Motorola P2k A-Series: A630,A668,A728,A732,A768i,A780,A835,A840,A920,A925,A1000,A1200 C-Series: C250,C26x,C33x,C35x,C370,C380,C450,C550,C650,C390,C975,C980 E-Series: E1,E398,E390,E375,E370,E378i,E380,E680,E770,E1000,E680i,E1070 P-Series: P280 T-Series: T280,T720,T721i,T722i V-Series: V60,V66,V7x,V80,V150,V180,V186,V188,V220,V226,V235, V30x,V360,V400,V500,V525,V535,V547,V555,V557,V635,V600,V620,V872, V3,V3x, V3i,V980,V975,V1050. other-Series: like L6,L7,U6. |
10-17-2008, 22:12 | #1 (permalink) |
Freak Poster Join Date: Mar 2007
Member: 474339 Status: Offline Thanks Meter: 44 | Solution motorola v957 at command error 1- the set has user code in it so sclip generates this error. to solve this put that sim to wich it is locked. now fone will ask the code. connect it with sclip and pres the unlock button. try it 3 or more times so that the sclip can try for success. disconnect the fone and put out battery. put the battery again and turn on. when fone asks for user code press menu button.it will ask u security code. now enter 000000 fone will turn on connect it with smart clip and read it sclip will show u the info ...sec code etc. now reset it totaly..as master reset, master clear. now turn off it. put the sim out unlock as normal.. goood luck.. |
Motorola with AT command? | GekoCH | Motorola ODM | 0 | 08-14-2008 18:54 |
Motorola E770 AT command error | shaheen15 | Smart-Clip | 4 | 04-24-2008 20:26 |
Motorola c139 AT commands-problem | 4Tomanek | Motorola ODM | 2 | 12-19-2006 19:20 |
AT Command error Solution | kava | Smart-Clip | 0 | 05-24-2006 12:21 |
AT commande error on versin 2.15 | HEADMASTER | Smart-Clip | 4 | 07-19-2005 14:06 |
