03-29-2006, 02:28 | #1 (permalink) |
Major Poster Join Date: Mar 2006
Member: 251705 Status: Offline Thanks Meter: 0 | Need an expert to fix it... Please... LGU8330 Now after process, the phone doesn't work anymore. It can not be turned on. It can not be operated with Vygis 1.20 Could you please help me ! I know all of people in here are experts in mobile phones. I appreciate that you're busy so I tried to minimum annoy you by search in the forum and tried many many ways to make it work but couldn't. The lastest solution I think it something involve with test point of the phone LGU8330, but I don't know how to do it (what is testpoint, what do I need to do with it, etc.. ) So could you please take a couple of minutes to help me... please... please... please... Let I tell you what I did: 1. I used the Vygis 1.20. I connected the phone as instructed but the Unlock menu is not accessible 2. Then I did go to "SSW flasher" section, select drive_c.ssw file (certainly for LG U8330) 3. After finished writing, the phone doesn't work anymore. I turned it on but nothing happen, even the screen. 4. Then I write this file U8330_U8330_V20_35635400_full.bif , use the Vygis 1.20 to write it into the phone, but the phone still doesn't work 5. Then I downloaded other files drive_c.ssw, drive_media.ssw, FS_Rec_IT.ssw, U8330_phone_wcdma_4mbram.ssw and wrote them into the phone. It still doesn't work. 6. Then I opened Vygis1.20, the software tell me to turn on, I turn it on. The software said: Loading flashloader...OK Loading certificate loader.... And a window opened: Error: phone not respond Then it said: "Operation failed." I tried it many times but the Vygis still can not operate with the phone 7. I disconected phone from the cable, I press the turn on button, nothing happen. I noticed that a screen was flash (in 1/4 second) and then it all in black. 8. Then I plug the charger into the phone, the screen is turn on and it said charging. But when I press the turn on button, it's freeze. I must remove battery to stop freezing. Now, I don't know what to do. The phone can not be turned on. The Vygis software can not operate with it. I know you are experts in this kind of problem and you have a good mercy. Could you please help me. Please help me.... I'm get lost and hopeless... A person who can help me is only you... You are my last hope.... I just need it work, even locked as before. If you'd like to have any more info, please send me an email ( [email protected]), I'll answer you as soon as possible. Thank you, thank you, thank you King Regard. |
03-29-2006, 04:36 | #2 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Computer Age: 41
Member: 154696 Status: Offline Thanks Meter: 16 | Use this solution : LG U8330 FULL FLASH for repair of dead phones. NOTICE: Can be flashed at 921kb/s (~22 min) YOU NEED TO USE TESTPONT FOR IT Instruction : 1. IWRITE FLASH "LG-U8330_V10_unlocked.bif" AT 921kb/s (~22 min) 2. Press "Unlock" and then "Disconnect" 3. Make Reset cu 47328545454# Phone is unlocked.. Goodluck |
03-29-2006, 06:55 | #4 (permalink) |
No Life Poster Join Date: Jun 2005 Location: India ( Punjab ) / China Age: 38
Member: 154749 Status: Offline Sonork: 100.92483 Thanks Meter: 1,048 | Flash DOWNLOAD HERE LG-U8330_V10_gdfs for flash files thnx to AliWali Testpoint must be connected to GND,when software will ask for this. brother download these files...if u can do test poit here is it Last edited by ..::Mr999::..; 03-29-2006 at 07:07. |
03-29-2006, 21:07 | #5 (permalink) |
No Life Poster Join Date: Apr 2004 Location: Milano, Italy Age: 37
Member: 62336 Status: Offline Thanks Meter: 115 | Think twice the next time With setool "cracked" you can unlock any lg just in seconds without flashing... Now follow the instructions posted by our forum friends and flash it with TP. Be careful, TP can be glued. You can scratch it softly with a screwdriver or any other metal tool . BR |
03-30-2006, 00:41 | #6 (permalink) | ||
Member: 251705 Status: Offline Thanks Meter: 0 | Thank you so much. You have too mercy. Quote:
I'd like to say many thanks to all of you who. Have a nice day Thank you danex_2000 Last edited by getabestdeal; 03-30-2006 at 01:37. | ||
03-30-2006, 01:53 | #7 (permalink) |
Freak Poster Join Date: Jun 2004 Location: no Life Age: 50
Member: 69564 Status: Offline Thanks Meter: 19 | hi sir, relax and drink a coffee, to unlock this phone you need test point already if your phone is dead or power on light only after you make flash the phone this the solution.. steps: 1. make test point in the phone (say in the picture) how? the green line indicate the test point make a wire soldered in the point then make other wire soldered in the gound where is ground? all metal around board inside is a common ground that is the ground. 2. flash the phone using this file i attach.. follow the instruction during flashing if the program say power on then press power button, if say connect test point short the two wires you make then say remove the test point separate the two wires that's all 3. write gdfs 8330 using this file i attach. 4 unlock.. enjoy.... http://rapidshare.de/files/16754576/...ocked.rar.html |
03-30-2006, 02:21 | #9 (permalink) |
Member: 69564 Status: Offline Thanks Meter: 19 | hi my friend, usb smart tool flash the phone with test point.. U8330_V10A_Australia_DRIVEC.zip U8330_V10A_Australia_DRIVEMEDIA.zip U8330_V10A_Australia_FS.zip U8330_V10A_Australia_PHONE.zip note: write gdfs full the unlock... enjoy.... |
03-30-2006, 20:50 | #10 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Scotland, UK
Member: 9719 Status: Offline Thanks Meter: 4 | @getabestdeal exactly what i said really in my email.....lol GND/Ground is basically the metal exposed surrounding the pcb (gold in colour) or any point that is 0v and ground (you can ground to the - battery terminal if you like for example but the metal points exposed on the pcb is easiest for some. WBR |
03-31-2006, 01:51 | #11 (permalink) |
Member: 251705 Status: Offline Thanks Meter: 0 | Thank you so much. All of you are very kind. The phone is alive now. I did what you said and the phone was working (and also unlocked) Yahooooooo! I was really really happy ! (I jumped around my friend and they thought I were crazy or something like that ) Just a small thing: when I press the Menu button -> it go to HomePage, and when I press triangle key -> it go to Menu. But doesn't matter, I can ignore it and use as it is. FINALLY, THANK YOU ! THANK YOU TO ALL OF YOU I'LL NEVER FORGET YOUR HELP BMobile,mr999,Bypx,Danex_2000,daloser... YOU'RE MY BEST FRIEND |
03-31-2006, 01:55 | #12 (permalink) | |
Member: 69564 Status: Offline Thanks Meter: 19 | Quote:
good work friend...congrats... | |
03-31-2006, 08:19 | #14 (permalink) | |
Member: 62336 Status: Offline Thanks Meter: 115 | Quote:
You can reflash original 8330 flashfiles with TestPoint and after this unlock the phone via Patching with setool free. Or just use the phone "as is" and be happy | |
03-31-2006, 09:56 | #15 (permalink) | |
Member: 154749 Status: Offline Sonork: 100.92483 Thanks Meter: 1,048 | Quote:
u did use conversion..files..if u want phone working as 8330..just follow as bypx said.. | |
Nokia N95 8GB i messed with it now i need help to fix it | AndrikoS | GPS devices , Navigators & Maps | 4 | 11-04-2008 17:15 |
HELP PLEASE!!! Problem V200 after codes!!! HELP TO FIX IT!!!! | adanku | Trident/AGERE Platform | 3 | 06-30-2003 06:08 |
need an expert | cokie | VLSI, Conexant, Skyworks and Old Models | 1 | 11-04-2002 23:11 |
8210 5.28 Contact Service, need help to fix it!!! | Penfold | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 08-09-2001 21:44 |
