Motorola P2k A-Series: A630,A668,A728,A732,A768i,A780,A835,A840,A920,A925,A1000,A1200 C-Series: C250,C26x,C33x,C35x,C370,C380,C450,C550,C650,C390,C975,C980 E-Series: E1,E398,E390,E375,E370,E378i,E380,E680,E770,E1000,E680i,E1070 P-Series: P280 T-Series: T280,T720,T721i,T722i V-Series: V60,V66,V7x,V80,V150,V180,V186,V188,V220,V226,V235, V30x,V360,V400,V500,V525,V535,V547,V555,V557,V635,V600,V620,V872, V3,V3x, V3i,V980,V975,V1050. other-Series: like L6,L7,U6. |
02-21-2006, 11:56 | #1 (permalink) |
Crazy Poster Join Date: Dec 2004 Location: UK Age: 44
Member: 102029 Status: Offline Thanks Meter: 0 | V3 Dead Wont Flash or anything !!!!!!help :-( now it will only go into flashmode, but it will not flash and i get this error message :RDL SIG ERROR:39:02 what can i do to bring back to life. p.s when i try to switch it on i just get flasing keypad and also in flashmode this is how it shows to start off with then i get error when try to flash .. <<<<<<:::::::PLEASE HELP:::::::>>>>>> Boot Loader 08.26 SW Version: Not Found OK to Program USB Transfer Mode |
02-24-2006, 06:03 | #4 (permalink) | |
Insane Poster Join Date: Apr 2005 Age: 45
Member: 141287 Status: Offline Thanks Meter: 5 | Quote:
02-25-2006, 00:40 | #5 (permalink) |
Member: 102029 Status: Offline Thanks Meter: 0 | [email protected] .thanks add me asap. i have tried alot of 08.26 files E.G. ******* Packs FlexLash Flex Language Packs MXLP REFLASH MLP AND REFLASH so none of the above will bring the phone back to life.i can now flash the phone but still no switch on. |
03-01-2006, 17:19 | #9 (permalink) | |
No Life Poster Join Date: Jul 2005 Location: Pakistan Age: 36
Member: 158181 Status: Offline Thanks Meter: 113 | Play Quote:
NOW PLY CONTINUSELY WITH V3 | |
03-01-2006, 17:34 | #10 (permalink) |
No Life Poster Join Date: Apr 2001 Location: รำมว&#
Member: 3956 Status: Offline Sonork: galletto3 rules :D Thanks Meter: 55 | hi bootloader is damaged, overwrite it with 8.26 version, after that reflash the phone with ******* pack you will need to do test point for this, best regards Invisible |
03-02-2006, 12:22 | #12 (permalink) |
Freak Poster Join Date: Sep 2001 Location: Estonia Age: 46
Member: 6208 Status: Offline Thanks Meter: 12 | I had same problem. Flashed with wrong software. Nothing helped. After that, opened phone and soldered one wire...test point... NO SPECIAL CABLE! Using test point and Smartclip fixed to life again |
v3 dead after flash | klodi | Smart-Clip | 30 | 09-03-2007 07:14 |
V3 dead afer flash | ChinaMobile | Smart-Clip | 11 | 11-09-2006 10:09 |
problems flashing or anything with e720 | scooterist007 | Samsung Flashers, Software, Firmware. | 0 | 07-12-2006 20:01 |
Motorola V3 dead after flash mss4 ...!!!! | Nestor7 | Motorola P2k | 11 | 04-19-2005 10:04 |
