Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > LG
Old 12-22-2009, 19:18   #1 (permalink)
Member: 447187
Thanks Meter: 107
How to flash dead Ks360
Hi, i need help for flash Ks360 dead with interface Infinity or furious if possible, thanks.
Old 12-23-2009, 20:38   #2 (permalink)
nasirahmed's Avatar
Member: 57760
Sonork: 100.1579298
Thanks Meter: 3,510
http://forum.gsmhosting.com/vbb/showthread.php?t=675647
Read the flashing procedure of KP500. Its same thing for KS360, you just have to select flash file and dll for KS360 instead of KP500.
Old 12-23-2009, 21:27   #3 (permalink)
moussa djamel's Avatar
Member: 296018
Thanks Meter: 74
and select com with cable ke500 and interface infi..furious...ustpro...universell box
Old 02-01-2010, 09:10   #4 (permalink)
Member: 953149
how to flash LG Ks360 using FG box
if any one knws plz help me ,, also can u all give me the software for it
Old 02-02-2010, 07:49   #5 (permalink)
nasirahmed's Avatar
Member: 57760
Sonork: 100.1579298
Thanks Meter: 3,510
KS360 flashing not supported with FG.
Old 02-04-2010, 11:17   #6 (permalink)
Member: 953149
then 4m wt i should do plzz
Old 02-04-2010, 19:11   #7 (permalink)
nasirahmed's Avatar
Member: 57760
Sonork: 100.1579298
Thanks Meter: 3,510
You can use GSMulti and original firmware to flash KS360. Can be done with USB cable or you can use your FG box as a COM interface.
Old 02-06-2010, 05:55   #8 (permalink)
Member: 953149
4m where i can dwnload GSMulti
Old 02-06-2010, 06:23   #9 (permalink)
nasirahmed's Avatar
Member: 57760
Sonork: 100.1579298
Thanks Meter: 3,510
http://rapidshare.com/files/32469810...SMULTI_V30.zip
Old 02-11-2010, 13:24   #10 (permalink)
Member: 275689
Thanks Meter: 64
do i just use a normal LG USB cable to flash it? and also can you please provide some instructions with this. thnx
Old 02-12-2010, 16:43   #11 (permalink)
Member: 1152099
Thanks Meter: 11
Can you gives us a different link and the flash file, this is not working for me. PLZZZZZZZZ
Thanks.
Old 06-27-2011, 15:19   #12 (permalink)
aitta7130's Avatar
Member: 320655
Thanks Meter: 28
Loading module , please wait...
PMB8888 Module 2.1 started. SW: Ver 3.6.0.0
Connecting to LG KS360 in UART Mode (COM5 ,921600)
Please reconnect battery, press and hold power button...
Phone found! (MCU:PMB8888) prebooting...
Release power button. Booting...
Reading info...
Flash ID: 0000
Force boot mode on!
Finished in 18 seconds
Opening "KS360AT-00-V10e-EUR-XX-SEP-10-2008+0.bin"...
Writing Firmware...
Sending SEC pack...
Writing done!
Finished in 109 minutes 16 seconds.
Disconnected.
TIP: Please reconnect phone battery / power source.
with z3x
Old 06-27-2011, 18:47   #13 (permalink)
dkaluba74's Avatar
Member: 703394
Thanks Meter: 47
Reading info...
Flash ID: 0000
Force boot mode on!
Writing Firmware...
Sending SEC pack...
Writing done!
Disconnected.
with z3x
Is that how long it took?
Old 06-28-2011, 20:00   #14 (permalink)
nasirahmed's Avatar
Member: 57760
Sonork: 100.1579298
Thanks Meter: 3,510
Yes, if you use UART mode (box cable). USB flashing need not more than 10 min.
How to repair dead ks360 luyanda LG Hardware Repair 0 02-20-2010 09:07
how to flash LG Ks360 using Z3X box jorey LG Hardware Repair 1 01-28-2010 14:15
how to flash LG KS360 with HWK? mrphuc HWK 0 05-26-2009 20:40
How to flash dead nokia phones with jaf usb flashing tiju kkm Nokia Hardware & Hardware Repair 0 01-24-2009 20:58
to the MASTERS how to flash dead V980 jawad8305 Motorola P2k 0 11-26-2006 15:54
Page generated in 0.24209 seconds with 9 queries
