Motorola P2k A-Series: A630,A668,A728,A732,A768i,A780,A835,A840,A920,A925,A1000,A1200 C-Series: C250,C26x,C33x,C35x,C370,C380,C450,C550,C650,C390,C975,C980 E-Series: E1,E398,E390,E375,E370,E378i,E380,E680,E770,E1000,E680i,E1070 P-Series: P280 T-Series: T280,T720,T721i,T722i V-Series: V60,V66,V7x,V80,V150,V180,V186,V188,V220,V226,V235, V30x,V360,V400,V500,V525,V535,V547,V555,V557,V635,V600,V620,V872, V3,V3x, V3i,V980,V975,V1050. other-Series: like L6,L7,U6. |
07-10-2004, 00:53 | #1 (permalink) |
Freak Poster Join Date: May 2002 Location: tunisia Age: 64
Member: 12001 Status: Offline Thanks Meter: 3 | Problem Connecting T720 But Flash Mode Ok i have T720, i can enter it in flash mode by shorting Pin13 and 14 or by pressing *# and power but i can't connect with this mobile in order to flex it. the phone actually light only. when i disconnect this phone and connect a C350, i can connect normally but with T720 i can't connect, the response is : usb device not found. with flash mode, Ok i flashed it normally. problem for me is driver, please help BR |
07-10-2004, 22:39 | #2 (permalink) |
Junior Member Join Date: Jun 2004 Age: 56
Member: 70434 Status: Offline Thanks Meter: 0 | If you're using VictorGSM soft, first look on the "flashing module" tab...down at the bottom, you have to hit the "search" button (i do believe you have to have a flash file loaded to search for the device). It should find a "Motorola P2K device" ...don't flash. Go to the "Other Functions" tab and browse for flex file...then flex. If you're using PST Multiflashflex, use the "show devices" button...it should show up as "Motorola P2K device" in the lower list. You should have the P2k drivers...usually found at : MotClub Hope this helps... --crowbarr-- |
07-11-2004, 00:19 | #3 (permalink) |
Member: 12001 Status: Offline Thanks Meter: 3 | I Use Victor 352 Cracked THANKS FOR RESPONSE, i connected succesfully the T720 in flash mode with shorting PIN13 and 14 or with *# and power, in flash mode the phone connect, browse for file, search, phone connected, and flash succesfully, and the phone work without display, i can make a call normally, but when i want to flex it, the response is : NO DEVICE WERE FOUND ON USB PORT, I got today another phone T720 with the same problem, and there is no connection in normal mode but in flash OK. i flashed my phone with : T720_G_05.05.015R_full_flash.vfl and T720_G_05.05.21R_full_flash.vfl in order to flex it, i can't connect, i thing problem is in USB driver because in configuration pannel, the PC not recognize the phone. please help, thanks BR |
07-11-2004, 02:21 | #4 (permalink) |
Member: 70434 Status: Offline Thanks Meter: 0 | You could try to install the motorola USB file, which is also found at the link I posted. As far as the flash and flex, I have had the phone be kind of picky about connecting after the T720_G_05.05.15R flash...remember to remove the battery for 30 seconds, turn on the phone (you may have do hold down the power button) and wait 2 minutes (for the phone to rebuild the FDI) before flashing with the T720_G_05.05.21_full_flash. |
07-11-2004, 14:12 | #6 (permalink) |
Member: 12001 Status: Offline Thanks Meter: 3 | @ crowbarr The USB files and drivers are installed good because i can connect and a C350 normally without problem. I will try another time for waiting 2 minutes after flashing the first flash. @ Hakima serial cable, i haven't schematics, i use an USB cable as following : PIN1 --- GND PIN2 ---R22k --- GND PIN3 --- +6V (not used) PIN4 --- Tx PIN5 --- Rx PIN6 --- VBUS PIN10 --- GND I notice here that Bruce pinout is inverted in the USB connector so, Pinout USB Connector that i use |--------------| | o o o o | |--------------| GND Tx Rx VBUS Pinout USB Connector of Bruce |--------------| | o o o o | |--------------| VBUS Rx Tx VBUS please can some one verify this USB Pinout and give shematics of serial cable? thanks BR |
07-12-2004, 00:15 | #8 (permalink) |
Member: 70434 Status: Offline Thanks Meter: 0 | Try reading thru this thread...I had similar problems with mine. This got me through. Make sure that the two pionts you are shorting on the USB cable are 13 & 14, else it won't work. If you hit points 14 & 15, the display will flicker blue on and off...that's kind of how I identify my points (they are so small). I'll be keeping my eye on the forums this evening...post back and let me know. http://forum.gsmhosting.com/vbb/show...&highlight=720 |
07-12-2004, 10:21 | #9 (permalink) |
Junior Member Join Date: Jul 2004
Member: 72481 Status: Offline Thanks Meter: 0 | Same problem I don't think u guys r understanding him correctly, as I am having the same problem he is. The problem is not getting it into flash mode by shorting 13 and 14, the problem is flexing it after flashing T720_G_05.05.15R and then T720_G_05.05.21_full_flash. I also waited the full 2 min for FDI rebuild after the first flash. What we are saying is that u can't flex the phone with it in flash mode. At least I can't and I've read elsewhere that other people can't either. When I restart after the last flash the phone won't stay on long enough for it to be recognized. If I hold down the power button for about 5 or 6 seconds it stays in blue screen but I can write display, wap, eeprom content, and logos, but when flexing the phone it stalls out after a few secs and then says Timeout while waiting for response. Flexing it is the last step in one of the repair threads and it's not working, and all other methods of flexing through other progs has had the same results. Any ideas? could there be something we r missing? |
07-12-2004, 12:40 | #10 (permalink) |
Member: 70434 Status: Offline Thanks Meter: 0 | I know that the phone can be stubborn going to flex after the first two flashes. If you don't un-short 13 & 14, you'll get an "Error initializing TCI". Want you're saying, from what I gather, is that the software is having trouble actually communicating with the phone. Youll have to check in your device manager and make sure that all of the Motorola devices are listed and functioning. Mine would start to flex, and then drop out...watched it happen in device manager. If you can't get it recognized this way, you would be better off to get the serial cable. USB can be a bear. |
07-12-2004, 21:11 | #12 (permalink) |
Member: 12001 Status: Offline Thanks Meter: 3 | problem solved many thanks for all responses, my problem is in USB driver, some keys in registry must be modified, i did modified these lignes in the registry but my case is that i have many similar lignes in the registry because i installed many drivers so perhaps there are conflit betweene them, i removed all keys under USB directory in the registry, rebooted, installed PST well, modified these lignes and all is OK. I followed the post of "KaBLooMz", thanks for him this is the lignes that i followed : Step 3 click start/Run typed regedit Step 4 open Hkey_Local_Machine\System\controlSet\Enum\USB right click USB folder click permissions.. under everyone look for permissions for everyone window tick allow for full control and Read. Step 5 After that you need to look under USB tag (registry) for folders like Vid_xxx&Pid_xxxx expand it look and click 5&28f8fc34&0&1 folder look for Service REG_SZ usbccgp and modify to usbhub . **Note the 5&28f8fc34&0&1 folder may be different depending on if you have your phone installed using differet USB port and more but never the less you want modify the tag for which ever ONE has the control folder, we don't modify this folder until the next step . The one with the control folder is the one you want to modify. This step is critical and if you don't do it nothing else after this step will work. You will know when you found the folder because it will have in it the Motorola USB Modem or something to that effect but it will have Motorola.** (okay here is where I got really lost, could not find Service REG_SZ usbccgp, i even did Find command for that string, no luck. So I Skipped to the end and used Alternate Method) Step 6 Inside the branch, that we were just working with, is the folder, with the name "Control", in it is the parameter " ActiveService " - we change its value to usbhub. Step 7 Exit out of the registry here is post : http://forum.gsmhosting.com/vbb/showthread.php?t=130383 thanks again BR |
07-12-2004, 22:01 | #13 (permalink) |
Member: 12001 Status: Offline Thanks Meter: 3 | another problem !! actually i have T720i with flash version : T720PM_G_05.20.09R flex version : SE5360AXXH111C-F.O.O.U.I.P.1 i can make a call normally but no display, i flashed it with many flashes and with flexs but always no display, please what can i do ? thanks. i ask else if this is display problem not software. BR |
07-13-2004, 12:24 | #15 (permalink) |
Member: 72481 Status: Offline Thanks Meter: 0 | looks like he's doing better than me. I can't even make a call. Still can't get it to accept a flex file of any kind but did get display, wap, bat, and eeprom content loaded without a prob. I'm using the radio shack cable so I don't know if that makes a diff. I'm gonna try to mod it later today to a full usb cable to see if it's the usb to serial chip in the middle of the cable that's not letting me hook up with flex. Weird though how I can do everything but flex this phone using this cable. |
E51 nokia blink then set off,but local mode ok. | ck.sufail | Nokia Base Band 5 ( BB-5 ) | 4 | 03-21-2010 21:38 |
1200 ,1208,1209 no power on with bettary But Normal mode ok | Dooha_Bd | Nokia Hardware & Hardware Repair | 8 | 02-12-2010 21:09 |
6300 Contact Service but Normal Mode OK | golam_maula | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 14 | 02-10-2010 19:12 |
i have problem with T630 i flashed it ok but now network come 5 second | gsm4libya | Cruiser Suite | 16 | 03-23-2006 06:04 |
C100 Dead But Test Mode OK | s1emens | Samsung Hardware Repair | 12 | 02-23-2005 16:43 |
