Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Motorola > P2k Series
P2k Series A-Series: A630,A668,A728,A732,A768i,A780,A835,A840,A920,A925,A1000,A1200
C-Series: C250,C26x,C33x,C35x,C370,C380,C450,C550,C650,C390,C975,C980
E-Series: E1,E398,E390,E375,E370,E378i,E380,E680,E770,E1000,E680i,E1070
P-Series: P280
T-Series: T280,T720,T721i,T722i
V-Series: V60,V66,V7x,V80,V150,V180,V186,V188,V220,V226,V235, V30x,V360,V400,V500,V525,V535,V547,V555,V557,V635,V600,V620,V872, V3,V3x, V3i,V980,V975,V1050.
other-Series: like L6,L7,U6.
Old 12-25-2007, 13:28   #1 (permalink)
fethi's Avatar
Member: 57836
V3x lcd black in normal mode, ok in boot mode
hi, V3x works ok, every thing fine, makes calls and recives calls and i can hear the ring of keypad, but the lcd is black and dose not show any thing,
if i enter boot mode, it works, and shows:
boot loader : 0.6.8.2
SW version: R25221LD_U_85.99.50R
What the problem could be ?
any help ?
thanks
The Following User Says Thank You to fethi For This Useful Post:
Old 12-25-2007, 13:48   #2 (permalink)
GSM_Support's Avatar
Member: 121052
Check flex cable or the TP resistor on the PCB.
Best Regards
GSMServer team
The Following User Says Thank You to GSM_Support For This Useful Post:
Old 12-25-2007, 14:47   #3 (permalink)
fethi's Avatar
Member: 57836
TP resistor ok,
and we tried other flex cable, still the same problem
can be flashe ?
Old 12-26-2007, 03:54   #4 (permalink)
Member: 117956
Try rehot small long square ic beside main flexi cable socket at pcb board , good luck !
The Following User Says Thank You to tgcommss For This Useful Post:
Old 09-02-2010, 15:32   #5 (permalink)
mr_loverman's Avatar
Member: 87722
same problem with me did you fix it?
The Following User Says Thank You to mr_loverman For This Useful Post:
Old 09-03-2010, 09:50   #6 (permalink)
Member: 121052
@ mr_loverman,
Do you know what initially had happened to the phone so it got to such state?
If yo use Smart-Clip and SmartMoto, try to perform Repair PDS and after that Full Flash the phone with higher firmware version of the same platform.
Best Regards
GSMServer team
Old 10-01-2010, 10:29   #7 (permalink)
Member: 87722
problem was in garcon
[IMG] code is Off
2300 local mode ok 1st boot error surajnad Nokia Hardware & Hardware-Repair Area 4 06-04-2009 14:26
3315 no display in bright light, ok in darkness chhoton Nokia Hardware & Hardware-Repair Area 3 01-11-2009 19:29
v3x lcd black NARESTAN Motorola Hardware Repair Section 1 09-30-2008 06:04
1600 fleshing ok local mode/test mode ok but normal mode fail zargar322 Nokia Hardware & Hardware-Repair Area 9 03-31-2008 16:22
in normal mode phone is ok ,not in batt akshay Nokia Hardware & Hardware-Repair Area 18 12-04-2005 11:48
Page generated in 0.48176 seconds with 11 queries
