Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Motorola > P2k Series
P2k Series A-Series: A630,A668,A728,A732,A768i,A780,A835,A840,A920,A925,A1000,A1200
C-Series: C250,C26x,C33x,C35x,C370,C380,C450,C550,C650,C390,C975,C980
E-Series: E1,E398,E390,E375,E370,E378i,E380,E680,E770,E1000,E680i,E1070
P-Series: P280
T-Series: T280,T720,T721i,T722i
V-Series: V60,V66,V7x,V80,V150,V180,V186,V188,V220,V226,V235, V30x,V360,V400,V500,V525,V535,V547,V555,V557,V635,V600,V620,V872, V3,V3x, V3i,V980,V975,V1050.
other-Series: like L6,L7,U6.
Old 06-14-2006, 07:45   #1 (permalink)
..::Thanh_gsm::..'s Avatar
Member: 207400
Sonork: 100.1582556
Two E398 dead, both of them have the same problem!!!! Pls help me
I received two e398 two days ago ( die after upgrade to E1), both of them have the same problem.
They can't power on and when I go bootloader both of them say : battery low, can't program. I used smart clip with moto normal cable to repair pds and flash full but result is the same. could'n change anything on my phone.
After that I tried to use force cable, it's great. I can repair and flash full them but only thing is: I can only turn on phone when use force cable and can't power phone if i use normal battery or use external power (bootloader still inform battery low, can't program).
Any one can help me, pls post.
Best & regards
Old 06-14-2006, 08:02   #2 (permalink)
seth_ro's Avatar
Member: 188359
well, you have to charge the battery, or use a power supply and give the phone 4V and then flash it.
I recommend using the monsterpack found here if you want to convert it to E1 and have lots of new features.
Good luck!
Old 06-14-2006, 08:52   #3 (permalink)
Member: 207400
Sonork: 100.1582556
I said I used external power supply bro. But when i used external power supply I can repair, can flash with smartclip but nothing change. In bootloader still old version (even I've flashed new version and new bootloader) and notice battery low.
It's so strange that, when I use force cable all thing is ok, but when use nomar power supply such as battery or external power supply phone can't turn it on and notice battery low in bootloader.
Old 10-09-2006, 00:22   #4 (permalink)
Member: 27956
have you tryed with TP?
Old 10-09-2006, 04:39   #5 (permalink)
Registered User
Member: 297999
flash this file http://da-daemon.mylivepage.ru/file/...42_for_all.rar
this is programm http://da-daemon.mylivepage.ru/files...%20cracked.rar
Old flash monsterpack.
[IMG] code is Off
1108 local mode i will remove two coments but same problem please help me prakash40 Nokia Hardware & Hardware-Repair Area 0 09-29-2009 07:32
I have 6230i network Problem pls help Me minihack Nokia Hardware & Hardware-Repair Area 5 05-20-2008 18:26
i have 2600 big problem pls help me moorthy Nokia Hardware & Hardware-Repair Area 1 12-14-2007 10:46
I have the same problem DupleX Sony 2 05-08-2002 23:36
I have seen hundreds of Nok3210 with the same problems! let's discuss it! sat Nokia Hardware & Hardware-Repair Area 16 10-14-2001 21:27
Page generated in 0.38747 seconds with 11 queries
