Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Motorola > P2k Series
P2k Series A-Series: A630,A668,A728,A732,A768i,A780,A835,A840,A920,A925,A1000,A1200
C-Series: C250,C26x,C33x,C35x,C370,C380,C450,C550,C650,C390,C975,C980
E-Series: E1,E398,E390,E375,E370,E378i,E380,E680,E770,E1000,E680i,E1070
P-Series: P280
T-Series: T280,T720,T721i,T722i
V-Series: V60,V66,V7x,V80,V150,V180,V186,V188,V220,V226,V235, V30x,V360,V400,V500,V525,V535,V547,V555,V557,V635,V600,V620,V872, V3,V3x, V3i,V980,V975,V1050.
other-Series: like L6,L7,U6.
Old 01-27-2005, 02:53   #1 (permalink)
Member: 106868
v600 Backlight problem
Hi,
I have a v600, only about 7months old, which is giving me a lot of problems. The backlight seems to have a mind of it's own, one minute it's working fine the next minute it's either staying on or off for days at a time.
I was wondering if anyone knows of a solution or is it just a case of sending it away to get fixed?
Thanks in advance
Old 02-06-2005, 10:44   #2 (permalink)
bestman's Avatar
Member: 61294
you can reflash your phone , to correct your phonr error .
bestman.
Old 02-07-2005, 01:16   #3 (permalink)
mrfixit's Avatar
Member: 60899
it probably got wet at the disbplay, open the display part and see the small 5 pin flat cable connector close to the top edge, remove the 5 pin flex cable there and clean contacts. if corroded need to solder fine wire to make contact. good luck.
[IMG] code is Off
GX30 backlight problem Paddy5 Sharp 2 09-13-2004 22:30
t68i flashing backlight problem jensenh1 Sony Ericsson 0 09-07-2003 23:02
GD67 backlight problem Jt Panasonic 1 06-08-2003 19:48
"Cloned" A50 blinking backlight problem AssenBG x1x to x45/x50 13 01-05-2003 07:09
A2618s backlight problems dimka Hardware Repair by brands 3 09-01-2002 07:18
Page generated in 0.28115 seconds with 11 queries
