04-16-2006, 21:25 | #1 (permalink) |
Freak Poster Join Date: Mar 2004 Location: U.K www.PhoneandIT.com
Member: 59991 Status: Offline Thanks Meter: 40 | Any Solution for LG 81xx Unlocking problem? same with me i have two handsets of LG 8120... after unlocking no signals.. any real solution.... using vygis and cable???? regards Pakstar |
04-16-2006, 22:37 | #4 (permalink) |
No Life Poster Join Date: Mar 2004 Location: UAE / UK / PAK / HK
Member: 59731 Status: Offline Sonork: 100.99999 Thanks Meter: 514 | I have seen few phones with this problem, most of them are due to bad GDFS , if you try to unlock it with Furious (read codes) it resets the GDFS which helps and we have fixed few phones with no signal. You can also re write GDFS if you using Vygis. all above information is base on personl experiance. regards Unlocking Expert Team. |
04-16-2006, 23:43 | #5 (permalink) |
Member: 59991 Status: Offline Thanks Meter: 40 | How i did, Connected phone with Vygis new cracked version, click on unlocked, it says enter this code with sim and then enter NCK.. when i turned on phone it said phone USIM locked.. i tried 3 sim.. it was working but NO SIGNALS... this is second phone with Vygis software, that I tried to unlocked and lost signals.. IF you have any GDFS files please send the link its U8120 V105 both phones same spec.. many thanks Pakstar |
04-16-2006, 23:51 | #6 (permalink) |
No Life Poster Join Date: Apr 2004 Location: Skopje , Macedonia Age: 40
Member: 61851 Status: Offline Sonork: 100.1604862 Thanks Meter: 117 | Here you are http://www.kokoom.com/eminem1/softwa...lashlinks.html and here are gdfs for all LG 3G http://www.kokoom.com/eminem1/software/lg3G/lg3g.html One more if you flash phone with V105 use drive_c from V104 or lower so you can enter readed codes. regards |
04-17-2006, 00:25 | #7 (permalink) | |
Member: 59991 Status: Offline Thanks Meter: 40 | Quote:
i did that but phone said USIM LOCKED and code didn't work, I re-locked and Unlocked again but no solution. now phone is not taking signals at all.. what is the solutoon? Can anyone tell me step by step? regards Pakstar Last edited by pakstar; 04-17-2006 at 00:45. | |
mr hack any solution for lg ke970 erased boot | f164 | FuriousGold | 1 | 07-30-2009 08:31 |
Any solution for LG RD3600 user lock | pavi | Various CDMA/TDMA Cell Phones | 3 | 06-22-2009 15:39 |
ANY SOLUTION FOR NOKIA 6131 Handsfree PROBLEM? | ..::khaled::.. | Nokia Hardware & Hardware Repair | 0 | 11-29-2008 18:23 |
Any Solution for Bird S199 Unlock/Flash ? | powerusergpt | Various | 8 | 10-04-2006 07:21 |
Any Solution for 8250 " Hang" Problem? | xpmobile | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 01-25-2002 02:56 |
