Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Motorola > Motorola P2k
Motorola P2k A-Series: A630,A668,A728,A732,A768i,A780,A835,A840,A920,A925,A1000,A1200
C-Series: C250,C26x,C33x,C35x,C370,C380,C450,C550,C650,C390,C975,C980
E-Series: E1,E398,E390,E375,E370,E378i,E380,E680,E770,E1000,E680i,E1070
P-Series: P280
T-Series: T280,T720,T721i,T722i
V-Series: V60,V66,V7x,V80,V150,V180,V186,V188,V220,V226,V235, V30x,V360,V400,V500,V525,V535,V547,V555,V557,V635,V600,V620,V872, V3,V3x, V3i,V980,V975,V1050.
other-Series: like L6,L7,U6.
Old 08-26-2006, 12:01   #1 (permalink)
Member: 13100
Thanks Meter: 12
pls help E770V dead after unlock with smart
at "Unlock" tab if flash mode fails to start
Searching for phone... found S Blank Rainbow POG, getting test interface... interface not found
Switching to flash mode... OK
Reading phone boot version... 3.10
Sending boot... load error
Warning: Phone may need "Remove RSA" procedure to get unlocked or flashed, check model list at "Unlock" tab if flash mode fails to start
Searching for phone... no phone found
Reading bus width... OK
Reading flash id... unable to retrieve flash id
Reading OTP... error B8
Warning: OTP read failed
Current phone does not correspond model selection
Unlocking phone... error AE
Old 08-26-2006, 13:59   #2 (permalink)
c_ahmad79's Avatar
Member: 221603
Sonork: 100.1581270
Thanks Meter: 6,395
unlock it again...............but this is recomended that you make backup b4 unlock............ unlock it again
Old 08-26-2006, 15:16   #3 (permalink)
Member: 295985
you must remove RSA before unlock....
Old 08-27-2006, 19:50   #4 (permalink)
Member: 13100
Thanks Meter: 12
this phone completly dead. can connect only with TP.
Old 08-27-2006, 22:42   #5 (permalink)
Member: 295985
what bootloader screen is?
Old 08-28-2006, 15:57   #6 (permalink)
Member: 313784
what is RSA, pls tell how to remove it
Old 08-28-2006, 16:27   #7 (permalink)
.:VodaFone:.'s Avatar
Member: 194868
Thanks Meter: 26
No need to unlock RSA, please check your testpoint try to unlock it again.
MSS4 is good solution for you now.
Good luck.
Old 08-30-2006, 11:10   #8 (permalink)
Member: 13100
Thanks Meter: 12
How much for MSS4 and where to get that
Old 08-30-2006, 12:22   #9 (permalink)
Member: 194868
Thanks Meter: 26
Check this:
http://www.em-5.org/product.asp?id=423
[IMG] code is Off
PLs help w300 dead after unlock with se-tool YasinŽ Sony Ericsson 2 06-07-2007 16:51
pls help E770V dead after unlock with smart rolko_mobile Motorola P2k 1 08-26-2006 12:59
l6 dead after unlock with smart moto 'testpoint' dexter2 Motorola P2k 9 07-31-2006 11:33
L6 Dead after Unlocking with Smart Moto " PHONE CODE SIG ERROR " Aamir_Zia Smart-Clip 53 06-13-2006 19:27
Need Help V975 Dead After Unlocking With Smart Clip ::.::SOUFIZ GSM::.:: Motorola P2k 13 09-04-2005 17:01
Page generated in 0.19531 seconds with 9 queries
