Motorola P2k A-Series: A630,A668,A728,A732,A768i,A780,A835,A840,A920,A925,A1000,A1200 C-Series: C250,C26x,C33x,C35x,C370,C380,C450,C550,C650,C390,C975,C980 E-Series: E1,E398,E390,E375,E370,E378i,E380,E680,E770,E1000,E680i,E1070 P-Series: P280 T-Series: T280,T720,T721i,T722i V-Series: V60,V66,V7x,V80,V150,V180,V186,V188,V220,V226,V235, V30x,V360,V400,V500,V525,V535,V547,V555,V557,V635,V600,V620,V872, V3,V3x, V3i,V980,V975,V1050. other-Series: like L6,L7,U6. |
11-07-2004, 00:34 | #1 (permalink) |
Freak Poster Join Date: Jul 2001 Location: bucharest Age: 47
Member: 5202 Status: Offline Thanks Meter: 7 | Motorola V525 blink solution... Few days ago i got a motorola V525 with this problem.. The phone only blink once when i try to power on (only keypad light) After few giga of flash, triplets and reflash files.. the phone only blink for 20 seconds(this time diplay is power too) and then power off.... Phone enter in test mode, manualy or by keypad and display all information during flash procces...Boot Loader 07.B0, Sw version Not Found, Battery OK USB transfer mode...etc.... I use PST and after flash i don`t get errors... Here are some flashes i use for this phone.. TRIPLETS_G_0B.09.38R_reflash.shx TRIPLETS_G_0B.08.8F9R_RFO_RFDI_image.shx TRIPLETS_G_0B.08.A5R_A_reflash.shx TRIPLETS_G_0B.09.1DR_A1_LP0039_JPG_0B_TRIPLET_04_0 5R_SE6414AXXB10FD_1FF.shx TRIPLETS_G_0B.09.1DR_A1_reflash.shx TRIPLETS_G_0B.09.1DR_A_reflash.shx TRIPLETS_G_0B.09.1DR_VA1_reflash.shx TRIPLETS_G_0B.09.1FR_A1_LP002E_JPG_0B_TRIPLET_04_0 5R_SE7413AXXU110A_1FF.shx TRIPLETS_G_0B.09.45R_reflash.shx and more... I can`t belive there is a hardware problem...the phone is very new...maybe sombody has some ideea about how to repair this phone.... |
11-07-2004, 05:42 | #2 (permalink) |
No Life Poster Join Date: Oct 1999 Location: Hong Kong
Member: 596 Status: Offline Sonork: 100.33096 Thanks Meter: 514 | well yes 90% is the sw problem but sometimes it should be the flash chip damaged for this kind of situation you should try do the old methods like t720 reviving flash it with the full flash file,if you can not get it you can to do it on another simple way write the backup flash by LT48. if above methods not working to you ,you have to change the flash chip good luck. |
11-07-2004, 09:38 | #3 (permalink) | |
Member: 5202 Status: Offline Thanks Meter: 7 | Quote:
For this V525 allready have the test poind but the phone enter in test mode and flashing, so no need to make this... And about LT48, even i found this tool from one friend, from where i can get full flash from working V525?? | |
11-07-2004, 18:42 | #4 (permalink) |
No Life Poster Join Date: Feb 2003 Location: HUR / R.S Age: 39
Member: 21750 Status: Offline Sonork: 100.62509 Thanks Meter: 73 | if u go to flash mdoe and found software version : not found and 99% it's ur proplem so no repair selution for this phone tell now v 56r dead while unlocking and also no selution for unlock this version as i know and now repai selution also |
11-07-2004, 23:10 | #5 (permalink) | |
yes...this is true..) | |
11-11-2004, 11:33 | #6 (permalink) |
Crazy Poster Join Date: Feb 2004 Age: 39
Member: 53969 Status: Offline Thanks Meter: 2 | I can`t belive there is a hardware problem...the phone is very new... that is your answer :your version is very new !!!I have the solution, contact me if you dont solve your problem yet I fix my v525 with the same proble phone work 100& |
12-04-2004, 16:58 | #7 (permalink) |
Member: 21750 Status: Offline Sonork: 100.62509 Thanks Meter: 73 | can u shar the selution if u really have ? i hear there is selution to repair and ofcours it's not hardware proplem sure 1000% |
12-04-2004, 20:19 | #8 (permalink) |
Junior Member Join Date: May 2004 Location: TotalMOTO team :))))))) Age: 48
Member: 65629 Status: Offline Thanks Meter: 0 | hi in this case PDS in you phone corupted - only Motorola and 1 good man can slove this problem flashing not help you - its like TECH zone in alcatel but solution not publik for unlock better use TotalMOTO 1.6.2 - this SW always make backup your PDS and newer kill phones |
v525 blinking | bassmc | Ultima Box Light | 2 | 08-01-2007 00:41 |
v525- blinks for a second | TELE-MEDIA | Motorola P2k | 8 | 03-14-2006 23:39 |
v525 blink repair with FULL flash | blang | Motorola P2k | 0 | 12-10-2004 09:51 |
Convert motorola v525 in motorola v600! chek here! | sergioems | Motorola P2k | 2 | 02-10-2004 19:39 |
Please calculate code for motorola V525 | inox | Phone Unlocking Codes & Maps | 3 | 12-15-2003 22:17 |
