Motorola P2k A-Series: A630,A668,A728,A732,A768i,A780,A835,A840,A920,A925,A1000,A1200 C-Series: C250,C26x,C33x,C35x,C370,C380,C450,C550,C650,C390,C975,C980 E-Series: E1,E398,E390,E375,E370,E378i,E380,E680,E770,E1000,E680i,E1070 P-Series: P280 T-Series: T280,T720,T721i,T722i V-Series: V60,V66,V7x,V80,V150,V180,V186,V188,V220,V226,V235, V30x,V360,V400,V500,V525,V535,V547,V555,V557,V635,V600,V620,V872, V3,V3x, V3i,V980,V975,V1050. other-Series: like L6,L7,U6. |
04-19-2004, 13:04 | #1 (permalink) |
No Life Poster Join Date: Jul 2000 Location: hiroshima Age: 51
Member: 1756 Status: Offline Thanks Meter: 9 | v300 with blank display phone works, can make/receive calls, but display is white already flashed it and put on it display setting from another v300 any advice is welcome |
04-21-2004, 05:58 | #2 (permalink) | |
Junior Member Join Date: Apr 2004 Age: 33
Member: 62998 Status: Offline Thanks Meter: 0 | Quote:
display cable is probily loose. I had the same prob. Open the back of ur phone, and near the top right side is a cable that leads to the screen. Make sure it is fully in. If this doesn't work, open the blue face of the phone, carefully remove the metal peice that is on top, there are small white latches on the side. After that you should just see the red-brown cables of the screen. To the top right corner there should be a cable that looks alot like the one in the back. Make sure that is all the way in. You can send the phone to me to fix if you want, i live in the seattle area. Please Email me if you want to do that, Hope This Helps! SeSS | |
v3x after unlock with testpoint display in blank | LOUAI2005 | Smart-Clip | 4 | 04-17-2007 16:02 |
v3x after unlock with testpoint display in blank---100% solution is here | makkah mobile | Smart-Clip | 1 | 04-17-2007 11:22 |
>>J200i with Blank Display but Working Perfectly<< | thoyyu | Sony Ericsson Hardware Repair | 8 | 05-31-2006 09:28 |
Blank display in 355 after flash with 350 firmware | Headmade | Philips | 1 | 08-25-2004 16:02 |
