04-30-2011, 10:15 | #1 (permalink) |
Junior Member Join Date: Apr 2011
Member: 1566514 Status: Offline Thanks Meter: 0 | Help GD900 Blocked in logo lg and I end up always the same thing happen to Step 7 of 10: Process Time Was 11 min 5 sec. Start downloading item 'ROOT DISK: CRYSTAL_EUROPE_OPEN-ROOT.dfat''from file'C: \ FLASHE2 \ GD900AT-00-V10b-XXX-XXX-JUN-15-2009_1.fls''. Sending sec-pack. Load region 0 Sending data. Process Time Was 36.4 sec. I started on a Windows XP PC because I work seven and still the same problem, I call with this story starts to annoy me ... |
04-30-2011, 11:28 | #2 (permalink) |
Member: 1566514 Status: Offline Thanks Meter: 0 | Oops,I forgot to put the error message is this: Stopped at 4% WIN32 Comport error 31. Line 2158 Channel 1 is succesfully closed. Disconnected. Ready for new phone." Can you help me ? PS: I speak french, excuse me for my bad english |
05-02-2011, 21:23 | #4 (permalink) |
Member: 1566514 Status: Offline Thanks Meter: 0 | I noticed that when I put the battery flashing it hangs from the beginning it does not advance, so that when I put the battery happens to 4% and blocks still there I do NOT understand, Help me PLEASE: ( Sorry to insist,but this phone will make me crack. |
05-03-2011, 22:17 | #6 (permalink) |
No Life Poster Join Date: Mar 2004 Location: LGE
Member: 57760 Status: Offline Sonork: 100.1579298 Thanks Meter: 3,510 | Hi, Try flashing with GSMulti V30. GD900 Firmware GD900AT-00-V10e-EUR-XXX-JUL-01-2010+0 GD900 DLL GD900_090408.zip Flasher and Procedure 1. Install GSMULti V30 2. Connect phone to usb cable without battery, Windows will ask for driver, show driver from C:\GSMULTI\UsbDrivers\INFINEON. 3. Open USBMap from C:\GSMULTI, select INFINEON and click MAPPING START, reconnect the phone to usb cable without battery. Some info will show on PORT/KEYNAME, now SAVE & EXIT. 4. Open GSMulti main software, go to Setting(s) > Configuration, select DLL and firmware on S/W box, select USB as communication then click OK. Now click START on main window, when the software says Wait Phone Connecting.. reconnect the cable. If flashing not start without battery just put the battery and slightly press power button. if still failed, try flashing with UART mode. You'll need a FTDI (or any USB to serial converter box) and a cable of KE500 pinout. |
05-04-2011, 14:27 | #7 (permalink) |
Member: 1566514 Status: Offline Thanks Meter: 0 | Thank you for your reply,I was already using GSMulti v3.0. I just downloaded your files and I tried again from the beginning on a PC formatted but when I connect my phone without battery to the pc again (after installing the drivers well on windows via the window), I hear the sound of windows when you plug a USB but I hear the sound of a few seconds after disconnection and GSMulti blocked at the first step to 0% without moving, then I try again with my battery and there GSMulti turns up again in the 7th stage and hangs at 4% ... I tried again the same steps up to 7 times now ... |
05-05-2011, 10:20 | #9 (permalink) |
Member: 1566514 Status: Offline Thanks Meter: 0 | So I have to buy a dongle to flash my phone, right? If that's it, I'd rather go pay someone to flash it, it must be said that the dongles are expensive ... But thank you for your answers I would stay with my clipboard at the moment |
Operator-Logo for 5110 | MiMiR the WiseMan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-25-1999 15:50 |
