c139 cingular locked version 1.9.24 try this for unlocking c139 sw version 1.9.24 unlock c139 cingular locked ... its hard to unlock and connect c139 cingular locked version 1.9.24 can't connect at direct unlock in smart clip also in infinity unlock or flashing cannot dettect here is the solution http://i160.photobucket.com/albums/t...5062008081.jpg Service Compal v1.00 Procedure: 1. Activate modem by pressing **16379# 2. Connect cable to phone 3. Select Comport 4. Press Connect 5. Press Code Subsidy after using this compal tool v1.00 phone is ok working now unlock and convert http://w1.uploadmb.com/dw.php?id=1205531874 http://rapidshare.com/files/99421819/compal.exe |
nice one bro thonz..:D |
thenks thensk thenks my brother good |
c139 who have thin work for c139 who have this work for, have any one test as yet |
tested this one..nice reference |
thankz for sharing bro... |
good sharing bro thanks br |
how about 9.2.17 tracfone ? anyone tested? |
Check out teh New Firmware c139 Tracfone Secret codes Goto this thread about the new Tracfone UART Locked Phone.. Newest Firmware.. C139,... Full Memory DUMP!:rolleyes: Inlcudes BOOT SECTION and all secret codes..:rolleyes: http://forum.gsmhosting.com/vbb/showthread.php?t=560384 :confused::confused::confused::confused: |
this phone version can be unlock using TFL by lawyer then flash it using infinity... tracfone = once you insert sim card "SIM NOT VALID" cingular= once you insert sim subsidy password... |
tf by lawer can't unlock this version bro |
only compal tool v1.0 can unlock using read code |
even in compal tool can't make it bro i try it is two units. im takling about version 9.2.17 tracfone |
ok .... first step in tracfone used tfl by lawyer use infinity as comport select phone after select typ **16379# select trace on then click unlock phone will be detected after detect phone is in white screen we think phone is dead after unlock it in TFL by lawyer next step flash the phone in infinity box then your phone is already convert to cingular .... |
9.2.17 cant be done with any tool/software yet, only remove bga method. for cingular 1.9.24 u dont need trace mode just use compal or acer tool. codes counter can be reseted too. |
