v600 Backlight problem Hi, I have a v600, only about 7months old, which is giving me a lot of problems. The backlight seems to have a mind of it's own, one minute it's working fine the next minute it's either staying on or off for days at a time. I was wondering if anyone knows of a solution or is it just a case of sending it away to get fixed? Thanks in advance |
you can reflash your phone , to correct your phonr error . bestman. |
it probably got wet at the disbplay, open the display part and see the small 5 pin flat cable connector close to the top edge, remove the 5 pin flex cable there and clean contacts. if corroded need to solder fine wire to make contact. good luck. |
