How to Enter LG Unlock Codes LG Unlock Code Entry Instructions If you receive an unlock code from GSMLiberty in the following format: Unlock Codes: (16 or 8 digit code) , (16 or 8 digit code), (16 or 8 digit code), (16 or 8 digit code), (16 or 8 digit code) The First code is always the network unlock code Fido-Canada models ONLY Certain LG models from Fido also require the SPCK, service provider code, along with the NCK, network unlock code. The LAST CODE is the Service Provider code to be used, in this case. The service provider code is only used when the Service Provider is locked on the phone. All other codes in between are not to be used. If you do not see instructions for your model, please do contact us at [email protected] with your order number to better assist you How to enter LG E900 Optimus 7 Unlock Code 1- Power phone on with a non-accepted SIM card 2- Phone will request Enter PIN Code or Insert Approved SIM card 3- Dial in SPCK Code and press OK How to enter unlock code LG Shine Plus C710 Aloha 1- Power phone on with accepted SIM card 2- Select the dial pad 3- Dial 2945#*710# and press send 4- Dial network unlock code at prompt (for Telus Canada, dial Service Provider Code) 5- Select unlock How to enter LG Cookie Lite T300 Unlock Code 1- Power phone on with an accepted or no sim card 2- Dial 2945#*300# 3- Unlock menu will appear 4- Select Network unlock 5- Dial nck/unlock code How to enter LG CE0168 Unlock Code: 1- Power phone on with non-accepted SIM card 2- Dial 2945#*168# 3- Dial Unlock Code and Press the Dial button or OK 4- Phone should show, code accepted How to enter LG KP235 Unlock Code 1- Power phone on with a non-accepted SIM card 2- Phone will show "phone restricted" 3- Select Cancel 4- Phone will display "phone restriction code" 5- Enter the Unlock Code 6- Select OK How to enter LG KM570 Unlock Code 1- Power phone on with accepted SIM card 2- Dial 2945#*570# 3- Unlock menu will appear 4- Dial unlock code provided 5- Press ok How to enter LG T310 Unlock Code 1- Power phone on with an accepted SIM card 2- Dial 2945#*310# 3- Unlock USIM 4- Press OK 5- Dial NCK unlock code 6- You might be asked to enter the unlock code twice 7- Phone is now unlocked How to enter LG P500 Unlock Code 1- Power phone on with an accepted SIM card 2- Dial 2945#*500# 3- Network unlock request will appear 4- Tap empty space to enter code 5- Dial NCK unlock code 6- You might be asked to enter the unlock code twice 7- Phone is now unlocked How to enter LG P509 Unlock Code 1- Power phone on with an accepted SIM card 2- Dial 2945#*509# 3- Network unlock request will appear 4- Tap empty space to enter code 5- Dial NCK unlock code 6- You might be asked to enter the unlock code twice 7- Phone is now unlocked How to enter LG BL20 New Chocolate Unlock Code 1- Power phone on with accepted SIM card 2- Dial 2945#*20# 3- Unlock USIM 4- Press OK 5- Dial NCK unlock code 6- You might be asked to enter the unlock code twice 7- Phone is now unlocked How to enter unlock code LG GD880 1- Power phone on with accepted SIM card 2- Dial 2945#*880# 3- Select Network unlock 4- Dial unlock code 5- Press OK How to enter unlock code LG p509 Optimus Unlocking Instructions 1. Power ON your phone with non accepted SIM card 2. Dial *2945#509# 3. Phone will request network unlock code to be entered twice 4. Device is now unlocked How to enter unlock code LG GB280 1- Power phone on with accepted SIM card 2- Dial 2945#*71001# 3- Request to enter unlock code will appear 4- Dial network NCK unlock code 5- Press ok How to enter unlock code LG GS290 1- Power phone ON with accepted SIM card 2- Dial 2945#*290# 3- Select unlock usim menu 4- Dial unlock code, press OK How to enter unlock code LG GT540 Optimus 1- Power phone on with accepted SIM card 2- Select the dial pad 3- Dial 2945#*540# and press send 4- Dial network unlock code at prompt 5- Select unlock How to enter unlock code LG KP130 1- Power phone on with a non-accepted SIM card 2- Dial unlock code at network unlock prompt 3- Press ok How to enter unlock code LG GT500 1- Power phone on with no SIM card 2- Dial 2945#*500# to enter unlock menu 3- Select network unlock 4- Dial unlock code, and press OK How to enter LG C1500 Unlock Codes 1- Power phone on with a non accepted SIM card 2- Phone will display phone restricted 3- Select Cance 4- Phone will show phone restriction code 5- Enter unlock code 6- Press ok, phone is unlocked How to enter unlock code LG GM360 Viewty Snap 1. Power phone on with an accepted SIM card 2. Dial 2945#*360# 3. A menu will pop up, select Network Unlock 4. Dial unlock code and press ok How to enter unlock code LG GW820 expo 1. Power on your phone with accepted SIM card 2. Enter 2945#*700# 3. A menu will pop up, select SIM Unlock. 4. Enter your unlock code and hit OK. 5. Your LG GW820 eXpo may automatically reboot. How to enter unlock code LG KP105 1- Power phone on with no SIM card 2- Dial *#9999#2945#*20001# 3- Go to Menu => Settings => Security => SIM-Lock => Net-Lock 4- Dial unlock code and press OK How to enter unlock code LG GM310 1- Power phone on with any SIM card 2- Dial 2945#*71001# 3- Dial the unlock code at the network unlock prompt 4- Press OK How to enter unlock code LG GD900 1- Power phone on with accepted SIM card 2- Dial 2945#*71001# 3- Menu to dial in unlock code will appear 4- Dial unlock code 5- Press OK How to enter unlock code LG GS500 Cookie Plus 1. Power on your phone with the original SIM card in. 2. Enter 2945#*700# 3. A menu will pop up, select SIM Unlock. 4. Enter your unlock code and hit OK. 5. Your LG phone may automatically reboot. How to enter unlock code LG GB255g How to enter unlock code LG GT505 1- Power phone ON no SIM 2- Dial 2945#*505# to enter unlock menu 3- Select network unlock 4- Enter unlock code, press ok How to enter unlock code TU750 1- Power phone on with accepted SIM card 2- Dial *#865625# 3- Unlock Menu will appear 4- Select Network Unlock 5- Dial unlock code and press ok How to enter unlock code LG GD330 1- Power on phone with no SIM card 2- Dial 2945#*71001# 3- Press OK to unlock SIM 4- Press OK to select Network Lock 5- Dial unlock code and press ok How to enter unlock code LG U960 1. Insert original sim card and turn phone on. 2. Enter 2945#*960# 3. A menu will pop up, select Unlock Usim. 4. Select Network Lock. 5. Enter the unlock code and ok. How to enter unlock code LG BL40 Chocolate 1- Power phone on with an accepted SIM card 2- Dial 2945#*40# 3- Select Unlock USIM 4- Dial unlock code twice as requested How to enter unlock code LG GS390 1- Power phone ON with a non-accepted SIM card 2- Select Unlock 3- Phone will indicate phone is locked 4- Press Yes 5- Dial unlock code and press OK 6- Phone will ask for the unlock code again, dial same code and press ok 7- Phone is unlocked or 1- Power phone ON with accepted SIM card 2- Dial 2945#*390# 3- Select unlock menu 4- Dial unlock code, press OK How to enter unlock code LG GT950 Arena 1- Power phone on with a non-accepted SIM card 2- 'Phone Restricted' will appear, select Cancel 3- 'Phone Restriction Code' will appear 4- Dial unlock Code and press OK How to enter unlock code LG CF360 1- Power phone on with non-accepted SIM card 2- Phone will show UNLOCK on screen 3- Select the Unlock option 4- Dial unlock code provided and press OK 5- Phone is now unlocked. How to enter unlock code LG GS101 1- Power phone on with a non-accepted SIM card 2- Select the Unlock option/SIM Lock Code 3- Dial the unlock code and press ok or 1- Insert the original/accepted SIM card and type 2945#*101# 2- Go to menu>Settings>Security>SIMUNLOCK 3- Select Network lock, since its the one that is locked 4- Dial in the network unlock code. How to enter unlock code LG KF310 1- Power on phone with accepted SIM card 2- Dial 2945#*310# 3- Select SIM Unlock 4- Press OK How to enter unlock code LG GD510 1- Power phone on with accepted SIM card 2- Dial unlock 2945#*510# 3- Dial unlock code at network prompt How to enter unlock code LG KS20 1. Power on phone with an accepted SIM card 2. Type 2945#*20# and 2945#*990# 3. A menu will pop up. Select "Sim unlock" 4. Enter supplied unlock code and press "OK" 5. The phone will then reboot 6. Your phone is now unlocked How to enter unlock code LG KF510 1- Power phone on with accepted SIM card 2- Dial 2945#*71001# 3- Go to Menu => Settings => Security => Simlock 4- Dial unlock code How to enter unlock code LG KF900 ***** 1- Power phone on with accepted SIM card 2- Dial 2945#*71001# 3- Enter unlock code in NCK section OR 1- Power on phone with no SIM card 2- Dial 2945#*71001#CODE How to enter unlock code LG KS360 1- Power on phone with accepted SIM card 2- Dial 2945#*71001# 3- Dial unlock code How to enter unlock code LG GB250 1- Power phone on with no SIM 2- Dial 2945#*71001# 3- Dial unlock code How to enter unlock code LG GW520 1- Power phone on with no SIM 2- Dial 2945#*71001# 3- Dial unlock code How to enter unlock code LG KB770 1- Power on phone with accepted SIM card 2- Dial 2945*#770# 3- Select SIM unlock 4- Dial unlock code How to enter unlock code LG KP170 1- Power on phone with accepted SIM card 2- Press telephone icon at bottom of screen to bring up the phone keypad 3- Dial 2945#*170# 4- Select Unlock USIM 5- Select Network Lock 6- Dial unlock code and press ok (you only have 10 attempts) 7- The phone will then reboot and the unlock is done How to enter unlock code KM555 1- Power phone on with a non-accepted SIM card 2- Phone will prompt unlock menu, press OK 3- Select Network Unlock 4- Dial unlock code, and press OK How to enter unlock code LG CU-515 1- Power on phone with non-accepted SIM card 2- Dial *#865625# 3- Select option 1 and then select 1 again 4- Dial your 16 digits code How to enter unlock code LG TE365, GT365 Neon, 1- Power on phone with accepted SIM card 2- Dial *#0001#code# 3- Your phone is unlocked or 1- Power phone on with accepted SIM card 2- Dial *#865625# 3- Dial unlock code twice 4- Your phone is unlocked How to enter unlock code LG CT810 (Incite) 1- Power on phone with accepted SIM card 2- Dial 2945#*810# 3- Select SIM unlock 4- Dial unlock code How to enter unlock code LG GT350 1- Power on phone with accepted SIM card 2- Dial 2945#*350# 3- Select SIM unlock => Network Unlock 4- Dial unlock code (make sure dial settings are set to real skin) How to enter unlock code LG GW300 1- power phone ON without SIM card 2- Dial 2945#*71001# to enter unlock menu 3- Dial unlock code How to enter unlock code LG GB106 1. Power phone on with accepted SIM card 2. Dial 2945#*20001# 3.Go to Menu = > Settings => Security => SIMLOCK 4. Dial unlock code & press ok How to enter unlock code LG CB630 (Invision) 1- Power on phone with accepted SIM card 2- Dial *#865625# 3- Press CALL 4- Prompt to input unlock code will appear 5- Dial unlock code How to enter unlock code LG U830 1- Power on phone with accepted SIM card 2- Dial 94471877#*# 3- Select Unlock USIM 4- Select Network Unlock 5- Dial unlock code 6- Phone will show Network Unlock Success 7- Phone will now restart How to enter unlock code LG KF300 1- Power phone on with non-accepted SIM card 2- Message will appear Insert Correct Card 3- Select Deblokkeren (Dutch) 4- Select Network lock off 5- Dial unlock code How to enter unlock code LG KP100 1- Power on phone with accepted SIM card 2- Dial 2945#*20001# 3- Dial unlock code and press ok 4- Phone will reboot, unlock is complete. How to enter unlock code LG KF755d 1- Power on phone with accepted SIM card 2- Press telephone icon at bottom of screen to bring up the phone keypad 3- Dial 2945#*755# or 2945#*750# 4- Select SIM unlock 5- Dial unlock code and press ok 6- Phone will reboot, unlock is complete How to enter unlock code LG Incite CT-810 1- Power on phone with accepted SIM card 2- Dial 2945#*810# 3- Dial unlock code How to enter unlock code LG KP265 1- Power on phone with accepted SIM card 2- Dial 2945#*265# 3- Select Menu > Settings > Security 4- Select SIM Locks > Network > De-activate 5- Dial unlock code How to enter unlock code LG ME550 1- Power on phone with accepted SIM card 2- Dial 2945#*71101# 3- Select Settings > Security > SIM Lock 4- Dial unlock code How to enter unlock code LG TU915 1- Power phone on with non-accepted SIM card 2- Dial 2945#*9701# 3- Dial unlock code at prompt OR Dial *#865625# then dial your 16 digits unlock code How to enter unlock code LG KF390 and KF390q 1- Power on phone with accepted SIM card 2- Dial *#865625# 3- Select Unlock USIM => Network Lock 4- Dial unlock code How to enter unlock code LG CE0168 1- Power phone on with non-accepted SIM card 2- Select Unlock 3- Dial unlock code and press OK Or LG CE0168 1. Power phone on with NO SIM card 2. Go to Menu => Settings => Security => Sim lock 3. Dial unlock code How to enter unlock code LG G910 1- Power phone on with non-accepted SIM card 2- Message will appear Invalid SIM card 3- Select Emergency calls 4- Dial 2945#*71001# 5- Select Netlock 6- Dial unlock code and press OK 7- Phone will reboot How to enter unlock code LG ***** KE850 1- Power on phone with accepted SIM card 2- Dial 2945#*8501# and press the dial button 3- SIM unlock mode will appear on screen 4- Dial unlock code 5- Select Reboot 6- Switch phone off, and then power it back on again How to enter unlock code LG CT810 1- Power on phone with accepted SIM card 2- Dial 2945#*810# 3- Select SIM unlock 4- Dial unlock code and press ok 5- Phone will then reboot How to enter unlock code LG VU CU915 & CU920 (Vu) 1- Power on phone with accepted SIM card 2- Dial *#865625# then the 16 digit unlock code 3- Phone will show Network Lock Deactivated How to enter unlock code LG U310 1- Power phone on with no SIM card 2- Dial 815118#*# 3- Dial unlock code and press ok 4- Phone will then reboot How to enter unlock code LG KC550, KS360, KP230, KP500, KP501, KP270, KM900, KM500, GT810, GC900, GT360 1- Power on phone with accepted SIM card 2- Dial 2945#*71001# 3- Dial unlock code and press ok 4- Phone will then reboot How to enter unlock code LG KF700 , LG Virgo 1- Power on phone with accepted SIM card 2- Dial 2945#*700# 3- Select SIM unlock 4- Dial unlock code and press ok 5- Phone will then reboot How to enter unlock code LG KC910 Renoir, KF910, LG ***** 1- Power on phone with accepted SIM card 2- Dial 2945#*910# 3- Select SIM unlock 4- Dial unlock code and press ok 5- Phone will then reboot How to enter unlock code LG KF750 1- Power on phone with accepted SIM card 2- Dial 2945#*750# 3- Select SIM unlock 4- Dial unlock code and press ok 5- Phone will then reboot How to enter unlock code LG KF600 1- Power on phone with accepted SIM card 2- Dial 2945#*71001# 3- Select SIM unlock 4- Dial unlock code and press ok 5- Phone will then reboot How to enter unlock code LG U970 1- Power on phone with accepted SIM card 2- Dial 2945#*970# 3- Select Unlock Usim. 4- Select Network Lock. 5- Dial unlock code How to enter unlock code LG U300 1- Power on phone with accepted SIM card 2- Dial 815118#*# 3- Dial unlock code How to enter unlock code LG C2000 1- Power phone on with non-accepted SIM card 2- Phone will show Phone Restricted 3- Select Cancel - phone will show Phone Restriction Code 4- Dial SIM Unlock code 5- Select ok How to enter unlock code LG KU990 Viewty , KE990 1- Power on phone with accepted SIM card 2- Press telephone icon at bottom of screen to bring up the phone keypad 3- Dial 2945#*990# 4- Select SIM unlock 5- Dial unlock code and press ok 6- Phone will reboot OR 1- Power phone on with no SIM card 2- Hold "camera" + "lock" button 3- Keypad will appear dial 2945#*990# 4- Select active code. 5- Phone will restart How to enter unlock code LG GB102 1- Power phone on with non-accepted SIM card 2- Dial unlock code at network prompt, press ok or 1- Power phone on with accepted sim card 2- Dial 2945#*20001# 3- Go to menu => settings => security => sim lock code => network unlock code => deactivate => enter sim lock code 4- Dial unlock code and press ok How to enter unlock code LG TU720 , LG CU720 Shine 1- Power phone on with non-accepted SIM card 2- Dial *#865625# 3- Dial unlock code at prompt, phone will ask for the same code twice How to enter unlock code LG CE110 1- Power phone on with non-accepted SIM card 2- Select "Cancel" - phone displays "phone restriction code" 3- Dial unlock code, press OK LG Xenon GR500 locked to FIDO ONLY 1- Power phone on with non-accepted SIM 2- Select Unlock 3- Select UNLOCK USIM 4- Select SERVICE PROVIDER LOCK 5- Enter service provider code 6- Press ok How to enter unlock code LG GR500 Xenon 1- Power phone on with non-accepted SIM card 2- Select "Cancel" - phone displays "phone restriction code" 3- Dial unlock code, press OK OR 1- Power phone on with accepted SIM card 2- Dial 2945#*9701# 3- Select SIM unlock 4- Dial unlock code press ok 5- Phone will then reboot OR 1- Power phone on with accepted SIM card 2- Dial *#865625# 3- Press Yes to continue. 4- Dial unlock code 5- Dial unlock code AGAIN How to enter unlock code LG CU320 1- Power phone on with no SIM card 2- Dial 277634#*# 3- Go to SIM Test in Phone Test Mod. 4- Dial code 2945#*# 5- Access SIM Unlock 6- Dial unlock code How to enter unlock code LG CU400 & CU405 1- Power phone on with non-accepted SIM card 2- Dial 159753#*# 3- Dial unlock code 4- Press OK How to enter unlock code LG CU500 1- Power phone on with non-accepted SIM card 2- Dial 159753#*# 3- Dial unlock code at NCK prompt, press OK How to enter unlock code LG CU515, CU575 Trax 1- Power phone on with non-accepted SIM card 2- Dial *#865625# select option 1 and then again select 1 3- Dial unlock code 4- Device will show Network Lock Deactivated How to enter unlock code LG U8150 1- Power phone on with non-accepted SIM card 2- Dial 277634#*# 3- Select SIM Lock 4- Dial unlock code at prompt How to enter unlock code LG U400 1- Power phone on with accepted SIM card 2- Dial 2945#*88110# 3- Phone will show 'Unlock sim'. Press OK. 4- Phone will show 'Network Unlock'. Press OK. 5- Phone will then show 'Input Network Control Key'. 6- Dial unlock code and press OK. If you receive a 6 digit code enter 2 zero’s after the 6th digit. If you receive a 7 digit code, enter 1 zero after the 7th code 7- Code accepted message will appear Other Models 1- Switch ON your phone with non-accepted SIM card 2- Dial: How to enter unlock code LG 510w - 2945#*5101# How to enter unlock code LG 1200 & B1200- 1945#*5101# How to enter unlock code LG 5200 & 52200 - 2945#*5221# How to enter unlock code LG 5300 - 2945#*5301# How to enter unlock code LG 5400 - 2945#*5401# How to enter unlock code LG 7020 - 2945#*70001# How to enter unlock code LG 7100 - 2945#*7101# How to enter unlock code LG 1100 - 2945#*1201# or 2945#*70001# How to enter unlock code LG7250T - 2945#*70001# How to enter unlock code LG C2200 - 2945#*2201# How to enter unlock code LG T5100 - 2945#*5301# How to enter unlock code LG C3310 - 2945#*3311# 3- Go to Menu => Settings 4- Select Security 5- Select Network Provider and select De-activate 6- Dial unlock code 1- Power phone on with accepted SIM card 2- Dial: How to enter unlock code LG C3100 - 2945#*3101# How to enter unlock code LG C3380 - 2945#*7101# How to enter unlock code LG F2300 - 2945#*7101# How to enter unlock code LG KE260 - 2945#*2601# How to enter unlock code LG KE970 - 2945#*9701# How to enter unlock code LG KG120 - 2945#*1201# How to enter unlock code LG KG220 - 2945#*1201# How to enter unlock code LG KG240 - 2945#*3311# How to enter unlock code LG KG280 - 2945#*7101# How to enter unlock code LG KG290 - 2945#*7101# How to enter unlock code LG KG800 - 2945#*7101# How to enter unlock code LG KU250 - 2945#*250# How to enter unlock code LG KU380 - 2945#*380# 3- Go to Settings => Security => SIM lock 4- Dial NCK unlock code and press OK 1- Switch ON your phone with non-accepted SIM card 2- Dial: How to enter unlock code LG KU311 - 815118#*# How to enter unlock code LG KU800 - 82652#*# How to enter unlock code LG L600v - 815118#*# How to enter unlock code LG U8150 - 277634#*# How to enter unlock code LG U8210 - 277634#*# How to enter unlock code LG U8500 - 277634#*# How to enter unlock code LG U400 - 2945#*88110# How to enter unlock code LG KC550 - 2945#*71001# How to enter unlock code LG KU580 - 2945#*580# How to enter unlock code LG KT520 - 2945#*520# How to enter unlock code LG KF750 - 2945#*750# How to enter unlock code LG KF600 - 2945#*71001# How to enter unlock code LG KG275 - 2945#*20001# How to enter unlock code LG KU380 - 2945#*380# How to enter unlock code LG KU311 - 815118#*# How to enter unlock code LG KU800 - 82652#*# How to enter unlock code LG L600v - 815118#*# How to enter unlock code LG U8150 - 277634#*# How to enter unlock code LG U8210 - 277634#*# How to enter unlock code LG U8500 - 277634#*# How to enter unlock code LG C3100 - 2945#*3101# How to enter unlock code LG C3380 - 2945#*7101# How to enter unlock code LG F2300 - 2945#*7101# How to enter unlock code LG KE260 - 2945#*2601# How to enter unlock code LG KG120 - 2945#*1201# How to enter unlock code LG KG220 - 2945#*1201# How to enter unlock code LG KG240 - 2945#*3311# How to enter unlock code LG KG280 - 2945#*7101# How to enter unlock code LG KS500 - 2945#*500# How to enter unlock code LG KP270 - 2945#*270# How to enter unlock code LG KF240 - 2945#*240# or 2945#*2401# How to enter unlock code LG KG290 - 2945#*7101# How to enter unlock code LG KU250 - 2945#*250# 3- Dial unlock code and press OK |
how to enter lg unlock code for LG A200 hi, plz i need to know how to enter the unlock code for LG A200 french SFR Thank you |
2945#*200# with original sim |
Lg A200 Unlock Code Entry Instructions: Put In a non allowed SIM card and turn on your Lg A200 phone (A sim from a different network other than the phone is restricted too). The Phone will display "phone restricted" Enter Unlock code and Select Ok. Your Lg A200 will be unlocked. 2945#*200# with original sim |
Please would you help me unlock code for LG GT365 How to enter unlock code LG GT350 1- Power on phone with accepted SIM card 2- Dial 2945#*350# 3- Select SIM unlock => Network Unlock 4- Dial unlock code (make sure dial settings are set to real skin) Phone no active |
Lg gt 550??? please... |
how about L-04C how can i enter the unlock code.?thanks.. |
how about L-04C how can i enter the unlock code.?thanks.. please help me |
how to enter in LGL35G in nck code any one knows how to enter in LGL35G in nck code |
how to enter NCK code to LG kc550 |
insert sim not orignal press 2945#*71001# for kc 550 |
and it not work friend. Have you any solution.? |
How to enter unlock code lg p705g |
lg enter code For : LG 510w enter 2 9 4 5 # * 5 1 0 1 # LG 1200 enter 1 9 4 5 # * 5 1 0 1 # LG B1200 enter 1 9 4 5 # * 5 1 0 1 # LG 5200 enter 2 9 4 5 # * 5 2 2 1 # LG 52200 enter 2 9 4 5 # * 5 2 2 1 # LG 5300 enter 2 9 4 5 # * 5 3 0 1 # LG 5400 enter 2 9 4 5 # * 5 4 0 1 # LG 7020enter 2 9 4 5 # * 7 0 0 0 1 # LG 7100 enter 2 9 4 5 # * 7 1 0 1 # LG 1100 enter 2 9 4 5 # * 1 2 0 1 # or 2 9 4 5 # * 7 0 0 0 1 # LG 7250T enter 2 9 4 5 # * 7 0 0 0 1 # LG C2200 enter 2 9 4 5 # * 2 2 0 1 # LG T5100 enter 2 9 4 5 # * 5 3 0 1 # LG C3310 enter 2 9 4 5 # * 3 3 1 1 # LG C3100 enter 2 9 4 5 # * 3 1 0 1 # LG C3380 enter 2 9 4 5 # * 7 1 0 1 # LG F2300 enter 2 9 4 5 # * 7 1 0 1 # LG KE260 enter 2 9 4 5 # * 2 6 0 1 # LG KE970 enter 2 9 4 5 # * 9 7 0 1 # LG KG120 enter 2 9 4 5 # * 1 2 0 1 # LG KG220 enter 2 9 4 5 # * 1 2 0 1 # LG KG240 enter 2 9 4 5 # * 3 3 1 1 # LG KG280 enter 2 9 4 5 # * 7 1 0 1 # LG KG290 enter 2 9 4 5 # * 7 1 0 1 # LG KG800 enter 2 9 4 5 # * 7 1 0 1 # LG KU250 enter 2 9 4 5 # * 2 5 0 # LG KU380 enter 2 9 4 5 # * 3 8 0 # LG KU311 enter 8 1 5 1 1 8 # * # LG KU800 enter 8 2 6 5 2 # * # LG L600v enter 8 1 5 1 1 8 # * # LG U8150 enter 2 7 7 6 3 4 # * # LG U8210 enter 2 7 7 6 3 4 # * # LG U8500 enter 2 7 7 6 3 4 # * # LG U400 enter 2 9 4 5 # * 8 8 1 1 0 # LG KC550 enter 2 9 4 5 # * 7 1 0 0 1 # LG KU580 enter 2 9 4 5 # * 5 8 0 # LG KT520 enter 2 9 4 5 # * 5 2 0 # LG KF750 enter 2 9 4 5 # * 7 5 0 # LG KF600 enter 2 9 4 5 # * 7 1 0 0 1 # LG KG275 enter 2 9 4 5 # * 2 0 0 0 1 # LG KU380 enter 2 9 4 5 # * 3 8 0 # LG KU311 enter 8 1 5 1 1 8 # * # LG KU800 enter 8 2 6 5 2 # * # LG L600v enter 8 1 5 1 1 8 # * # LG U8150 enter 2 7 7 6 3 4 # * # LG U8210 enter 2 7 7 6 3 4 # * # LG U8500 enter 2 7 7 6 3 4 # * # LG C3100 enter 2 9 4 5 # * 3 1 0 1 # LG C3380 enter 2 9 4 5 # * 7 1 0 1 # LG F2300 enter 2 9 4 5 # * 7 1 0 1 # LG KE260 enter 2 9 4 5 # * 2 6 0 1 # LG KG120 enter 2 9 4 5 # * 1 2 0 1 # LG KG220 enter 2 9 4 5 # * 1 2 0 1 # LG KG240 enter 2 9 4 5 # * 3 3 1 1 # LG KG280 enter 2 9 4 5 # * 7 1 0 1 # LG KS500 enter 2 9 4 5 # * 5 0 0 # LG KP270 enter 2 9 4 5 # * 2 7 0 # LG KF240 enter 2 9 4 5 # * 2 4 0 # or 2 9 4 5 # * 2 4 0 1 # LG KG290 enter 2 9 4 5 # * 7 1 0 1 # LG KU250 enter 2 9 4 5 # * 2 5 0 # LG newer models enter 2 9 4 5 # * 7 1 0 0 1 # Miscellaneous access code rules Some LG phones adopted a simple rule to access the hidden menu, as follows: 2 9 4 5 # * Phone_Model_Number # Or 2 9 4 5 # * Phone_Model_Number 1 # Where Phone_Model_Number is the numbers in your phone model. (If it's only 3 digits, add a 1 to the end) Here are some examples KE970 = 2 9 4 5 # * 9 7 0 1 # KE260 = 2 9 4 5 # * 2 6 0 1 # KU990 = 2 9 4 5 # * 9 9 0 # However, for many newer models, the most common hidden menu access code method is simply entering 2 9 4 5 # * 7 1 0 0 1 #. |
