10-04-2004, 20:12 | #3 (permalink) |
Freak Poster Join Date: Dec 2003 Age: 50
Member: 47237 Status: Offline Thanks Meter: 0 | Yes I tested it. You must the 2 cables togheter to the lg and to the pc the same time. The software after the boot with com port cable switchs to usb and makes the update. I tested the 3 loaders and only the loader for the 8120 done the good update for the 8110(?). Here are the pin out Keyboard up 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 21 link to 2 19 link to 12 to gnd 18 tx(max 232) 17 rx(max232) 16 +5v (usb) 15 tx(usb) 10 rx (usb) Good look! I tested it and all ok you must only the driver from LG(official) installieren and after that when the software switchs to usb the first time makes error and you must install the driver in the flasher package..... |
10-13-2004, 09:48 | #5 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: Live in your Heart
Member: 71045 Status: Offline Thanks Meter: 19 | Quote:
thanks for cable schematic sir i need the flasher for lg 8120 can u give the llink please i have the flash file thanks in advance Br Zafar Janjua | |
10-19-2004, 12:00 | #7 (permalink) |
Junior Member Join Date: Apr 2004 Age: 53
Member: 61561 Status: Offline Thanks Meter: 0 | HI I cannot understand .. This is the schema of the cable that I can use to also flash the sw inside the phone??? and this can unlock the phone??? is a mix with a serial and usb??? how can I have the schema used for the serial ??? there's a schema I can use to create the complete circuit??? I can provide the USB lg 3 original drivers and the manual to install it and also.. the last release for th flash sw..with the loader but would like to have the completed schema with the component... Tks Eng |
10-19-2004, 13:44 | #9 (permalink) |
Member: 61561 Status: Offline Thanks Meter: 0 | ok.. could someone provide the complete schema with components and where put it??? To do this cable I need 9 "pin" to put inside the Connector versus the Phone correct?? if yes where it's possbile find the "pin" ??? Tks |
11-12-2004, 14:50 | #12 (permalink) | |
No Life Poster Join Date: Sep 2002 Location: Portugal
Member: 15312 Status: Offline Sonork: 100.1576041 Thanks Meter: 1,097 | Quote:
THIS IS JUST TO UNLOCK, THIS PINOUT DONīT FLASH PS: About your blazer advertise, Iīve been deleting all your posts about it. | |
11-29-2004, 05:13 | #14 (permalink) | |
Freak Poster Join Date: Nov 2004 Location: philippines
Member: 93544 Status: Offline Thanks Meter: 1 | Quote:
LG 8110 flash firmware 1.00/1.01 | inbed79 | LG | 9 | 08-17-2005 09:32 |
pleaaaaaase help lg 8110 flash file | markLEE | LG | 1 | 07-05-2005 21:30 |
LG 8110 flash FOR SETOOL | decoder5000 | LG | 2 | 05-29-2005 18:30 |
LG 8110 Flash File | fonetech | LG | 9 | 05-05-2005 18:36 |
lg 8110 flash files!!!! | abbas | LG | 2 | 02-08-2005 00:42 |
