Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Motorola > P2k Series
P2k Series A-Series: A630,A668,A728,A732,A768i,A780,A835,A840,A920,A925,A1000,A1200
C-Series: C250,C26x,C33x,C35x,C370,C380,C450,C550,C650,C390,C975,C980
E-Series: E1,E398,E390,E375,E370,E378i,E380,E680,E770,E1000,E680i,E1070
P-Series: P280
T-Series: T280,T720,T721i,T722i
V-Series: V60,V66,V7x,V80,V150,V180,V186,V188,V220,V226,V235, V30x,V360,V400,V500,V525,V535,V547,V555,V557,V635,V600,V620,V872, V3,V3x, V3i,V980,V975,V1050.
other-Series: like L6,L7,U6.
Old 06-02-2009, 01:17   #31 (permalink)
strangerboy's Avatar
Member: 3783
tested in 3 z8 phones from portuguese operator none of them ask code when you turn on ....with these method you can unlock phone without keypad solution.100% working solution thks friends
The Following User Says Thank You to strangerboy For This Useful Post:
Old 06-02-2009, 06:59   #32 (permalink)
dannyogolo's Avatar
Member: 18200
Sonork: 100.1608286
Me too.
Worked for me.
Thanks
Old 06-07-2009, 21:33   #33 (permalink)
Member: 703622
pls_?
pls somebody help me
im try but i cant make
i've mtorola a1000
not see sim card the phone screen write invalid usim contact customer sevicesemr.calls only_?
Old 06-07-2009, 21:56   #34 (permalink)
jawad8305's Avatar
Member: 198621
Sonork: 100.1591649
let it powered on for 2h to 24h ,message will disappear then you can enter the code
Old 06-13-2009, 02:06   #35 (permalink)
Member: 610991
I just ran accross this thread and I wanted to help. For those with a V3xxR, the USB setting should actually be Settings>USB>M-Link USB Driver instead of Settings>USB>GNPO USB Driver:
http://img196.imageshack.us/img196/8281/unlock.jpg
The Following 2 Users Say Thank You to phrotac For This Useful Post:
Old 06-15-2009, 19:20   #36 (permalink)
Member: 223859
Originally Posted by jawad8305 View Post
Now you will be able to unlock your new phones by imei with the help of Radiocomm software:
-Download the soft (new version) from HERE
-Connect the phone, then open radiocomm, make sure it is in GSM mode (Main>MA>GSM) After you have done that go to Settings>USB>GNPO USB Driver, then connect the phone, while making sure no other motorola phone programs are open. The Circle in the top should change to magenta from the red, if not then try doing it again with the phone plugged in.
After you have established a connection with Radiocomm, Click on the GSM 3 Tab at the top, then go down to where it says SBDY_LCK, choose 00-Get status and then click execute, if you get a 00 that means your phone is unlocked, 01 meaning it is locked.
Now to unlock your phone all what you have to do is just enter the 16 numbers code in the box and press execute in the upper side of the screen, must appear that subsidy code is done.
http://img156.imageshack.us/img156/6418/rcv8.jpg
NOW ALL WHAT YOU NEED IS BUY CODE FROM A SERVER
Thank you very useful information friend.
*** bless
Thanks Work solution
Old 06-16-2009, 01:25   #37 (permalink)
jawad8305's Avatar
Member: 198621
Sonork: 100.1591649
Originally Posted by americantel View Post
codes can be purchased for these models here:
http://www.unlockbase.com/?aff=54
What that's mean ? we are not in sales section !next time post in correct section
For ALL here's all trusted servers,go here: http://forum.gsmhosting.com/vbb/f265/
Old 06-19-2009, 00:17   #38 (permalink)
tito millo's Avatar
Member: 390642
Sonork: 100.1573430
I successfully unlocked a Moto V3xxr from at&t with boot 7.00 now my customer is happy and i earned some money.
Br,
Tito Millo
The Following User Says Thank You to tito millo For This Useful Post:
Old 06-20-2009, 04:08   #39 (permalink)
BouRRi_GSM's Avatar
Member: 111457
That's applicable on versions which need 8digit codes
Phones need 16digit codes are different story
If you already received one of the new versions, you will see that when you insert the wrong simcard the phone freezes @ the moto logo, when it works if you insert the correct sim,so we can't enter the code to unlock them.
Enjoy!
K1s Red also ask for 16 digit code, but not hang with other sim.
and after some wrong code, it will be in contact provider, so just wait about 42mn like old p2k., then u will be able to enter 16 digits unlock code.
Originally Posted by dannyogolo View Post
by 16 Digit, do you mean 2 x 8 digit codes ?
The code I got is 8 digits in 2 places
Do I combne them to get 16 ?
this mean u got a wrong code or incomplete code, u must get it from provider not from Motorola factory code.
for Motorola V9 who asking for 16 digits code, tape c 073887*, select NCK, enter unlock code. and maybe work also with other new moto with same problem.
NB: there is also differents security for phone who asking for 16 digilts code.
some like K1s Red (16 digit),
some like V9 (16 digits) (most of them) work with this c 073887*
some other V9 (16 digits) who don't work with previous way.
and maybe more
br
The Following 2 Users Say Thank You to BouRRi_GSM For This Useful Post:
Old 06-27-2009, 18:29   #40 (permalink)
Member: 780076
this is a free solution i want to unlock my v8 2gb
Old 07-01-2009, 21:50   #41 (permalink)
Member: 206939
ined for unlock motorola z8?
how toi entr code pleas help mi........
Old 07-01-2009, 22:01   #42 (permalink)
GSM-XPERTS's Avatar
Member: 1001830
Sonork: 100.1627763
Now these days server is not gives right codes.. It gives wrong codes
Old 07-20-2009, 21:43   #43 (permalink)
gopalhot's Avatar
Member: 149032
I need cradite.its working?
Old 07-20-2009, 23:21   #44 (permalink)
GSMman187's Avatar
Member: 917893
Sonork: 100.1584763
WRONG MAN,.,
IT DEPENDS WHICH SERVER YOU USE
send to me i unlock it for you.
test this service it will work
www.unlocker.com.au
Old 07-22-2009, 02:45   #45 (permalink)
Member: 1079936
which one is the 16 digital code?
TC send Header ? or
TC receive header?
i tried both but they arent work.
[IMG] code is Off
Maybe one day unimoto support new motorola phone v550 Slavonac UniMoto 2 03-29-2005 07:14
NEW: MSS_40 -> Unlock new V550, E550 A1000 and other new Motorola phones... Spalato Main Sales Section 0 12-27-2004 11:18
Here you can find reall pinouts for new Motorola phones (V66,V60...) VictorGSM P2k Series 2 11-27-2001 21:07
About new motorola phones..... ReZn0r Old Legacy Motorola (EMMI) 8 07-21-2001 14:30
Page generated in 0.49784 seconds with 12 queries
