07-14-2005, 08:10 | #1 (permalink) |
Junior Member Join Date: Jul 2005 Age: 44
Member: 160343 Status: Offline Thanks Meter: 0 | decode LG8330 but not with u8130_v101_1022 s/w ? pls again hi reading the posts i did not found the answer : Can lg8330 be decoded with other than u8130_v101_1022 software(ex.8330)? I've decoded mine (to connex-romania) with 8130 software but with problems because of G3 support (can place/give 1 of 3 calls) tks |
07-15-2005, 13:12 | #8 (permalink) |
No Life Poster Join Date: May 2003 Location: Romania Age: 48
Member: 29006 Status: Offline Thanks Meter: 28 | if on another provider work fine,then maybe is a problem with new suport of 3G from connex.call customer service,explain you problem and maybe they can solve your problem. |
07-15-2005, 19:49 | #9 (permalink) |
Junior Member Join Date: Feb 2005 Age: 71
Member: 116609 Status: Offline Thanks Meter: 0 | Problems of decoding u8330 with U8130 v101_1022 The problems that I had met when I have decoded the U8330 with the soft of U8130 V101_1022 are : 1/ the battery is discharged quickly after maximum 30 hours. 2/ the signal network isn't reset automatically with the displacement of the mobile from zone witch there is network signal to a zone whitch there isn't network signal. This is very embarassed because it dosn't make possible to have communication neither entering nor outgoing before its switching off and after switching on the mobile. In your opinion how can us solve those important problems . Thanks for your replies. |
07-16-2005, 08:57 | #10 (permalink) |
No Life Poster Join Date: Aug 2001 Location: Roma Age: 49
Member: 5926 Status: Offline Thanks Meter: 275 | is first time when I hear this I've done a lot but not one return with these simptoms like u describe I had one 8130 like this but was dropped from high level (customer said that) BR Rak|m |
07-16-2005, 21:14 | #11 (permalink) | |
Freak Poster Join Date: May 1999 Location: in my mind Age: 56
Member: 17 Status: Offline Thanks Meter: 6 | yes this is true....... also if you flash it with version 106+ and use only drive_c with 101 for unlock is still the same problem... lossing the signal.... br. M. Quote:
07-17-2005, 22:36 | #14 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Quote:
Br | |
Unlocking problem with Nokia 2610 but not with Nokia 2310 | simclub1 | MT-BOX | 28 | 03-14-2007 11:26 |
3230 on with ufs but not with battery | prnc | Nokia Hardware & Hardware Repair | 0 | 10-12-2006 21:52 |
3310 Phone Power On With Ufsx Box But Not With Battry | hafeez48 | Nokia Hardware & Hardware Repair | 20 | 09-21-2006 22:21 |
Strange problem with 6101 phone! swtichin on with cable but not with battery??? | ReyTech | Nokia Hardware & Hardware Repair | 0 | 08-01-2006 14:06 |
