04-02-2008, 19:44 | #1 (permalink) |
Junior Member Join Date: Mar 2008
Member: 735847 Status: Offline Thanks Meter: 6 | Explore/Download/actions on filesystem with Bluetooth for LG phones ! I've made a new version of my program. With it you can download file, open folders, rename, move, delete files/folders, ... Just a problem, you can upload file with size under 8ko, i'm working on this issue. If you want to upload more, use windows or pc studio and send file and move it after in the directory that you want I have a LG KU380 and I think that this program can works for other LG mobile phones because it can be the same protocol Just choose the correct com port and press connect - .. is to go to base directory - file with >D are directory click Open - you can access to directory by entering the name in the edit box and press open dir The main goal is to upload java program on the phone, if somebody find a solution please post here. I've tried with gthing but doesn't works :s I've tried to upload jar on memory card and after move it on the java/ams/M001 folder (before delete the old) but the phone don't allow move the file :s Logs are in c:\temp\lg the folder c:\temp must exists. Maybe you will need the VC++ dll for VS2003 (MFC 7.1) maybe vc++ 2005 redist works i don't test. Sorry for my bad english, i'm french. |
04-03-2008, 17:41 | #3 (permalink) |
Member: 735847 Status: Offline Thanks Meter: 6 | here is the new program if the old doesnt correspond to screenshot. About java app, i've dl 1 from wap and moved it to µsd. i'll try to put an other instead of the installed to see if it's works. |
Ribbon with IC for LG MG910 Phone - Original | IPMART | ipmart WebShop | 0 | 11-15-2008 11:00 |
Ribbon with IC for LG KU970 Phone - Original | IPMART | ipmart WebShop | 0 | 11-15-2008 11:00 |
LCD with Ribbon for LG KU580 Phone - Original | IPMART | ipmart WebShop | 0 | 11-08-2008 07:00 |
LCD with Ribbon for LG KU250 Phone - Original | IPMART | ipmart WebShop | 0 | 11-08-2008 07:00 |
Download big files with bluetooth for qtek 8500 | efiefi | HTC & PDA WM( With Touchscreen) | 0 | 11-25-2007 03:48 |
