08-08-2011, 01:09 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Free Palestine
Member: 330579 Status: Offline Thanks Meter: 67,512 | How to enter Unlock Code on LG Electronics For the following models you must insert an accepted SIM Card and then: LG C3100 press 2945#*3101# LG C3380 press 2945#*7101# LG F2300 press 2945#*7101# LG KE260 press 2945#*2601# LG KE970 press 2945#*9701# LG KF390 and KF390q *#865625# LG KF600 press 2945#*71001# LG KF755d press 2945#*755# (you need to insert a not-allowed SIM card instead and then enter the sequence to enter the code) LG KG120 press 2945#*1201# LG KG220 press 2945#*1201# LG KG240 press 2945#*3311# LG KG280 press 2945#*7101# LG KG290 press 2945#*7101# LG KG800 press 2945#*7101# LG KP210a press 2945#*71001# ( (you need to insert a not-allowed SIM card instead and then enter the sequence to enter the code) LG KP500 press 2945#*71101# LG KP265 press 2945#*265# LG KU250 press 2945#*250# LG KU380 press 2945#*380# LG TE365 press 2945#*365# (you need to insert a not-allowed SIM card instead and then enter the sequence to enter the code) Next, a secret menu will appear, go to settings-security-sim lock, enter NCK and press OK. For the following models you must insert a not-allowed SIM and then: LG KS360 press 2945#*71001# LG KU311 press 815118#*# LG KU800 press 82652#*# LG L600v press 815118#*# LG U8150 press 277634#*# LG U8210 press 277634#*# LG U8500 press 277634#*# Enter NCK and press OK. For the following models you must insert a not-allowed SIM and then: LG KS360 press 2945#*71001# LG KU311 press 815118#*# LG KU800 press 82652#*# LG L600v press 815118#*# LG U8150 press 277634#*# LG U8210 press 277634#*# LG U8500 press 277634#*# Enter NCK and press OK. How to Enter Unlock Codes on LG KP100: 1) Insert a not allowed SIM card 2) Press the unlock button 3) Enter the code OR 1. Insert allowed SIM. 2. Booting (Request PIN Code, PIN Code enable) 3. In Idle Screen, Input the hidden number (2945#*20001#) 4. Input the number (above), go back to the idle screen 5. Menu-4.Settings, 7.Security-6.SIMLock Code:-1.Network Unlock Code:-1.Deactivate: 6. Select “1.Deactivate:” Menu, Display pop up “ SIM Lock Code:”. 7. Input right Unlock code, Display pop up “Deactivate". 8. Reboot, and unlock simlock code How to Enter Unlock Codes on LG KF390 and KF390q: 1) Insert a SIM Card from the network the mobile is locked to and turn it on 2) Insert the following sequence *#865625#; 3) Select 'Unlock USIM' 4) Select 'Network Lock' 5) Insert the unlock code 6) Reinsert the unlock code 7) Select OK. Done! How to Enter Unlock Codes on LG ***** (e.g KE850, etc): Switch the telephone on with Original SIM card inside. Enter SIM pin if required. Enter 2945#*8501# and press the call button (middle button bottom of the screen). SIM unlock mode will appear on screen. Enter unlock code Select Reboot. Switch phone off, and then turn back on again. Phone is now unlocked How to Enter Unlock Codes on LG KE990 / KU990 Viewty: Insert original sim card and turn phone on. Press telephone icon at bottom of screen to bring up the phone keypad Enter 2945#*990# A menu will pop up, select sim unlock: Another menu will appear, select Network lock. Enter your unlock code and press ok The phone will then reboot and the unlock is complete. How to Unlock LG KG245 (Vodafone Australia): Insert a Vodafone Australia working SIM card. Ensure the phone is charged and then switch the phone on. Optional Step: If the SIM card has a PIN, enter your PIN number Wait for the phone to power up then enter 2945#*7101# Select Menu , then go to Settings > Security > SIM Lock > Network Select Deactivate and enter the 8-digit unlocking code provide for your handset. The handset will be unlocked automatically and will display “Done”. This will be confirmed if you can make and receive calls with the Non-Vodafone Australia SIM card. (You will need reception and phone credit with the different network provider) How to Unlock LG KG800 or TG800 Chocolate: With the phone in standby, enter 2945#*7101#. This will activate the extra menu. Go to: Settings>Security>SimLock>Network Select deactivate. Enter the unlock code How to Unlock LG C2000: Insert non-Cingular SIM card Power on the handset - phone will display "phone restricted" Select "Cancel" - phone will display "phone restriction code" Enter the SIM Unlock code Select "OK" - the handset is now successfully unlocked How to Enter Unlock Codes on LG F2250: With allowed sim card in the start menu type: 2945#*3311#. Handset shows saved, then return to startup screen Press Menu key, choose Settings > Security > Sim Lock> Network > Deactivate, handset will now show 'Enter NCK' Enter your unlock code How to Enter Unlock Codes on LG U8150: Switch ON your phone with a not allowed SIM card. Compose: 277634#*#. Go to menu "SIM Lock". Enter the unlock code How to Enter Unlock Codes on LG U8110: With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*# Select 'Sim Unlock' menu # Enter NCK code, then validate Your phone is now unlocked. How to Enter Unlock Codes on LG U8210: With a not allowed sim card enter Pin code then validate, type: 277634#*# Shows test menu Choose sim test menu and type: 2945#*#, choose Sim Unlock menu Handset shows 'Enter NCK' Enter code and then hit OK. How to Enter Unlock Codes on LG U81xx: To bring up the unlock menu on the phone with a SIM card, type 2945#*88110# Enter the code In case you need to reset the phone without a SIM card first, type 277634#*# or 47328545454#. How to Enter Unlock Codes on Cingular AT&T LG CU575 TRAX: Insert non-Cingular SIM card. Power on the handset. Phone will display "Invalid SmartChip" Now enter *#865625# then select option 1 and then again select 1 and enter your code How to Enter Unlock Codes on Cingular AT&T LG CU500/CU400: Insert non-Cingular SIM card. Power on the handset. Phone will display "Invalid SmartChip" (IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN) In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5 Enter the 8 digit SIM unlock code Select "OK". The handset is now successfully unlocked. How to Enter Unlock Codes on Cingular AT&T LG CU515: Insert non AT&T SIM Turn on the phone Phone says invalid smart chip Enter *#865625# Yes to Unlock Enter your 16 digit unlock code. How to Enter Unlock Codes on all other LG cell phones: Switch ON your phone with an allowed SIM card Then compose: 2945#*5101# - (if you have a LG 510w) 1945#*5101# - (if you have a LG 1200 & B1200) 2945#*5221# - (if you have a LG 5200 & 52200) 2945#*5301# - (if you have a LG 5300) 2945#*5401# - (if you have a LG 5400) 2945#*70001# - (if you have a LG 7020) 2945#*7101# - (if you have a LG 7100) 2945#*1201# or 2945#*70001# - (if you have a LG 1100 or 1150) 2945#*70001# - (if you have a LG7250T) 2945#*2201# - (if you have a LG C2200) 2945#*5301# - (if you have a LG T5100) 2945#*3311# - (if you have a LG C3310) Go to "Menu" and then to "Settings" Then select "Security" To finish select "Network Provider" and select "Deactivate" Enter the unlock code If your cell phone is not listed, please follow instructions for LG C2000 above How to Enter Unlock Codes on LG U400 Shine (2 codes needed): Insert the network SIM in the handset which works with the phone (from the locked carrier). Enter 2945#*9636#. The phone will then prompt 'Unlock sim'. Press OK. The phone will then prompt 'Network Unlock'. Press OK. The phone will then prompt- 'Input Network Control Key'. Enter the 8 digit unlocking code, Press OK. If the unlocking code comes with only 7 digits, add a 0 in front of the 7 digit code. If the unlocking code comes with only 6 digits, add 00 in front of the 6 digit code. If you received a 16 digit code, enter it. The phone will have space for it. It should give you the message: Success. Come back to the main screen and Enter 2945#*9636#. The phone will then prompt unlock sim. Press OK. The phone will then prompt Network Unlock/ Lock but if you scroll down you will see a message Enter SP Lock. Enter SP Code. How to Enter Unlock Codes on LG KE970 Shine: Insert original sim card and turn phone on. Press telephone icon at bottom of screen to bring up the phone keypad Enter 2945#*990# A menu will pop up, select sim unlock Enter your unlock code and press ok The phone will then reboot and the unlock is complete. OR Switch ON your phone with an allowed SIM card Then compose: 2945#*9701# Press CALL. It should you ask you for the code How to Enter Unlock Codes on LG TU720 Shine Put in a non-allowed SIM, phone says invalid SIM card (or insert original SIM and proceed to step 2) Now enter *#865625# then enter your 16 digits code OR Insert the original network SIM Enter 2945#*88110#. The phone will then prompt ' Unlock sim'. Press OK. The phone will then prompt 'Network Unlock'. Press OK. The phone will then prompt- 'Input Network Control Key'. Enter the 8 digit unlocking code. Press OK. If the unlock ing code comes with only 7 digits, add a 0 in front of the 7 digit code. If the unlocking code comes with only 6 digits, add 00 in front of the 6 digit code. It should give you the message Success. Come back to the main screen and Enter 2945#*88110#. The phone will then prompt unlock sim. Press OK. The phone will then prompt Network Unlock/ Lock but if you scroll down you will see a message Enter SP Lock. Enter SP Code. Then press OK. How to Unlock LG (other models not listed in the above guide): Insert not-allowed SIM card Power on the handset- phone will display "phone restricted" Select "Cancel" - phone will display "phone restriction code" Enter the SIM unlock code Select "OK" - the handset is now successfully unlocked Regards Haicha |
The Following 13 Users Say Thank You to Haicha For This Useful Post: |
11-24-2015, 08:50 | #3 (permalink) |
Junior Member Join Date: Jun 2014
Member: 2213550 Status: Offline Thanks Meter: 1 | hi thanks for samsung sgh i897 unlock code. and another have a problem i have a lg 320g tracfone the imie is 01210900141408004 please help me again to unlock my phone it is 3 years not used this phone because of unlock code thanks again and *** bless you always |
The Following User Says Thank You to virus0130 For This Useful Post: |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
