09-08-2004, 21:12 | #1 (permalink) |
Freak Poster Join Date: Sep 2001 Location: OSIJEK CROATIA Age: 59
Member: 6250 Status: Offline Thanks Meter: 14 | LG 510W no network after flash after flash 510w orange phone is unlocked but no network .How solved this problem? U tray two flash but no result.did anyone traying clone these phones and software for that? br dark |
09-08-2004, 22:10 | #4 (permalink) |
Member: 6250 Status: Offline Thanks Meter: 14 | hi hi moldovan u used FLOADER V2.1 yes sometime in manual search phone find network with all bars on signal strenght but disapear in second.phone before flashing work ok..I think some parameter in eeprom is destroyed. |
09-08-2004, 22:32 | #8 (permalink) |
No Life Poster Join Date: Mar 2003 Location: NCK, Logs, Server
Member: 23684 Status: Offline Sonork: 1582723 Thanks Meter: 684 | Before flashing You must read CalData with Floader v2.1 and store on You computer for easy work {sorry for my English}. Read CalData now , here contains You ORIGINAL IMEI , and MAY BE destroyed RX and TX and Battery calibrations parameters. But I think problem in other place , becauce I repeat: With Floader v2.1 You can,t owerwrite EEPROM and CalData during write standart firmware. WBR |
09-08-2004, 22:41 | #9 (permalink) |
Member: 6250 Status: Offline Thanks Meter: 14 | hi u tray tomorrow read one good 510w and write cal.data to my lg. before flashing u not check sw version so it is possible to incompatibile sw version.if floader dont overwrit cal.data why is phone unlocked after flashing? hovewer thx for help ill traying and post results here br dark |
09-08-2004, 22:48 | #10 (permalink) |
Member: 23684 Status: Offline Sonork: 1582723 Thanks Meter: 684 | CalData contain You ORIGINAL IMEI , and RX and TX and Battery calibrations parameters. Loks located in other place. In Floader box You have button OWCD--owerwrite CalData , but her is inactive.Read and save CalData with orig.IMEI , befere next experiment. WBR Good night. |
09-09-2004, 03:03 | #11 (permalink) | |
No Life Poster Join Date: Sep 2002 Location: Portugal
Member: 15312 Status: Offline Sonork: 100.1576041 Thanks Meter: 1,097 | Quote:
I´m a bit confused... Humm... you say flashing doesn´t overwrite eeprom or caldata, but we all know that sometimes after flash some problems appear. For example, no network, battery callibration, sim-locks screwed up and etc... and sometimes this can be fixed by writting original caldata. So if flashing doesn´t damage caldata settings, who or what does? Thanks | |
09-09-2004, 21:55 | #12 (permalink) | |
Member: 23684 Status: Offline Sonork: 1582723 Thanks Meter: 684 | Quote:
I writed about concretic Floader v2.1. This program have INACTIVE button OWCD----OwerwriteCalData in normal flashing process. And if IMEI after flashing is same with before flashing---CalData still original. You can damaged CalData with other Floaders for example v28 , where button OWCD is active or specialy used button Write cal. data near button Read cal. data WBR Paul. | |
09-09-2004, 22:26 | #13 (permalink) |
No Life Poster Join Date: Nov 2003 Age: 46
Member: 43076 Status: Offline Thanks Meter: 10 | I have read all your post about that f ucked phone. I have same problem with you last few days this what I have done : get your NCK code when use you manual mode to search the nerwork, wait until your phone find one, press 2945*#5101# then menu 555 got to network select Active then enter the NCK code try and post result here |
09-09-2004, 23:16 | #14 (permalink) | |
WBR Paul. | |
09-10-2004, 00:03 | #15 (permalink) | |
My doubt was when you say that flashing doesn´t damage caldata. But we seen some cases here on forum that even just flashing damaged the caldata. And some fixed the problems by writting the caldata backup. So I think this clearly means that caldata were damaged or written during flashing process. And yes, flashing with 2.1. PS: No need to tell me to read your posts or from anyone else with attention. Because, usually I don´t come here to play or distract myself BR | |
LG U8210 no network after flash !!! | Lhamzagsm | LG | 8 | 11-09-2009 12:55 |
LG U830 no network after flash/unlock | e-person | FuriousGold | 6 | 08-13-2008 22:11 |
lg 2710 no network after flash | umesh garg | Various CDMA/TDMA Cell Phones | 0 | 12-22-2007 16:56 |
LG c3310 no network after flash | pipasbe | HWK | 0 | 07-23-2006 20:02 |
LG U8290 No network after flash | wikad_soft | LG | 4 | 06-15-2006 18:11 |
