02-28-2014, 11:22 | #1 (permalink) |
Freak Poster Join Date: Nov 2011
Member: 1686318 Status: Offline Thanks Meter: 5 | LG GW520 Yellow Screen after unlock FIX LGTool --Step 1- Go to the download tab and download the firmware for your phone, I downloaded HUK as my LG was on 3 Uk. --Step 2-- Connect the device in the direct service tab. Once the phone has been detected, do a 'FULL' dump of the device and save the dump somewhere as a backup. Then Dump the File System - This is the 1 we need. YOU MUST DO A FILE SYETEM DUMP --Step 3-- In the flash section, Browse for the firmware you downloaded and click the 'Firmware' button to start the flashing process. This may take a little while. Once the firmware has flashed you now need to browse for the File System DUMP which you made, and click the 'File System' button to flash to the phone. If you dont do this step you will get a Partition Error. --Step 4-- Now in the services tab, enter your phones correct IMEI number and click the 'Repair IMEI' button. Your phone should now be booting into the firmware and have the correct IMEI. If you still need to unlock the phone, you should be able to 'get code' from the free server tab. |
