Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > LG
Old 04-12-2005, 13:10   #1 (permalink)
sutiee's Avatar
Member: 93717
Installing Usb Drivers For Lg Flasher?
I am trying to flash 8120, but i get the following error
error occurred while port changing from uart to usb
How do I install usb drivers because windows never says found new hardware for me to point to the drivers folder.
Please help me and I have spent at least 2 hours searching forum, so please don't say search forum.
Old 04-12-2005, 13:48   #2 (permalink)
Crazy Poster
Member: 92431
Cool
To uninstall or update go to control panel/system/device manager/
Select the controller and Right Click for the options
hope that helps.....
Old 04-12-2005, 15:59   #3 (permalink)
4R
4R's Avatar
Member: 15800
freind the drivers are inside of the folder ol lg..
Old 04-12-2005, 16:06   #4 (permalink)
sutiee's Avatar
Member: 93717
I can't install because windows doesn't ask for drivers at any time.
Old 04-12-2005, 16:09   #5 (permalink)
sutiee's Avatar
Member: 93717
Thanks
but i know the drivers are in the lg Epacomm folder but how do you install them when windows never says new hardware found so i cannot point to the folder with the drivers.
Old 04-12-2005, 16:43   #6 (permalink)
Member: 37317
hi
make sure your cable is correct...i had similar problem when I was building my own cable ...but once I connect all the wires in the right way - windows immediately found new hardware
good luck
Old 04-12-2005, 17:21   #7 (permalink)
sutiee's Avatar
Member: 93717
Thanks
I will try to get new cable, I was trying with cable that came with furious2. It seems it is a cable problem, I tried to flash a different phone and had the same problem.
Old 04-12-2005, 17:38   #8 (permalink)
blaiseid's Avatar
Member: 37735
Originally Posted by sutiee
Thanks
I some times have the same problem but just try and try.I always use my cable to flash the U series but for some of theme it s not easy to install DRIVERS.For, when it reach the time of changing port com to USB, there is an error MESSAGE, dont CANCEL that Error message, wait for some seconds, the INSTALLATION WINDOW will open and will ask you to install the DRIVERS, Install your drivers and dont close the first error message .When Drivers installation is DONE,close that error message and RUN your flasher.
Good luck.
Wassalam
Old 04-13-2005, 11:22   #9 (permalink)
sutiee's Avatar
Member: 93717
Thanks to everyone esp blaiseid
After I keep trying many times. at least 20, eventually windows detected new hardware and i was able to install drivers and my 8120 v105 is now unlocked. I didn't change cable by the way.
how to install usb driver for ufs tornado gsmdz UFS2 + UFS3-Tornadoflasher 4 10-14-2010 16:04
All usb driver for lg 3g phones themobileshop FuriouS TeaM Products 1 02-24-2009 12:41
ı need usb driver for lg creative LG 4 04-03-2006 21:48
USB driver for LG 8120 stojsins LG 0 03-15-2005 06:59
Page generated in 0.35088 seconds with 11 queries
