03-23-2010, 14:23 | #3 (permalink) |
Freak Poster Join Date: Oct 2009 Location: madrid spain
Member: 1145599 Status: Offline Thanks Meter: 41 | how enter unlock cod in lg Cellunlocker.net - IMEI unlock codes, unlocking Cellular, Subsidy Unlock, Unlock network Here are some instructions, hope this helps How to Unlock LG (most models): 1. Insert SIM card not allowed 2. Turn the phone handset will display "phone restricted" 3. Select "Cancel" - phone will display "phone restriction code" 4. Enter the SIM unlock code 5. Select "OK" - the phone is unlocked successfully Instructions to unlock LG TU720 (shine) and VU 1. Turn on the phone with no SIM card enabled (which do not come with the phone) 2. Enter * # 865,625 # 3. the phone asks you to enter the unlock code twice, just input the unlock code 4. Device is unlocked How to Unlock LG KG800 or TG800 Chocolate: 1. With the phone in standby, enter 2945 # * 7101 #. This will activate the extra menu. 2. Go to: Settings> Security> Operator> Red 3. Select Off. Enter the unlock code How to Unlock LG C2000: 1. No Insert Cingular SIM card 2. Turn on your phone - phone will display "phone restricted" 3. Select "Cancel" - phone will display "phone restriction code" 4. Enter the SIM Unlock Code 5. Select "OK" - the phone is unlocked successfully How to Enter Unlock Codes on LG F2250: 1. With enabled SIM card in the start menu type: 2945 * # 3311 #. 2. Phone shows saved, then return to startup screen 3. Press Menu, select Settings> Security> Sim Lock> Network> Deactivate, now phone will display "Enter NCK" 4. Enter your unlock code and OK. How to Enter Unlock Codes on LG U8150: 1. Turn your phone with a not allowed SIM card. 2. Membership: 277,634 # * #. 3. Go to menu "SIM Lock". 4. Enter the unlock code How to Enter Unlock Codes on LG U8110: 1. With not allowed SIM card in your phone enter the PIN code and then validate, type: 277,634 # * # 2. Select 'Open Sim menu' # 3. Enter NCK code then validate 4. Your phone is unlocked. How to Enter Unlock Codes on LG U8210: 1. SIM card not allowed to enter the PIN code and then validate, type: 277,634 # * # 2. Displays the test menu 3. Select SIM test menu and type * # 2945 #, choose Sim Open menu 4. Phone shows 'Enter NCK' 5. Enter the code, and then click OK. How to Enter Unlock Codes on LG U81xx: 1. To open the menu to unlock the phone with a SIM card, type * # 2945 # 88110 2. Enter code In case you need to restart the phone without a SIM card first, type 277,634 # * # or # 47,328,545,454. How to Enter Unlock Codes on Cingular AT & T LG CU500: 1. No Insert Cingular SIM card. 2. Turn on the phone. Phone will display "Invalid SIM card" 3. (If the phone is not listed please VALID SmartChip off and on again) 4. In the idle screen, enter * # 159,753 #. Phone will display "Enter NCK, Remaining 5 5. Enter the 8 digit SIM unlock code 6. Select "OK". The phone is unlocked successfully. Unlock Instructions for LG KU990 (Viewty) 1. Insert original SIM card and turn phone. 2. Click the phone icon in the bottom of the screen to display the phone keypad 3. Enter 2945 # * 990 # 4. This opens a popup menu, select SIM unlock 5. Enter your unlock code and press OK 6. Then the phone will reboot and the unlock is complete. Instructions to unlock LG KF600: 1. Insert original SIM card and turn phone. 2. Enter * # 2945 # 71001 3. A pop-up menu to enter the SIM unlock code 4. Enter your unlock code and press OK 5. Then the phone will reboot and the unlock is complete. Instructions to unlock LG KF750 aka LG Secret: 1. Insert original SIM card and turn phone. 2. Enter 2945 # * 750 # 3. This opens a popup menu, select SIM unlock 4. Enter your unlock code and press OK 5. Then the phone will reboot and the unlock is complete Instructions to unlock LG CU915: 1. Turn on the phone with an accepted SIM card. 2. Enter * # 865,625 # CODE 3. Click OK 4. Device is unlocked How to Enter Unlock Codes on LG Incite CT810: 1. Flag this phone the LG Incite menu 2. 2945 # * 810 # 3. Press Call. 4. You should ask for the code. How to Enter Unlock Codes on LG Invision CB630: 1. Insert an AT & T or Cingular SIM in the phone, do not have to be an active SIM 2. Flag this phone the LG Incite menu 3. * # 865,625 # 4. Press Call. 5. You should ask for the code. How to Enter Unlock Codes on all other LG cell phones: 1. Turn your phone with a SIM card enabled 2. Then compose: 3. 2945 * # 5101 # - (if you have a LG 510w) 4. 1945 * # 5101 # - (if you have a LG 1200 and B1200) 5. 2945 * # 5221 # - (if you have a LG 5200 and 52200) 6. 2945 # * 5301 # - (if you have a LG 5300) 7. 2945 # * 5401 # - (if you have a LG 5400) 8. 2945 # * 70001 # - (if you have a LG 7020) 9. 2945 * # 7101 # - (if you have a LG 7100) 10. 2945 # * 1201 # or * # 2945 # 70001 - (if you have a LG 1100) 11. 2945 # * 70001 # - (if you have a LG7250T) 12. 2945 * # 2201 # - (if you have a LG C2200) 13. 2945 # * 5301 # - (if you have a LG T5100) 14. 2945 * # 3311 # - (if you have a LG C3310) 15. Go to "Menu" then "Settings" 16. Then select "Security" 17. Finally, select "network" and select "Disable" 18. Enter the unlock code 19. If your cell phone is not listed, please follow the instructions for LG C2000 above How to Enter Unlock Codes on LG KE970 Shine: 1. Turn your phone with a SIM card enabled 2. Then compose: 2945 * # 9701 # 3. Press Call. 4. You should ask for the code. How to Enter Unlock Codes on CU575 / CU515 Trax and 1. Put a non Cingular SIM in the phone, the phone says invalid smart chip 2. Then enter * # 865,625 # then select option 1 and then again select 1 and enter your 16-digit code __________________ -- |
How to Unlock LG Shine CU720? | Lubin | LG | 3 | 05-15-2011 18:47 |
How to unlock LG u310 and LG u450 | blu1111 | VygisToolbox | 1 | 03-30-2009 16:57 |
problem to unlock LG CU720 ::: U NEED ACTIVATION ::: | gsm_78 | PolarBox 3 | 4 | 02-25-2009 16:14 |
how to unlock lg cu720 from ATT ::: OLD POST BUT ANSWERED ::: | ALGUIEN | PolarBox 3 | 5 | 02-08-2009 19:18 |
how to unlock Lg-LP3000A N Lg Vx9800 by | kerug-bali | Infinity-Box | 3 | 07-14-2008 13:22 |
