Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Motorola > ODM (Original Design Manufacturing)
  • BENQ(Acer): C113,C139,C168,C200,C205,C300,C257,C261, T205,T2688,T190,T191,V171,V290
  • CHIMEI: MPX200, MPX220, MPX300, V690, V878
  • COMPAL: E360, E365, MPX100, C115, C155
  • Reply
    Old 01-29-2010, 14:45   #1 (permalink)
    akhil_bbsr's Avatar
    Member: 271478
    Sonork: 1590868
    motorola experts REPLAY ONLY
    The W180 is detected as LOCOSTO but after 5 seconds, it is detected as "W180".
    I tried many times to remove/insert the battery but I don't manage to reconize it , Where as its detects by MSS2,but it cant detect in pc, its apers for 10 seccond then vanish from device manger, but in mss its connecting without any problem.i removed driver cleaned still unable to connect in DM TOOL
    IF ANY ONE KNOWS THE EXACT SOLUTION..PLS...POST HERE
    Old 01-29-2010, 16:02   #2 (permalink)
    Member: 416710
    Which soft are you using to detect phone. You need use program to boot the phone because if you only are in device manager phone will change to charge mode or to phone mode.
    [IMG] code is Off
    Need expert replay -fps10 akhil_bbsr GSM Programming & Reverse Engineering 3 03-25-2010 17:04
    experts reply only shabooksa Nokia Hardware & Hardware-Repair Area 6 04-23-2008 10:44
    @ Motorola Expert ... plz inform how to unlock farrukh mobiles Smart-Clip 2 10-28-2007 07:31
    to motorola experts tajinder P2k Series 4 02-08-2007 15:24
    Who is motorola expert? Kashif Khan P2k Series 1 02-02-2006 22:02
    Page generated in 0.23322 seconds with 11 queries
