Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Motorola > Motorola P2k
Motorola P2k A-Series: A630,A668,A728,A732,A768i,A780,A835,A840,A920,A925,A1000,A1200
C-Series: C250,C26x,C33x,C35x,C370,C380,C450,C550,C650,C390,C975,C980
E-Series: E1,E398,E390,E375,E370,E378i,E380,E680,E770,E1000,E680i,E1070
P-Series: P280
T-Series: T280,T720,T721i,T722i
V-Series: V60,V66,V7x,V80,V150,V180,V186,V188,V220,V226,V235, V30x,V360,V400,V500,V525,V535,V547,V555,V557,V635,V600,V620,V872, V3,V3x, V3i,V980,V975,V1050.
other-Series: like L6,L7,U6.
Old 08-03-2007, 20:17   #1 (permalink)
Member: 538098
Thanks Meter: 14
smart usb driver problems - Please help!
Hi ive been using Smart clip for years but only just recently started using Smart moto after i got Scard
The problem im having is ive just bought the cable for the w220 (T191) and it needs to be assigned a com port but my computers having trouble installing it.
i have tried different drivers from different sites but nothing seems to work!
Also i may have installed it wrong the time so is there a way i can completly remove and start from scratch!
All help much appreciated
Thanks
Old 08-05-2007, 14:48   #2 (permalink)
Member: 538098
Thanks Meter: 14
Bump
sorry but i really need the help
Old 08-05-2007, 19:11   #3 (permalink)
Member: 390137
Thanks Meter: 28
Thanks
What type of cable are you using?? if you are using just a serial cable you don't need to install any drivers nor configure any port but if your computer doesn't have serial port and if you're installing a usb to serial cable then you need to install the usb to serial cable drivers (most models use prolific drivers) when you finish to install it, you can go to control panel/ system/ hardware/ device manager/ expand Ports (com&lpt) menu, double click in serial cable com port location port settings/ advanced/ and change the COM port number to desired number then ok and done
Old 08-06-2007, 12:58   #4 (permalink)
Member: 538098
Thanks Meter: 14
hi mate im using the usb cable and i have found lots of different drivers out there but none of them seem to work or i might be doing something wrong
I am trying to get hold of the serial cable but i need the USB one installing ASAP to unlock some phone i have lying round
Ill try and find the prolific drivers but if you have them can you post the link here please or help with any other information
[IMG] code is Off
E1080 usb drivers needed please help??????? yassinek85 UST Pro II 0 02-09-2010 19:40
USB driver problems with smart! Please help! tiggy49 Smart-Clip 2 08-04-2007 16:44
Help! Smart USB Driver installation fox1 SonyEricsson (USB-Smart) 1 09-28-2005 05:44
Page generated in 0.21984 seconds with 8 queries
