Motorola ODM BENQ(Acer): C113,C139,C168,C200,C205,C300,C257,C261, T205,T2688,T190,T191,V171,V290 CHIMEI: MPX200, MPX220, MPX300, V690, V878 COMPAL: E360, E365, MPX100, C115, C155 |
07-01-2002, 05:09 | #2 (permalink) |
Freak Poster Join Date: Nov 2001 Location: Zagreb, Croatia Age: 41
Member: 7558 Status: Offline Sonork: 100.94170 Thanks Meter: 6 | HALLO TEST THIS CODES ..... *#0007# AND THEN PRESS GREN BUTON... Best regards GSMsolution [email protected] http://free-zg.hinet.hr/gsmsolutionzg/ |
07-01-2002, 17:22 | #3 (permalink) |
Junior Member Join Date: Oct 2001 Location: Russia, Saint-Petersburg Age: 48
Member: 6611 Status: Offline Thanks Meter: 0 | langpacks for t191 contains 10-20 languages(flash filename "mhxxxx10/11/12.mot") and if you press *#0007#<send> and see russian message, you dont need to flash phone, if not, use xxxx11 flash file. after entering combination above, you will have russian menu, but you can not select russian language in lang submenu, and if you power-off the phone, russian will be disabled. to activate needed language in menu you must flex the phone. |
07-01-2002, 22:02 | #7 (permalink) |
Member: 7558 Status: Offline Sonork: 100.94170 Thanks Meter: 6 | HI flex option here ..... You can flex your phone if you have special cable ,,, and DMtools .... or use KIMA software .... Flex Option Use this command to switch the current view to FlexOption View , which using to Read or Write Flex Option. FlexOption Mode : For Topaz model we support D70/D70R and D70R2 in the same flexoption view. When you change the flexoption mode, the flexoption tree item will change to the format for the mode you change. For Amethyst model, it support by the software major version MH_0, MH_1 in the same flexoption view. When you change the flexoption mode, the flexoption tree item will change to the format for the mode you change. PS. The modes are support the flexoption define file (*.def) in the install directory, it define the flexoption tree and the relative position in eeprom of the target handset. Check before Read: If you enable it, when you read reflexoption the dmtool will auto change the flexoption mode. And then mapping result value which reading from target handset to the flexoption tree item. Check before Write: If you enable it, when you write reflexoption the dmtool will auto check the flexoption mode is correct or not. If it is correct mode, then dmtool will mapping now flexoption tree item and write to target handset. Auto Check Mode: You can click it to auto change your flexoption mode by check your target handset software version. Write Flex Option: When you click this button, dmtool will write the settings to the target handset. Read Flex Option: When you click this button, dmtool will read the flexoption settings from the target handset. Write PPF flexoption: When you click this button, dmtool will read the flexoption settings from ppf file and write into the target handset. best regards GSMsolution. |
07-02-2002, 01:06 | #8 (permalink) | |
No Life Poster Join Date: Apr 2001 Location: IN CASTLE Age: 46
Member: 3925 Status: Offline Thanks Meter: 22 | Re: HI hi man --------------------------------------------------------------------------- Quote:
how to add russian language in my phone. i'm need *.pff file please teach me. thank you for help regards | |
07-03-2002, 17:23 | #9 (permalink) |
No Life Poster Join Date: Apr 2001 Location: รำมว&#
Member: 3956 Status: Offline Sonork: galletto3 rules :D Thanks Meter: 55 | re hi, you donīt need more that read flex and then write back with lenguajes you choose, no more needs that flash database and dmtools. Lenguajes can be activated all or individualy, up to you, best regards, Invisible |
07-03-2002, 22:50 | #10 (permalink) |
Member: 7558 Status: Offline Sonork: 100.94170 Thanks Meter: 6 | HALLO If you use DMtools for activation language you mast read flex option ..... or use flex file ..... if you only select language without reading flex option your phone cant vibrate because ringing is not active .... Best regards GSMsolution [email protected] http://free-zg.hinet.hr/gsmsolutionzg/ |
07-04-2002, 01:11 | #11 (permalink) |
Member: 6611 Status: Offline Thanks Meter: 0 | yes, its very simply - read flexoptions --> enable needed language --> write flexoption. never more no less if language not present in menu after that, flash the phone(sorry, i don't know where you can get the flash file with your language) |
07-08-2002, 01:06 | #13 (permalink) | |
Freak Poster Join Date: Oct 2001 Location: Novosibirsk
Member: 6791 Status: Offline Thanks Meter: 0 | Quote:
http://www.gsmlab.com/programs/images/t191.gif | |
'0C' is not a valid integer value WHAT SHOULD BE DONE? | ockiya | Cyclonebox | 0 | 02-19-2010 08:57 |
what details should be given to activate our box from ub | totalmanish | Universalbox | 1 | 01-01-2009 08:12 |
iphone in recovry mode,itunes errors what should be done | prasad3223 | iPhone 2 / iPhone 3G / iPhone 3GS | 0 | 09-19-2008 16:50 |
! POLL::What should be more model add in Infinity.....??? | GsmXplorer | Infinity-Box | 3 | 06-30-2007 04:34 |
