Motorola P2k A-Series: A630,A668,A728,A732,A768i,A780,A835,A840,A920,A925,A1000,A1200 C-Series: C250,C26x,C33x,C35x,C370,C380,C450,C550,C650,C390,C975,C980 E-Series: E1,E398,E390,E375,E370,E378i,E380,E680,E770,E1000,E680i,E1070 P-Series: P280 T-Series: T280,T720,T721i,T722i V-Series: V60,V66,V7x,V80,V150,V180,V186,V188,V220,V226,V235, V30x,V360,V400,V500,V525,V535,V547,V555,V557,V635,V600,V620,V872, V3,V3x, V3i,V980,V975,V1050. other-Series: like L6,L7,U6. |
07-28-2004, 08:24 | #1 (permalink) |
Banned Join Date: Nov 2001 Location: IRAN Age: 38
Member: 7444 Status: Offline Sonork: 100.99999 Thanks Meter: 10,013 | V60 ,,,, Repair! -flashed SAP4_G_01.06.1ER_repair_new_notpacked.vf2 in it. -flashed SAP4HA_G_01.06.1DR_lang000D_full_flash.vfl (V66 flash) in it. then phone is dead! then i did: -flashed it with PHX4_G_01.05.06R_lang000D_full_flash_crypted.vfl but still phone is dead! any idea how to repair this phone? |
07-28-2004, 09:10 | #2 (permalink) |
No Life Poster Join Date: Nov 2001 Location: türkiye Age: 59
Member: 7114 Status: Offline Thanks Meter: 51 | same problem with me ph8 phone goes flash mode and flashing but dead always not powered on I need solution also fdı reclaim not work also because not powered on |
07-28-2004, 15:02 | #3 (permalink) |
Freak Poster Join Date: May 2001 Location: Vietnam
Member: 4769 Status: Offline Thanks Meter: 4 | @VsH Use com cable, switch to repair, if MSS can connect with phone, do following step : - Flash with repair_sap4_g_01_06_1er_full_flash.vfl - Remove battery, then insert battery - Flash with phx4_xx_xx_xxr_langxxxx_full_flash.vfl - Remove battery, insert battery, power phone, at this time your phone only screen light (no text) - Switch cable to normal, flex phone with v60_xxx_core_model_xxx.vhs - Write display file V60_hosiden_display_759.display - Remove battery, insert battery, power on phone, your phone go live now - Use USB cable to change IMEI If you don't have there file, please contact me. Sorry for my English :-) Best regards, |
07-28-2004, 17:30 | #6 (permalink) |
Member: 7114 Status: Offline Thanks Meter: 51 | yes I can flash with victor but not powered on always dead...I can swith flash mode scren bootloader on 10.0i ready to program serial (rs-232) transfer mode also with usb same working flashing mode and I can flash but all flashes ıtry not success |
07-30-2004, 15:34 | #7 (permalink) |
Member: 4769 Status: Offline Thanks Meter: 4 | @ardagul try use usb cable write phx8 full flash, after that try use FDI reclaim tool, if phone can power on with screen light only, use MSS flex with V60i core_flex file, write display file and your phone work right. If not :-), i cant help you. |
07-31-2004, 13:37 | #9 (permalink) |
Member: 4769 Status: Offline Thanks Meter: 4 | After full flash with victor your phone can't power on but can connect with pst, use FDi reclaim tool to recover your phone, after that phone can power on with light only. And do next step :-) |
V60 repair | questman | Motorola P2k | 0 | 07-17-2003 15:52 |
Need V60 repair flash-file urgently! | VendorGSM | Motorola P2k | 5 | 10-14-2002 17:57 |
Motorola V66, V60, V70, T280 SP unlock and IMEI repair clips ready for delivery | Teleway | Main Sales Section | 8 | 06-30-2002 06:51 |
v70,v60,v66,t280 unlock imei repair £10 uk only | t68 | Main Sales Section | 8 | 06-12-2002 04:23 |
