Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > LG
Old 11-27-2013, 13:17   #1 (permalink)
Member: 300043
Thanks Meter: 360
How to get LG flashfiles direct from .kdz
download LGExract from [TOOL] LGExtract 0.2.1 - xda-developers
download .kdz from
hxxp://csmg.lgmobile.com:9002/csmg/b2c/client/auth_model_check2.jsp?esn=xxxxxxxxxxxxxxx
replace xxxxxxxxxxxxxxx with your own imei of-course.
(kdz files not available for some models.)
put LGExtract.exe and your kdz file into one folder,
from inside this folder hold down shift key and and right click anywhere,
from the context menu click "Open command window here"
in command prompt type in:
LGExtract -kdz filename.kdz
and then press enter.
wait till you see "File(s) successfully extracted!"
unextract the .cab file using winrar or 7zip
LGExtract -wdb filename.wdb Inf_WebDnld.dll
Old 11-28-2013, 20:29   #2 (permalink)
Member: 300043
Thanks Meter: 360
download .kdz from
and you can check the service provider for your imei here:
hxxp://csmg.lgmobile.com:9002/svc/popup/model_check.jsp?esn=xxxxxxxxxxxx
look at <buyername> field. (so you can check the firmware's branding/region)
Old 09-11-2015, 02:15   #3 (permalink)
Member: 2457182
I know this is years old , but...
I bricked my LG F320S (G2)
I converted the kdz to cab but when I went to extract the cab it said the file is damaged or something. I'm guessing the kdz didn't download properly?
The Following User Says Thank You to klavins For This Useful Post:
Old 11-03-2017, 22:31   #4 (permalink)
Member: 1844330
Thanks Meter: 4
lgextractor
thanks LBOZ_GSM
1-LGExtract -kdz name of flash file with kdz extention(as :LGExtract -kdz US73011b_03.S11b_03.P15107.kdz)
2-result of 1 is a file as:LG730ZV8_05.S8_00.P61009.cab
3-extract LG730ZV8_05.S8_00.P61009.cab by winrar here
4-LGExtract -wdb name of flash file with wdb name of flash file with dll
asLGExtract -wdb US73011b_03.S11b_03.P15107.wdb US73011b_03.dll).
thanks LBOZ_GSM
Page generated in 0.16211 seconds with 9 queries
