Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > LG
Old 11-23-2006, 18:53   #1 (permalink)
petermov's Avatar
Member: 79485
blank display kg800 chocolate
Hi, I have a pair of lg kg800 with blank display, no conector, nor display, nor flex cable are damaged... so I suposse is a module engine failure, any body has suffered same probl?
TIA.
Old 11-23-2006, 18:59   #2 (permalink)
.:hack3r2k:.'s Avatar
Member: 15022
Sonork: 100.53452
TIA.
Just do a search. Youll find anwer on this forum.
Old 11-24-2006, 10:08   #3 (permalink)
petermov's Avatar
Member: 79485
mmm...
Nuthing solved on that post, man.
Thank you for your fast response.
Old 11-30-2006, 07:31   #4 (permalink)
Crazy Poster
Member: 237607
try full flash with hwk, if not, unlock and save the calculation data from a working phone, flash working calculation data, rebuild and unlock... should be okay, i 've done it to mine and it works fine now, good luck!
Old 12-01-2006, 06:37   #5 (permalink)
Member: 68136
100% solution of kg 800 display white
replaecd the flexible assy /try to reconect flexible assy connector your problem 100% solve. i have repair more than 30 handsets in same case
Old 12-04-2006, 09:14   #6 (permalink)
petermov's Avatar
Member: 79485
mmmmm....
@civ1129: THANKS!!!! SOFT PROBLEM....SOLVED!!!
Thanks everybody for your attention.
Old 03-12-2007, 09:20   #7 (permalink)
Member: 83223
Did you find out enything about the issue wich the touch pad activate by itself in menu? Thanx
Old 01-05-2009, 01:54   #8 (permalink)
mobile tech!!'s Avatar
Member: 829776
do you have pics of this (assy)
Correct pinout for KG800 -chocolate- Mobileman_hu ThunderStorm Box 0 10-30-2006 19:17
LG KG800 chocolate + KG 22x clip - Lobster 544 &575clip - BenQ Siemen Clip £35 incVAT datacablelondon Main Sales Section 0 10-30-2006 13:43
LG KG800 Chocolate incredibleh LG 3 10-21-2006 18:44
Lg Kg800 Chocolate H_TSOPELAS LG 6 07-27-2006 02:04
First in the world LG KG800 CHOCOLATE unlocking clip fonegroup Main Sales Section 0 07-06-2006 19:02
Page generated in 0.63906 seconds with 11 queries
