how enter unlock(nck) code in g440 1 Attachment(s) please help me any one how enter nck code in lg 440 i have code but not able to enter i tired this code Dial 2945#*71001# and 2945#*440# not work for me please give me solution how enter unlock code LG 440G Tutorials |
show on display after insirt sim simlock code-1 |
Pls help me same problem me get code but how to enter |
same problem here . Any solution ????? |
Option 1 method - LG Models To enter your unlock code, LG phones often require access to a hidden menu first. To access this menu simply enter the digits 2 9 4 5 # * 7 1 0 0 1 #. 1. Insert an original SIM card and turn the phone on 2. Access the hidden menu by typing 2 9 4 5 # * 7 1 0 0 1 # 3. Select 'Menu' and then 'Settings' 4. Next, select 'Security' 5. Select 'Network Provider' and 'Deactivate' 6. Finally enter the Unlocking Code provided. (Please note: Some phones require a slightly different access code - please see the list below if the above access code doesn't work for your phone.) Option 2 method - LG Models 1. Insert a not accepted SIM Card and switch your LG phone 2. The phone will display 'phone restricted'. 3. Select Cancel 4. The phone will display 'phone restriction code'. 5. Enter the Unlock code provided 6. Select OK 7. Your LG will now be now unlocked |
The LG 440g is HARDLOCKED. Even if you try to enter the code the phone will not accept it. |
that means!!!!! Start the device with an accepted simcard (example LG 440G was bought in Orange you need to insert an Orange card) |
