[How To] LG Km900 Flashing (all Files included) As I was loohing quite a while for all Files and had to test several Infos abozut how to Flash the LG Km900... I`ll share my knowledge about how to flash this one. First you need to install the following Files: 1. LG PC-Suite III- you can get it from the LG-Site or here! 2. Install Infineon-Flash-Driver Install both and connect turned on Handy. Use PC-Suite-Mode on the Handy to install correct driver. Now remove Handy and remove the Accu. Connect the Handy without Accu to the PC. Now the FlashDriver should be installed (you can check in your PC-Hardware-list for some seconds). Remove Handy now. Now you need to get Flasher and working FlashFile: 1. You can find Flasher here! 2. You need a Flashfile in "Cab"-Format (not .kdz). You can find latest Open Europe here (its V10I_06) Now we can start: 1. Start KP500-Utils-EN.exe and connect the Handy 2. You should see this screen: http://img35.imageshack.us/img35/8740/lgflasher.jpg Only enter the text inside the "" for the follwing steps: 3. You choose "i" and enter 4. You enter PhoneModell "KM900" and press Enter 5. Now you enter exact Position of FlashFile. If you have put the File into same directory as the Flasher is located you need just to type the Filename: "V10I_06.cab" and Enter 6. Now you enter Firmware-Name. For my file you enter "V10I_06" and press Enter Now and Window should open with the Flasher... Just follow the options (they differ from the FW-Version on your Handy, so dont worry). Flashing takes 20-40 Minutes. Don`t disconnect the Handy while Flashing... or it`s dead... After all you need to do an factory-Reset: Just type: "1809#*900#" and Choose Factory Reset |
gooooooooooooood job |
2 Attachment(s) Quote:
http://forum.gsmhosting.com/vbb/show....php?p=4831335 Flash with GSMULTI 3.0 Hassle free ;) |
i have LG KM900 only show logo LG when i connected to usb nothing happen br |
Connect the phone to USB cable without Battery, should ask for Flash Loader Utility driver. |
Sahil you don't have images in C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\image ! |
but what u mean by accu ?? |
pls help me i cant flash by this procedure |
Please check here for the procedure to flash with original flasher. Fimrware and DLL also posted in different thread. Do a search. http://forum.gsmhosting.com/vbb/f177...orial-1176882/ |
thinks pro for sharing |
my lg km900 is not going to lg plz help me sir how will go to |
Best Regards |
