Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Motorola > Motorola ODM
Motorola ODM
  • BENQ(Acer): C113,C139,C168,C200,C205,C300,C257,C261, T205,T2688,T190,T191,V171,V290
  • CHIMEI: MPX200, MPX220, MPX300, V690, V878
  • COMPAL: E360, E365, MPX100, C115, C155
  • Reply
    Old 01-22-2008, 03:44   #1 (permalink)
    Member: 567081
    Thanks Meter: 4
    C139 8.8.17 TracFone
    So I was in walmart the other day and saw this phone for $11. I figured I'd pick it up and mess with it. I built a quick serial cable and got it working, but then started reading threads about how these phones can't be unlocked, except with a testpoint and the $350 infinity box. I have done a lot of work with the iPhone and have good reversing skills. I'll post what I've figured out so far; hopefully people can add to this.
    @ 57600 baud, only two at commands appear to work
    at -- echos OK
    at+system=0 -- enter factory mode
    The acer tool factory mode commands work, and I can read out the subsidy code, but the firmware is locked to TracFone.
    @ 115200 baud, the phone prints "ftmtool" then one second later prints "error" I'm sure this is a flasher interface, but when I google "ftmtool", I get nothing at all.
    Does anyone have docs on this phone, or more importantly a flash dump of a 8.8.17 TracFone?
    Old 01-25-2008, 14:12   #2 (permalink)
    Member: 482218
    Thanks Meter: 112
    with acer tool they work like a charm but only reading subsidy codes. u already know about how to do the testpoint, if what u want is a backup of the original 8.8.17 it would be kind a hard without an unlocking box like rockerdongle or infinity so i suggest u get one. i have tryed to make backup with other free tools but no luck, not even with non-tracfone ones. let me know how can i help.
    Old 01-28-2008, 20:30   #3 (permalink)
    Member: 639954
    Is this the George Hotz? I had hoped that some of the expertise being applied to the iPhone problem would cross-over into the realm of GSM unlocking.
    Good luck with the C139 a non-soldering solution would be very helpful. Maybe compare the AT&T version...
    Old 02-23-2008, 05:18   #4 (permalink)
    rudyandremely's Avatar
    Member: 108193
    Thanks Meter: 70
    yes that would be good to unlock this phone with out taking apart the phone cos i have screw up 2 of them the one whit the new pcb 8.8.17. keep trying bro...
    Old 02-24-2008, 01:13   #5 (permalink)
    Member: 567081
    Thanks Meter: 4
    If anyone can get a dump of the 8.8.17 bootcore, could you send it to geohot at gmail
    Old 02-27-2008, 01:54   #6 (permalink)
    un1x's Avatar
    Member: 603495
    Thanks Meter: 28
    i cand send you only a... the COMPLETE FIRMWARE where is locate part of the bootcore you think this help??
    Old 02-27-2008, 03:57   #7 (permalink)
    Member: 280594
    Thanks Meter: 21
    you can unlock that using only software depends on flags
    if flag = 0 OK
    but if flag = 1 u need a testpoint in CPU to unlock
    Old 02-28-2008, 14:49   #8 (permalink)
    un1x's Avatar
    Member: 603495
    Thanks Meter: 28
    if flag = 0 OK
    dude.. sorry but TESTPOINT is not needed any more a solutiom come from VICTOR GSM mssbox2 can unlock ANY 8.8.8.17 whit ANY FLAG 1 OR 0 whit testpoint Cpu
    Old 02-29-2008, 02:50   #9 (permalink)
    Member: 280594
    Thanks Meter: 21
    wrong explanation!
    worst people....
    Old 02-29-2008, 05:24   #10 (permalink)
    Member: 60668
    Thanks Meter: 69
    I have already converted and flash such C139 tracfone unit (v.8.8.8.17) without testpoint, but with new Tracfone NTc139b with same version, i have getting problem, it cannot detect by pc, maybe the bootloader are different, is there anyone succed to flash this Tracfone NTc139b?
    Old 02-29-2008, 16:50   #11 (permalink)
    Member: 482218
    Thanks Meter: 112
    NTC139B is the net10 version i think. as already said MSSBOX2 ODM TOOL is the only one capable skipping testpoint procedure. they dont specify if net10 ones use same method. ill let u know as soon as i can get my hands on one of those.
    Old 03-02-2008, 00:41   #12 (permalink)
    mrfixit's Avatar
    Member: 60899
    Thanks Meter: 778
    flashing of tracfone c139 ok with mssbox2 which will make it a "normal" gsm phone, but received another new version of c139-tf which dont want to connect into flash mode.
    Old 03-02-2008, 00:49   #13 (permalink)
    mrfixit's Avatar
    Member: 60899
    Thanks Meter: 778
    Originally Posted by geohot View Post
    So I was in walmart the other day and saw this phone for $11. I figured I'd ....
    I can send u flash dump from mssbox2 from this one in a short while.
    Old 03-02-2008, 01:24   #14 (permalink)
    Member: 99013
    Thanks Meter: 52
    http://rapidshare.com/files/96314074...8.17.mofw.html
    Old 03-02-2008, 01:49   #15 (permalink)
    mrfixit's Avatar
    Member: 60899
    Thanks Meter: 778
    so c139 is done, now we really need this c168i att "fixed" too, another 20 dollar phone
    [IMG] code is Off
    c139 tracfone 8.8.17 boot problem solved zeerik Infinity-Box 1 08-01-2009 20:13
    c139 version 8.8.17 tracfone a.z Infinity-Box 0 06-09-2007 10:43
    c139 ver. 8.8.17 unlock ??? sygnal Infinity-Box 5 04-16-2007 11:02
    C139 trackphone v. 8.8.17 that doesnīt need TP Plisto Infinity-Box 4 01-13-2007 05:20
    C139 Tracfone with s/w ver 8.8.17...need help flashing pvfjr Motorola ODM 1 12-15-2006 23:38
    Page generated in 0.42311 seconds with 8 queries
