easy tool 37, then I selected E1000 phone to unlock and ... everything was going ok, then I get some message to disconnect cabel from mobile, and connect it again, then I pressed "ok". After this, my mobile not worked. I get only 0xdab error after I boot it using "#"+"*"+red. After that, I done many probes to fix it, but no result. In the end, I have selected "use TESTPOINT on 3G phones", but I didn't make any modifications on mobile mainboard. And I clicked "do selected jobs". After that operation, telephone is not turning on ! Also when I use "#"+"*"+red it don't working - I don't even get any message and error code! Can somebody tell me what should I do now ? I have only original cabel from motorola, any other things are needed to fix it ? Thank you in advance Regards, thinkbot |
10-26-2006, 22:45 | #4 (permalink) |
Member: 375397 Status: Offline Thanks Meter: 0 | Hello, I had done tespoint then, 1. using RSD Lite 2.5 I had been trying to flash using R26LD_U_83.39.27I_flash+lp0039+k500zm flex.shx but there was error. 2. using p2k_easy_tool I wass trying to flash but : Connecting to phone ... Connected to: 'Motorola Flash' Connected OK Bootloader version: 0310 Sending loader to phone ... Sending second loader to phone ... ERROR: Sending second loader (8) ERROR: Send second loader failed 3. From SmartMoto I get this informations about my phone: S Blank Rainbow POG And when I try to flash it I get: ERROR: Incompatible superfile for Subscriber Unit state. ERROR: The superfile selected is for reflash. You must use a rom superfile with blank Subscriber Units. Meybe I use wrong flash file ? which one should I use ? Could you help me ? Thank you very much ! Regards, thinkbot |
n96 not powered after simlock repair | M_ABRISHAMI | Nokia Base Band 5 ( BB-5 ) | 4 | 01-11-2010 08:33 |
F480v touch screen doesn't work after simlock removal | DarkDemon | QUALCOMM Models (3G) | 0 | 03-21-2009 15:35 |
2600c keypad not work up key,downkey,optionskey,cencelkey not work after change ic. | lavkey | Nokia Hardware & Hardware Repair | 1 | 08-08-2008 16:52 |
Motorola v975 not work keypad after flashing | zeel_zeel | Smart-Clip | 4 | 05-22-2008 17:47 |
motorola v975 not work keypad after flashing | raltelefonica | Motorola P2k | 0 | 01-05-2007 21:42 |
