Z3 Reviving dead phones & Repair PDS(Tutorial) 2 Attachment(s) first thanks to diabolic53 So ... i decided to make this tutorial for those that bricked their phone and cannot flash any firmware and there is nothing else they can do to revive the phone. Keep in mind that this tutorial requires you to make a TEST-POINT on your phone!!! So let's begin: Symptoms :- phone won't turn on , it will only turn on in bootloader - phone shows PH SIG ERR : 35:02 - Flashing any other firmware didn't solve the problem Fixing the problem: 1. Dis-assemble the the phone and make a TP on it 2. Start Ramldr2 and press Send loader 3. Select write boot an select Boot_0AC0_patch, and wait for "Shutting down ... OK" ( after this process the phone will start only in Blankmode ) 3. Start Flash Backup 3 and flash the phone with the "Revive dead flash with RSA & PDS patch" flash 4. Start Ramldr2 again, press Send loader, then press write PDS & select the file "PDS_Z3", after the shutting down close Ramldr2 5. Start Ramldr2 again and press Send loader, then press Write boot and select "Boot_Start_SW", after closing the program remove cable, assemble the phone & that is it your phone is revived WARNING!!! AFTER THIS PROCESS YOU WILL NOT BE ABLE TO FLASH YOUR PHONE WITHOUT TAKING YOUR PHONE INTO BLANKMODE AGAIN !!!( With Dualboot this is just a minor inconvenience) Repair Flash link : Revive dead flash with RSA, Dualboot included & PDS patch by Diabolic53 Boot_0AC0_patch link : http://www.mediafire.com/?2afltigd5fn Ramldr2 link : http://www.mediafire.com/?1cwln1m90zn Boot_Start_SW link : http://www.mediafire.com/?8bwbyznrml9 PDS link : http://www.mediafire.com/?2avgs9yxsnz Testpoint Picture: |
What am I missing HERE I must be doing something wrong as thisis the message I get when I send loader. Switching to flash mode Switching to flash mode Loader sending at addres 03FD0000AD Switching to flash mode USB: IO Time-out! What am I doing wrong, PLEASE advise, I have a sig err and am trying to fix it....I have tried so many things and times, I am not desiring to FOLD on this...THANK U!:( |
OK I finally got it worked OK, and I was back to the phone again, BUT I tried then to flash the phone with my Original Back UP and now all I get is a white screen! When I try to flash again I get this Extracting data from firmware file... Sending the loader... Error! Executing JUMP... Error! Erasing memory... (Progress of this process is not shown) Error! Sending code group: CG1 Error! Sending code group: CG2 Error! Sending code group: CG3 Error! Sending code group: CG4 Error! Sending code group: CG7 Error! Sending code group: CG15 |
did same one test this solution ???? please poste result |
K1 I get the following error , what might cause this? USB: IO Time-out! USB: IO Time-out! Switching to flash mode |
when i connect my z3 pc says One of the usb devices attached to this computer has malfunctioned and windows recognise it.this happened after i flashed it .can it be revived? |
can use this method for z3 boot loader : 0A.C3 |
can use this method for z3 boot loader : 0A.C3 ??????????????? |
welcome to my post beats by dre |
