Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Motorola > Motorola P2k
Motorola P2k A-Series: A630,A668,A728,A732,A768i,A780,A835,A840,A920,A925,A1000,A1200
C-Series: C250,C26x,C33x,C35x,C370,C380,C450,C550,C650,C390,C975,C980
E-Series: E1,E398,E390,E375,E370,E378i,E380,E680,E770,E1000,E680i,E1070
P-Series: P280
T-Series: T280,T720,T721i,T722i
V-Series: V60,V66,V7x,V80,V150,V180,V186,V188,V220,V226,V235, V30x,V360,V400,V500,V525,V535,V547,V555,V557,V635,V600,V620,V872, V3,V3x, V3i,V980,V975,V1050.
other-Series: like L6,L7,U6.
Old 08-02-2006, 16:34   #1 (permalink)
celluniversal's Avatar
Member: 139388
Thanks Meter: 97
V3 no display,no display light
V3 no display, no light(only blank dark display)
But keypad light ok
Phone also working good (both incoming and outgoing calls)
What to do i
1)change ribon
OR
2)we have to flash the phone
Needed good advice pls
Old 08-02-2006, 20:34   #2 (permalink)
cellectro's Avatar
Member: 73310
Thanks Meter: 3
check flex toward lcd, if that is ok change lcd,should work
Old 08-02-2006, 22:59   #3 (permalink)
originalgraders's Avatar
Member: 323968
Sonork: 100.114140
Thanks Meter: 24
i think make sure flex is not cracked,
i can help u np.
pm
Old 08-02-2006, 23:20   #4 (permalink)
ABOUSHADY's Avatar
Member: 200717
Sonork: 100.1580056
Thanks Meter: 786
no flex no lcd
i can help u np
contact [email protected]
msn [email protected]
Old 08-03-2006, 00:08   #5 (permalink)
Member: 27463
Thanks Meter: 3
it's little cristal ic by the flat connector on the pcb.
REGARDS
Old 08-03-2006, 05:45   #6 (permalink)
verse1965's Avatar
Member: 56365
Thanks Meter: 28
REGARDS
Do we change it or just reheat etc..?
regards, JOHNNY.
Old 08-03-2006, 06:06   #7 (permalink)
hrkgloballinks's Avatar
Member: 129536
Thanks Meter: 9
most of this problem is from the flex.change the flex it works for me
Old 08-03-2006, 06:21   #8 (permalink)
Member: 139388
Thanks Meter: 97
regards, JOHNNY.
Please explain more i cannot understand or do u have any picture OR
Can u pls come in the messanger
Yahoo:[email protected]
ICQ:244-868-730
Old 08-03-2006, 06:44   #9 (permalink)
Member: 21937
Thanks Meter: 279
o.k listen up.
if you change keypad flex and lcd and still same problem...
it can be 2 problems .
software or hardware from main board.
there is a little crystal IC near mainboard flex conector , rehot it with some flux ... if doesnt help , remove it and make jumper like in this pic.
if doesnt help you need to repair pds and full flash.
my problem got fixed with this jupmer 100% .
you can start with soft if you like ....
good luck
The Following 7 Users Say Thank You to TRABEL For This Useful Post:
Old 08-03-2006, 06:59   #10 (permalink)
c_ahmad79's Avatar
Member: 221603
Sonork: 100.1581270
Thanks Meter: 6,392
this is really good soloution........ i will test it soon.........
Old 08-03-2006, 07:47   #11 (permalink)
Member: 139388
Thanks Meter: 97
For flashing motorola V3 for display problem in Smart clip an seniour poster gaved the what are the flash files to use in smart clip
R374_G_0E.42.07R_A
R374_G_0E.42.08R_A
R374_G_0E.42.0CR
Those files could be used as a solution for the handsets with nonworking internal display after flashing with 9CR version of flash file.)
But i dont have smart clip I am having only usb smart But i dont know which files to select to flash Can anyone know which files to select in usb smart for flashing V3 for display problem
Needed good advice
Old 08-03-2006, 11:28   #12 (permalink)
Member: 139388
Thanks Meter: 97
R374_G_0E.42.07R_A
R374_G_0E.42.08R_A
R374_G_0E.42.0CR
Needed good advice
No reply
WAITING,WAITING
Does any one tried in usb smart????
Old 11-08-2007, 09:04   #13 (permalink)
malta's Avatar
Member: 27289
Thanks Meter: 24
but if that little ic is not in that place and flashed the phone changed the flex and the lcd and still the same problem what will be the solution
Old 11-18-2007, 10:30   #14 (permalink)
GSMJordan's Avatar
Member: 92813
Sonork: 100.1619156
Thanks Meter: 132
Originally Posted by TRABEL View Post
o.k listen up.
good luck
thanx man its work 100% with me
Old 11-18-2007, 11:11   #15 (permalink)
Member: 478257
Thanks Meter: 11
bro change the ribbon flex
[IMG] code is Off
After flash moto v3 no display, only keyboard light ! Unlocker_001 Motorola P2k 17 06-28-2009 12:19
help....v3 no display and display light CHAPRAN Motorola Hardware Repair 2 01-29-2009 09:57
V3 no display, no light amanhalwara Motorola Hardware Repair 0 07-02-2008 10:44
help me pls.... urgent my 6131 no light n display no light WinD_VteC Nokia Hardware & Hardware Repair 3 02-18-2008 09:21
2 Motorola V3 after flash no display and keyb light!!!! midou01 Smart-Clip 18 01-10-2006 16:43
Page generated in 0.44696 seconds with 9 queries
