Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Motorola > Motorola P2k
Motorola P2k A-Series: A630,A668,A728,A732,A768i,A780,A835,A840,A920,A925,A1000,A1200
C-Series: C250,C26x,C33x,C35x,C370,C380,C450,C550,C650,C390,C975,C980
E-Series: E1,E398,E390,E375,E370,E378i,E380,E680,E770,E1000,E680i,E1070
P-Series: P280
T-Series: T280,T720,T721i,T722i
V-Series: V60,V66,V7x,V80,V150,V180,V186,V188,V220,V226,V235, V30x,V360,V400,V500,V525,V535,V547,V555,V557,V635,V600,V620,V872, V3,V3x, V3i,V980,V975,V1050.
other-Series: like L6,L7,U6.
Old 08-21-2008, 16:09   #1 (permalink)
malek45's Avatar
Member: 32529
Thanks Meter: 23
Z3 Reviving dead phones & Repair PDS(Tutorial)
first thanks to diabolic53
So ... i decided to make this tutorial for those that bricked their phone and cannot flash any firmware and there is nothing else they can do to revive the phone.
Keep in mind that this tutorial requires you to make a TEST-POINT on your phone!!!
So let's begin:
Symptoms :- phone won't turn on , it will only turn on in bootloader
- phone shows PH SIG ERR : 35:02
- Flashing any other firmware didn't solve the problem
Fixing the problem:
1. Dis-assemble the the phone and make a TP on it
2. Start Ramldr2 and press Send loader
3. Select write boot an select Boot_0AC0_patch, and wait for "Shutting down ... OK" ( after this process the phone will start only in Blankmode )
3. Start Flash Backup 3 and flash the phone with the "Revive dead flash with RSA & PDS patch" flash
4. Start Ramldr2 again, press Send loader, then press write PDS & select the file "PDS_Z3", after the shutting down close Ramldr2
5. Start Ramldr2 again and press Send loader, then press Write boot and select "Boot_Start_SW", after closing the program remove cable, assemble the phone & that is it your phone is revived
WARNING!!! AFTER THIS PROCESS YOU WILL NOT BE ABLE TO FLASH YOUR PHONE WITHOUT TAKING YOUR PHONE INTO BLANKMODE AGAIN !!!( With Dualboot this is just a minor inconvenience)
Repair Flash link :
Revive dead flash with RSA, Dualboot included & PDS patch by Diabolic53
Boot_0AC0_patch link :
http://www.mediafire.com/?2afltigd5fn
Ramldr2 link :
http://www.mediafire.com/?1cwln1m90zn
Boot_Start_SW link :
http://www.mediafire.com/?8bwbyznrml9
PDS link :
http://www.mediafire.com/?2avgs9yxsnz
Testpoint Picture:
The Following 4 Users Say Thank You to malek45 For This Useful Post:
Old 11-07-2008, 04:24   #2 (permalink)
Member: 450025
Question What am I missing HERE
I must be doing something wrong as thisis the message I get when I send loader.
Switching to flash mode
Loader sending at addres 03FD0000AD
USB: IO Time-out!
What am I doing wrong, PLEASE advise, I have a sig err and am trying to fix it....I have tried so many things and times, I am not desiring to FOLD on this...THANK U!
Old 11-07-2008, 20:43   #3 (permalink)
Member: 450025
OK I finally got it worked OK, and I was back to the phone again, BUT I tried then to flash the phone with my Original Back UP and now all I get is a white screen!
When I try to flash again I get this
Extracting data from firmware file...
Sending the loader...
Error!
Executing JUMP...
Error!
Erasing memory... (Progress of this process is not shown)
Error!
Sending code group: CG1
Error!
Sending code group: CG2
Error!
Sending code group: CG3
Error!
Sending code group: CG4
Error!
Sending code group: CG7
Error!
Sending code group: CG15
Old 01-22-2009, 13:51   #4 (permalink)
RIOPHONE's Avatar
Member: 266765
Sonork: +21624131501
Thanks Meter: 336
did same one test this solution ????
please poste result
Old 02-12-2009, 09:15   #5 (permalink)
Member: 438309
K1
I get the following error , what might cause this?
USB: IO Time-out!
USB: IO Time-out!
Old 03-09-2010, 19:49   #6 (permalink)
Member: 1126425
when i connect my z3 pc says
One of the usb devices attached to this computer has malfunctioned
and windows recognise it.this happened after i flashed it .can it be revived?
Old 04-11-2011, 16:08   #7 (permalink)
Member: 467118
Thanks Meter: 16
can use this method for z3
boot loader : 0A.C3
Old 04-11-2011, 17:48   #8 (permalink)
Member: 467118
Thanks Meter: 16
boot loader : 0A.C3
Old 04-13-2011, 08:20   #9 (permalink)
Member: 1555289
welcome to my post beats by dre
[IMG] code is Off
noox box revive dead phone juceca21 NoooX Box 1 09-30-2008 19:10
Reviving dead phones Gozha SMTi 9 10-14-2007 08:51
lg 8130r full flash needed to revive dead phone jesto80 Sonics Box 9 08-11-2005 01:30
lg 8130r full flash needed to revive dead phone jesto80 Blazer 0 08-07-2005 01:12
BE1 16c/d Flashing - reviving dead phone shamir Alcatel & TCL Old Models 20 12-16-2001 05:11
Page generated in 0.33709 seconds with 9 queries
