Motorola P2k A-Series: A630,A668,A728,A732,A768i,A780,A835,A840,A920,A925,A1000,A1200 C-Series: C250,C26x,C33x,C35x,C370,C380,C450,C550,C650,C390,C975,C980 E-Series: E1,E398,E390,E375,E370,E378i,E380,E680,E770,E1000,E680i,E1070 P-Series: P280 T-Series: T280,T720,T721i,T722i V-Series: V60,V66,V7x,V80,V150,V180,V186,V188,V220,V226,V235, V30x,V360,V400,V500,V525,V535,V547,V555,V557,V635,V600,V620,V872, V3,V3x, V3i,V980,V975,V1050. other-Series: like L6,L7,U6. |
06-08-2006, 17:09 | #1 (permalink) |
No Life Poster Join Date: May 2003 Location: POLAND
Member: 27761 Status: Offline Thanks Meter: 55 | v360v dead after flash, revive but camera is oposite view i made unlock then i wanted to make polish lang i choose file V360_L7_R4513_BL08D0_LP_2F.lng and lang went into phone. all was OK then i saw that phone has got that s t upid colors from Vodafone and i wanted to debrand it. i used file from support: R4513_G_08.B7.ABR_RB_PDS015_LP0339_DRM0103_JPJAVA_ G_08_L7_06_01_08R_SE5793AXXF4115_1FF.shx i made flash and now phone after power ON just for 2sek lighting keyboard and then going OFF. i tried PDS repair but still same. data from v360v: R4513_G_08.B7.ABR Flex:SE6132AXXB5115 DSP 631F1F00 BOOT 08.D0 *********************************************** i flash with file: R4513_G_08[1].B7.5DR_RB_PDS013_LP0339_DRM0103_JPJAVA_G_08_L7_06 _01_08R_SE5793AXXF40E2_1FF after flash i made PDS repair, phone is working but camera view is oposite (up side down) so i can't make normal photo. please i ithink i need flex file that will repair it (make v360 photo mode, coz now phone is working like L7) and external LCD is not working too. how to fix camera and external LCD? |
06-09-2006, 09:50 | #3 (permalink) |
Member: 27761 Status: Offline Thanks Meter: 55 | i have smart-clip and p2l_easy_tool from usb-smart in usb-smart support section i found files with language for L7 and V360 and i thought that same thing is for full 1FF flash files. please anybody have file for v360 or FLEX to fix camera and lcd? |
06-09-2006, 11:56 | #4 (permalink) |
Freak Poster Join Date: Jul 2004 Location: JATT LABLE Age: 43
Member: 73479 Status: Offline Sonork: 100.1581683 Thanks Meter: 55 | Dead V360v when unlocking Hi, I was unlocking moto V360v with smart clip form vodofone i put the test points and grounded it after it went in to s blank mode removed the test point and in the software of smart moto pressed unlock via test point then what happend is m puting the log read from phone as below > Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.00 Reading flash id... Intel-28F256L18B Reading flash id/2... OK, none Phone group: V360,V360v,V3i,L7,L7v Hardware IMEI: 357395001781908 Security area saved to "S Blank Neptune LTE2 357395001781908.pds" Unlocking phone... error A0 after this the phone lost IMEI i rehoted the mcu the IMEI came back but now the phone is just blinking ................ Then i removed the fone from smart clip ... and put it back i could read the phone.......Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK But now i cant read the phone nothing at all,,,,,,,,,,SmartMoto 1.20 Clip serial: 238318406, version: 2.25, initializing... OK Searching for phone... no phone found................ the phone is showing white screen. Please any one help thanks. |
06-10-2006, 11:21 | #9 (permalink) | |
No Life Poster Join Date: Aug 2001 Location: Roma Age: 49
Member: 5926 Status: Offline Thanks Meter: 275 | Quote:
BR Rak|m | |
06-10-2006, 13:02 | #10 (permalink) | |
Member: 73479 Status: Offline Sonork: 100.1581683 Thanks Meter: 55 | @Raklm Quote:
thanks. | |
06-10-2006, 13:03 | #11 (permalink) | |
thanks. | |
06-10-2006, 14:37 | #12 (permalink) |
Member: 5926 Status: Offline Thanks Meter: 275 | I have for smart-clip if u have it as well u can download it from support I just gave you a hint, with title of "INFO", if this not helps you , sorry but I cant repair your phones for you anyway info was not for you because this aply only for SW problems But of course your problem is HARDWARE so no file will helps you till hw will be ok BR Rak|m Last edited by Raklm; 06-10-2006 at 14:47. |
N72 Camera Flash On But Set Is Dead After Pressing On/off Switch | gsmsoftware77 | Nokia Base Band 5 ( BB-5 ) | 3 | 07-09-2008 18:41 |
v360v dead after flash | ekotek | Smart-Clip | 3 | 12-19-2007 16:42 |
V360v dead after flash. this is not P2K_easy_tool Error just need help | PSG | Motorola P2K (USB-Smart) | 6 | 06-09-2006 17:25 |
v360v dead after read flash with smartmoto | mmanduri | Smart-Clip | 7 | 03-09-2006 08:07 |
v360v dead after read flash with smartmoto | mmanduri | Motorola P2k | 3 | 02-27-2006 15:19 |
