Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > LG > LG Android based phones
LG Android based phones General LG Android phones discussion, firmwares, solution, root, help
Old 08-03-2012, 11:12   #1 (permalink)
salo_ustad's Avatar
Member: 413160
Sonork: 100.1657278
Thanks Meter: 69
Hard Reset LG P705
how to a hard reset of LG p705 i can't find my solution that's y i post here
Old 08-09-2012, 20:49   #2 (permalink)
edcentec's Avatar
Member: 232960
Thanks Meter: 329
1. When the phone is switched off, press
and hold the Volume down key +
Power key with your left hand.
2. When the LED on the bottom of the phone
lights up, touch and hold the Menu key
with your right hand. You need to do this
immediately, before the screen displays the
LG logo. Make sure your left hand is still
holding the Volume down and Power keys.
Then release the power key at vibration time.
3. When the LG logo is displayed on the
screen, continue to hold the keys for
around 2 seconds, and then release all
them at the same time, before the LG
logo disappears.
Leave your phone for at least a minute while
the hard reset is carried out. You will then be
able to switch your phone back on.
Old 08-11-2012, 16:30   #3 (permalink)
salo_ustad's Avatar
Member: 413160
Sonork: 100.1657278
Thanks Meter: 69
logo disappears.
sorry all the method didn't worked for me only flashing system solved my problem
Old 08-22-2012, 08:41   #4 (permalink)
Member: 62154
Thanks Meter: 16
yes, flashing is more easy.
Thank you
nang
Old 09-24-2012, 23:33   #5 (permalink)
Member: 1038468
Thanks Meter: 50
I used this method and it worked for me
1 - Open the version of Vygis LGI_1_95SD
2 - Mark model KP100
3 - Connects only in ports & settings
4 - Click on reset phone with him and connected with the cable GS102
The Following User Says Thank You to SPAÇOCELL For This Useful Post:
Old 10-02-2012, 16:54   #6 (permalink)
Member: 402146
Thanks Meter: 4
100 % work
Hard Reset LG P705 - YouTube
Old 11-09-2012, 05:28   #7 (permalink)
Member: 465933
Thanks Meter: 10
Hard Reset LG P705 HANВ MODE )
The Following User Says Thank You to MobilaGSM For This Useful Post:
Old 11-09-2012, 06:55   #8 (permalink)
Member: 465933
Thanks Meter: 10
Hard Reset LG P705 HAND MODE )
Old 01-05-2013, 10:00   #9 (permalink)
Member: 82528
thanx
Originally Posted by MobilaGSM View Post
1000000% perfect and true
thanx
Old 01-05-2013, 16:46   #10 (permalink)
Member: 45771
Sonork: 1580823
Thanks Meter: 9
logo disappears.
Old 01-14-2013, 14:32   #11 (permalink)
Member: 1263622
Thanks Meter: 116
im_tested..............................good_workin g.............
Old 03-08-2013, 10:24   #12 (permalink)
.::Indrojith::.'s Avatar
Member: 80250
Sonork: 100.1602959
Thanks Meter: 47
first remove battery
then hold vol up+down and insert cable
wait a few minute...
then show android engine..
after 2min press power button....
select wipe data reset....
when complette then select reboot system now...
100% tested
Old 03-10-2013, 11:09   #13 (permalink)
Member: 1891179
Sonork: 100.1627755
Thanks Meter: 50
LG Optimus L7 P700 hard reset - PDA Smartphone PNA hard reset soft reset
Old 03-15-2013, 21:31   #14 (permalink)
Member: 172567
Thanks Meter: 48
Made by hand! It's important to know, "menu key" is not the center key, is the lighted sensor on the right. Instructions are correct, just confused the key to press.
Old 03-17-2013, 14:15   #15 (permalink)
plentong's Avatar
Member: 44095
Thanks Meter: 18
logo disappears.
Yes this solution tested by me.
COMFIRM WORK
Thanks.
My 5110 v5.11 have a strange error.., it resets it self every 60second luuk Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 24 08-11-2006 15:29
3110 Need to Unlock & Reset ed2k_7 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 11-22-2001 07:35
how can you reset the life timer without using a data cable for a 5125 TDMA phone? PiNoY_bOy204 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 08-23-2001 12:46
HOW TO RESET SECURITY CODE IN NOKIA 6210 ed2k_7 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 10 05-26-2001 05:33
5190 patial flashes - why are they so hard to find? Bads Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 04-14-2001 03:18
Powered by Searchlight © 2015 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2015 -
Page generated in 0.51184 seconds with 8 queries
