Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > LG
Old 09-01-2009, 18:03   #1 (permalink)
evolutions's Avatar
Member: 863844
Sonork: 100.1587943
kp 170 no signal after unlock
I HAVE GOT KP170, AFTER I UNLOCKED IT ON VYGUIS BOX IT IS NOT SHOWING ANY SIGNALS. I HAVE FACTORY RESET IT TOO AND FLASHED IT AS WELL. BUT NO LUCK. CAN SOME ONE HELP ME OUT IN THIS PROBLEM..
The Following User Says Thank You to evolutions For This Useful Post:
Old 09-01-2009, 18:17   #2 (permalink)
Member: 1053278
Sonork: 1585387
Originally Posted by evolutions View Post
i have got kp170, after i unlocked it on vyguis box it is not showing any signals. I have factory reset it too and flashed it as well. But no luck. Can some one help me out in this problem..
this mobile is blocked by company of lg ...cplc...
Old 09-02-2009, 08:37   #3 (permalink)
bashir telecom's Avatar
Member: 541511
Sonork: 1583582
100% solution no signal after unlock
flash with furious gold 100% ok
with this file: KP170AT-00-V10g-EUR-XXX-OCT-23-2008+0
tested by me
The Following 4 Users Say Thank You to bashir telecom For This Useful Post:
Old 09-03-2009, 06:53   #4 (permalink)
evolutions's Avatar
Member: 863844
Sonork: 100.1587943
thank you so much, i'll try it
Old 09-03-2009, 23:06   #5 (permalink)
evolutions's Avatar
Member: 863844
Sonork: 100.1587943
the signal never appear even after flash..
Old 10-15-2009, 20:59   #6 (permalink)
Member: 1053278
Sonork: 1585387
Good brother .......... *** bless you !!!!!!!!!!
Old 10-19-2009, 05:18   #7 (permalink)
zakiyyboss's Avatar
Member: 64823
First you need to know which box you unlock IT. if the box make any eeprom backup, then you might get the network again by just flashing the phone with its original eeprom. Else need to read a full LG phone and copy it to your phone.
Cheers and tested 100% work.
The Following User Says Thank You to zakiyyboss For This Useful Post:
Old 11-06-2009, 16:05   #8 (permalink)
Temporary banned !!
Member: 78028
if u have infinity box select model kp 215 and write this file KP170_eeprom_calibration_04.B1E.bin
100% tested
The Following 7 Users Say Thank You to devika For This Useful Post:
Old 11-06-2009, 17:18   #9 (permalink)
evolutions's Avatar
Member: 863844
Sonork: 100.1587943
thanks devika i will try this
Old 11-20-2009, 12:24   #10 (permalink)
Digiview's Avatar
Member: 40975
100% tested
thanks yes 100% success
Old 11-20-2009, 13:10   #11 (permalink)
roney_nexus's Avatar
Member: 288504
Sonork: .:100.1587032:.
100% tested
well post bro.......thx.....
The Following User Says Thank You to roney_nexus For This Useful Post:
Old 02-23-2010, 13:47   #12 (permalink)
.::BHATTI::.'s Avatar
Member: 203158
Sonork: 100.1592032
COM3 [VCP0] selected
module v1.39
Device: LG-KP215
Checking data, wait...
Action: flash write
Skip: Firmware (code)
Skip: File system
Skip: Alchemy data
Write: Eeprom
"smart write" active
Boot ...
Connecting, wait...
Release Power button now !
flash: 01227E223C2200:FEEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb
Boot Done
Set baud ...
921600
Set baud Done
Check flash ...
current eeprom imei: 350305260000001
file saved: C:\Documents and Settings\Farrukh\Desktop\eeprom_350305260000001_LG-KP215_20100223-184608.B1E.bin
Check flash Done
Check space ...
Check space Done
Check parameters ...
Check parameters Done
Erase ...
Erase Done
Write ...
Write: Eeprom
Write Done
Finished, time used: 42 sec
Remove/Install battery now !
Old 03-05-2010, 13:09   #13 (permalink)
hanif007's Avatar
Member: 665441
Sonork: 100.1601130
100% tested
100% working solution tested today
here the log
COM5 [VCP0] selected
module v1.39
Device: LG-KP170 (under test)
Action: flash write
Skip: File system
Skip: Alchemy data
Write: Eeprom
Boot ...
Connecting, wait...
Boot Done
Set baud ...
115200
Set baud Done
Check flash ...
file saved: C:\Program Files\InfinityBox\LGA\eeprom_350305260000001_LG-KP170 (under test)_20100305-182751.B1E.bin
Check flash Done
Check space ...
Check space Done
Erase ...
Erase Done
Write ...
Write: Eeprom
Write Done
Finished, time used: 76 sec
The Following User Says Thank You to hanif007 For This Useful Post:
Old 03-05-2010, 15:12   #14 (permalink)
Member: 270936
100% working solution tested today, for me too thanks.
Old 03-09-2010, 16:13   #15 (permalink)
Member: 652541
not done
ime goes to 00000000000000000
no network comes
reply soon
kp 170 no signal after unlock shoaibrao FuriouS TeaM Products 15 03-02-2012 06:52
error unlock nokia 1112 sw 6.46 phone is no signal after unlock residentdenuevo MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 02-16-2010 07:26
KP-570Q without signal after UNLOCK Diviclaro VygisToolbox 4 06-18-2009 22:33
kp 170 still locked after unlock why chitawira HWK 20 04-21-2009 16:39
E50 Rm-170 no netwok after unlock :( stargsm_ro MT-BOX 4 10-15-2008 19:18
Page generated in 3.25354 seconds with 11 queries
