Motorola P2k A-Series: A630,A668,A728,A732,A768i,A780,A835,A840,A920,A925,A1000,A1200 C-Series: C250,C26x,C33x,C35x,C370,C380,C450,C550,C650,C390,C975,C980 E-Series: E1,E398,E390,E375,E370,E378i,E380,E680,E770,E1000,E680i,E1070 P-Series: P280 T-Series: T280,T720,T721i,T722i V-Series: V60,V66,V7x,V80,V150,V180,V186,V188,V220,V226,V235, V30x,V360,V400,V500,V525,V535,V547,V555,V557,V635,V600,V620,V872, V3,V3x, V3i,V980,V975,V1050. other-Series: like L6,L7,U6. |
06-08-2004, 18:00 | #1 (permalink) |
No Life Poster Join Date: Dec 2000 Location: uk
Member: 2899 Status: Offline Thanks Meter: 6 | "problem updating cxxxclip with pony" im trying to update my blue botton clip with pony,when i connect and click on "probe" it says test faild! i followed the provided instructions with no luck,used it on xp and win 98,the results are the same.i even took apart the clip and mesured the voltage between the legs of the connectors which showed 1.69 v.im using a 9 v from a desktop power supply.also when i choose to wrte the new data,it gives me error -14.i also changed the lpt directions with no luck,has any body else had this problem?is there a special trick?any help will be much apreciated. br farry |
06-09-2004, 13:13 | #5 (permalink) |
No Life Poster Join Date: Aug 2002 Location: Romania, The Bla Bla Country Age: 44
Member: 14279 Status: Offline Thanks Meter: 35 | first of all go to www.alexgsm.ro in downloads area u will find update for C blue + pony prog + instructions and settings for pony prog. remember to use win 98 to work with pony prog. if that does not solve your problem drop me an e-mail at [email protected] BR Alinus AlexGSM-Team |
dont update box with update tool1.4 | masterspargo | Multi-Box | 4 | 11-20-2006 19:08 |
