11-02-2012, 08:13 | #1 (permalink) |
Insane Poster Join Date: Mar 2008
Member: 736553 Status: Offline Sonork: 000957 Thanks Meter: 19 | how to flash lg E900 2. Install LG United Modem Driver, connect the phone to PC through USB cable and let the drivers to be installed. USB 1.1 is recommended. 3. You'll need firmware in DZ format and the correct DLL for your model. 4. Open LGDP2_V36_UMTS from C:\DOWNLOAD, select UMTS in Division and click OK. 5. Select port (check Device Manager for LG USBModem Port number), you can set a range from easy select or select manually. Select DLL '(LGE900_101009_MP.dll)and select firmware( LG-E900AT-00-V10j-234-15-FEB-07-2011+0.dz)in Downlaod Configuration. Click OK.(you can download firmware from hwk site) 6. Click START in main window and connect the phone to USB cable in Emergency download mode(VOL+CAM+PWR). |
11-03-2012, 13:30 | #2 (permalink) |
Member: 736553 Status: Offline Sonork: 000957 Thanks Meter: 19 | download here LGDP2_V36_UMTS download and copy to 'c' drive then install lg united modem driver Last edited by LELINE_1; 11-03-2012 at 13:39. |
09-20-2014, 11:47 | #4 (permalink) | |
Freak Poster Join Date: Jun 2012
Member: 1776947 Status: Offline Sonork: 100.1659966:tjjxxs Thanks Meter: 74 | password Quote:
