Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Motorola > Motorola P2k
Motorola P2k A-Series: A630,A668,A728,A732,A768i,A780,A835,A840,A920,A925,A1000,A1200
C-Series: C250,C26x,C33x,C35x,C370,C380,C450,C550,C650,C390,C975,C980
E-Series: E1,E398,E390,E375,E370,E378i,E380,E680,E770,E1000,E680i,E1070
P-Series: P280
T-Series: T280,T720,T721i,T722i
V-Series: V60,V66,V7x,V80,V150,V180,V186,V188,V220,V226,V235, V30x,V360,V400,V500,V525,V535,V547,V555,V557,V635,V600,V620,V872, V3,V3x, V3i,V980,V975,V1050.
other-Series: like L6,L7,U6.
Old 03-28-2006, 19:38   #1 (permalink)
DREAMGSM's Avatar
Member: 3377
V3 language changed to chinesse canīt acces to phone book
Iīve changed the language pack to traditional chinesse, when i want to acces in the menu to the phonebook nothing happens. If chosse english or automatic language is able to acces to phonebook but not when phone is in chinesse language, Who knows where the problem is located? can anyone give me some information about that?
thx in advance and B/R
Old 03-29-2006, 08:07   #2 (permalink)
Member: 90682
Thanks Meter: 21
Try this! Solution to fix Chinese Phonebook problem
Get Software named "SeemPlayer v2.91"
Download SEEM 0032_0001 (use P2KTools v0.8.6)===>Open SeemPlayer v2.91 ==>Files==>VXX SEEM==>0032_0001.seem==>Open(select the 0032_0001 u downloaded from your V3)==>then Phonebook (Tab)==> CHECK ALL the box inside the Phonebook (Tab)==> Do whatever you like to do==>SAVE==> Upload via P2KTools the SAVED 0032_0001.seem back into your V3.....
I know this works for V600, V525, V300, V3 and I think my E398 too... Good Luck!
Old 03-29-2006, 09:59   #3 (permalink)
DREAMGSM's Avatar
Member: 3377
great! i will try and post result, thx mate!
Old 04-03-2006, 18:23   #4 (permalink)
Member: 238059
There is also an alternative...Go to initial setup and set phone back to english. Then open phonebook...on any contact name...press the menu button (T-Button). Then go setup...SORT BY "SPEED DIAL". Then change back to chinese...then you can open phone book!!
Old 04-04-2006, 09:37   #5 (permalink)
Member: 13748
Thanks Meter: 84
realy a good trick! both of those solutions work fine for me, thx very much! wrote on my repair hints book.
best regards and thx again from spain.
Old 04-04-2006, 09:48   #6 (permalink)
DREAMGSM's Avatar
Member: 3377
thx for all, all working fine. thx very much. people on gsmforum really share and help
best regards from spain.
Old 04-11-2006, 20:24   #7 (permalink)
Member: 19190
Thanks Meter: 28
and how about when type sms in chinese menu, finaly cant sent, it will return to the main menu...!!!
Old 04-12-2006, 10:06   #8 (permalink)
DREAMGSM's Avatar
Member: 3377
really best solution is change language with the same version of phone firmware, or full upgrade. I have no idea how fix ur problem mate, sorry for no helping .
About speed dial i have some troubles but work fine more or less, sometimes phone says "waiting..." and no way to access to phone book or any others menu items. Reinsert batery and all go fine.
b/r
Old 04-16-2006, 20:51   #9 (permalink)
Member: 251358
Use MotoKit fix phoneBook to fix these problem, but don't effect the sound!
http://www.kempsun.com/Motokit
Old 05-13-2007, 19:43   #10 (permalink)
MNGASHNET's Avatar
Member: 78502
Sonork: 100.86270
Thanks Meter: 7
thank for ur trick i try now
Old 05-13-2007, 19:51   #11 (permalink)
MNGASHNET's Avatar
Member: 78502
Sonork: 100.86270
Thanks Meter: 7
thanx man work good i lost 1 hour with flah now ok 15 $ more
[IMG] code is Off
Can anyody help extract phone book from pm file.. stylius Infinity-Box 5 07-21-2009 09:21
can not acces to suppost foufou SonyEricsson (USB-Smart) 3 06-18-2006 04:46
v3 flash to chinese version cannot log in phone book vijaya7668 Motorola P2k 3 04-24-2006 05:26
Where to get LM can read and write phone book 6100,7210 ? billgate Nokia Multimedia 1 03-04-2003 13:23
8210-dead-STOLEN-HOW CAN i READ THE PHONES BOOK? cosmo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 07-04-2001 22:59
Page generated in 0.19270 seconds with 9 queries
