Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Motorola > ODM (Original Design Manufacturing)
  • BENQ(Acer): C113,C139,C168,C200,C205,C300,C257,C261, T205,T2688,T190,T191,V171,V290
  • CHIMEI: MPX200, MPX220, MPX300, V690, V878
  • COMPAL: E360, E365, MPX100, C115, C155
  • Reply
    Old 08-03-2006, 18:15   #1 (permalink)
    Cheater Don't Deal With Him
    Member: 112444
    need help please to change band for , c139, v172 , v171, c261
    hi i have these phones in 850 mhz i need to change to 900. i have dmtool but when i flash to unlock it the frequnecy is the same. I know they can work but how do i change the software. I also have the same phones in 900 mhz same hardware . Just different software please tell me how to make it work
    Old 08-04-2006, 05:17   #2 (permalink)
    Member: 280043
    This band its posible winth manually for settings for this phone
    Old 08-04-2006, 13:35   #3 (permalink)
    Member: 112444
    that wont work
    that wont work in the menu u only get 850/ 1900
    i want to completely reprogram the phone to get 900/1800.
    Old 08-13-2006, 06:49   #4 (permalink)
    Member: 136686
    Sonork: 1589083
    this will not work you need to change hardware...
    Old 09-20-2006, 07:41   #5 (permalink)
    sajib_ngage's Avatar
    Member: 243500
    Sonork: 100.1590423
    i have same problem after unlock no network.what can be done????
    Old 09-22-2006, 16:19   #6 (permalink)
    Member: 305197
    I would like to know as well.
    Old 10-01-2006, 17:04   #7 (permalink)
    Member: 293459
    Just reflash it with european software supporting 900/1800MHz. Hardware is identical.
    Old 10-01-2006, 17:27   #8 (permalink)
    Member: 137489
    I flash with DTTool but the band dont change.......
    Old 10-02-2006, 02:12   #9 (permalink)
    Member: 293459
    Go to settings and take a look there if it says 850/1800 or 900/1800.
    Are you sure you flashing european soft. Make sure to use eropean flex.
    Let me know how it goes.
    Old 10-03-2006, 05:03   #10 (permalink)
    Member: 280043
    yes you need flsh tri band 900, 1800 and 1900Mhz ok please givme time.
    Old 10-13-2006, 03:34   #11 (permalink)
    Member: 157188
    I too. please help me. unlock band 900
    Old 10-24-2006, 13:06   #12 (permalink)
    Crazy Poster
    Member: 305793
    I was succeed change for C139.But it only 900HZ.
    It need change hardware!
    First,flash of support 900/1800 SW,it is 850/1900HZ also.After change R101 to R218 place(R218 original is blank),power-on,now it is 900/1800HZ.
    Old 11-02-2006, 12:48   #13 (permalink)
    Member: 280043
    Espero te ayude con este flash...
    Old 11-09-2006, 16:26   #14 (permalink)
    Member: 75301
    i think you must have to change the cristal too
    Old 11-17-2006, 17:58   #15 (permalink)
    Crazy Poster
    Member: 38994
    you mean exchange place, where is that located? post more details, TIA
    [IMG] code is Off
    [Need Help] How to change IMEI N95-1 destronid Chinese Miracle & PinFinder 8 12-11-2010 18:01
    How to change band for C139B? suntluk ODM (Original Design Manufacturing) 0 09-23-2006 04:21
    need help ,how to read flash from C139 pali ODM (Original Design Manufacturing) 0 08-25-2006 08:37
    need help trying to change my v600 from cingular startup image and icons to unbranded megastahr UniMoto 2 06-18-2004 09:02
    need help how to change icon raivenz Off Topic Zone 0 03-03-2002 00:33
    Page generated in 0.68251 seconds with 12 queries
