11-27-2013, 13:17 | #1 (permalink) |
No Life Poster Join Date: Jun 2006
Member: 300043 Status: Offline Thanks Meter: 360 | How to get LG flashfiles direct from .kdz download .kdz from hxxp://csmg.lgmobile.com:9002/csmg/b2c/client/auth_model_check2.jsp?esn=xxxxxxxxxxxxxxx replace xxxxxxxxxxxxxxx with your own imei of-course. (kdz files not available for some models.) put LGExtract.exe and your kdz file into one folder, from inside this folder hold down shift key and and right click anywhere, from the context menu click "Open command window here" in command prompt type in: LGExtract -kdz filename.kdz and then press enter. wait till you see "File(s) successfully extracted!" unextract the .cab file using winrar or 7zip in command prompt type in: LGExtract -wdb filename.wdb Inf_WebDnld.dll and then press enter. wait till you see "File(s) successfully extracted!" |
11-28-2013, 20:29 | #2 (permalink) | |
Member: 300043 Status: Offline Thanks Meter: 360 | Quote:
hxxp://csmg.lgmobile.com:9002/svc/popup/model_check.jsp?esn=xxxxxxxxxxxx look at <buyername> field. (so you can check the firmware's branding/region) | |
09-11-2015, 02:15 | #3 (permalink) |
Junior Member Join Date: Sep 2015
Member: 2457182 Status: Offline Thanks Meter: 1 | I know this is years old , but... I bricked my LG F320S (G2) I converted the kdz to cab but when I went to extract the cab it said the file is damaged or something. I'm guessing the kdz didn't download properly? |
The Following User Says Thank You to klavins For This Useful Post: |
11-03-2017, 22:31 | #4 (permalink) |
Junior Member Join Date: Nov 2012
Member: 1844330 Status: Offline Thanks Meter: 4 | lgextractor thanks LBOZ_GSM 1-LGExtract -kdz name of flash file with kdz extention(as :LGExtract -kdz US73011b_03.S11b_03.P15107.kdz) 2-result of 1 is a file as:LG730ZV8_05.S8_00.P61009.cab 3-extract LG730ZV8_05.S8_00.P61009.cab by winrar here 4-LGExtract -wdb name of flash file with wdb name of flash file with dll asLGExtract -wdb US73011b_03.S11b_03.P15107.wdb US73011b_03.dll). thanks LBOZ_GSM |
